Hi All,
I’m having trouble getting the z-wave add-on to recognise all my devices, I got so frustrated with it that yesterday I wiped everything and re-installed. I still get:-
2017-03-26 09:50:35.943 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 4: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-03-26 09:50:36.286 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 5: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-03-26 09:50:36.629 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 6: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-03-26 09:50:36.966 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 7: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-03-26 09:50:37.298 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 9: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-03-26 09:50:37.666 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 10: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-03-26 09:50:38.334 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 13: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-03-26 09:50:38.638 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 14: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-03-26 09:50:38.944 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 15: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-03-26 09:50:39.278 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 16: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
2017-03-26 09:50:39.548 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 17: Device discovery could not resolve to a thingType! 7FFFFFFF:7FFFFFFF:7FFFFFFF::0.0
I recently purchased a AEON zwave-plus stick (replacing a non-plus stick) as node 2+3 needed is, hence my nodes are not in purchase chronological order.
I think node 13 was node 8 which I performed a hardware reset on to see if that would send the manufactor details, node 4 to 11 are Fibaro Eye’s, 15 & 16 might be Fibaro smoke detectors (FGSS-001 v2.5 EU), node 7 & 14 worked on Friday and are both Fibaro Eye FGMS-001 EU v3.2, node 11 is an old Fibaro Eye (v2.6) and is detected.
It’s strange how everything that fails is battery operated…?
Any pointers to how I can debug this?
I’d like to attach the full zwave log but as a new user it’s stopping me, so here a grep on node 14:-
2017-03-26 09:27:17.857 [INFO ] [age.SerialApiGetInitDataMessageClass] - NODE 14: Node found
2017-03-26 09:27:18.233 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 14: Init node thread start
2017-03-26 09:27:18.990 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 14: Serializing from file /opt/openhab2/userdata/zwave/node14.xml
2017-03-26 09:27:18.993 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 14: Error serializing from file: file does not exist.
2017-03-26 09:27:19.139 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Starting initialisation from EMPTYNODE
2017-03-26 09:27:19.148 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer - EMPTYNODE: queue length(0), free to send(true)
2017-03-26 09:27:19.167 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer: loop - EMPTYNODE try 1: stageAdvanced(false)
2017-03-26 09:27:19.168 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer: Initialisation starting
2017-03-26 09:27:19.170 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer - advancing to PROTOINFO
2017-03-26 09:27:19.172 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer: loop - PROTOINFO try 0: stageAdvanced(true)
2017-03-26 09:27:19.178 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer: PROTOINFO - send IdentifyNode
2017-03-26 09:27:19.219 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 14: Node advancer - queued packet. Queue length is 1
2017-03-26 09:27:19.242 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 14: Init node thread finished
2017-03-26 09:27:19.553 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: ProtocolInfo
2017-03-26 09:27:19.556 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Listening = false
2017-03-26 09:27:19.558 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Routing = true
2017-03-26 09:27:19.560 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Beaming = true
2017-03-26 09:27:19.563 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Version = 4
2017-03-26 09:27:19.565 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: FLIRS = false
2017-03-26 09:27:19.567 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Security = false
2017-03-26 09:27:19.569 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Max Baud = 40000
2017-03-26 09:27:19.572 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Basic = Routing Slave
2017-03-26 09:27:19.574 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Generic = Sensor Notification
2017-03-26 09:27:19.576 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Specific = Notification Sensor
2017-03-26 09:27:19.578 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Creating new instance of command class NO_OPERATION
2017-03-26 09:27:19.580 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Command class NO_OPERATION, endpoint null created
2017-03-26 09:27:19.583 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Version = 1, version set. Enabling extra functionality.
2017-03-26 09:28:00.715 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 14: Is sleeping
2017-03-26 09:28:00.716 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 14: Putting message SendData in wakeup queue.
2017-03-26 09:28:00.727 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: ProtocolInfo
2017-03-26 09:28:00.727 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Listening = false
2017-03-26 09:28:00.727 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Routing = true
2017-03-26 09:28:00.727 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Beaming = true
2017-03-26 09:28:00.728 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Version = 4
2017-03-26 09:28:00.728 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: FLIRS = false
2017-03-26 09:28:00.728 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Security = false
2017-03-26 09:28:00.728 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Max Baud = 40000
2017-03-26 09:28:00.728 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Basic = Routing Slave
2017-03-26 09:28:00.729 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Generic = Sensor Notification
2017-03-26 09:28:00.729 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 14: Specific = Notification Sensor
2017-03-26 09:28:00.729 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Creating new instance of command class NO_OPERATION
2017-03-26 09:28:00.729 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 14: Command class NO_OPERATION, endpoint null created
2017-03-26 09:39:41.503 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Application Command Request (ALIVE:MANUFACTURER)
2017-03-26 09:39:41.505 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Incoming command class ALARM
2017-03-26 09:39:41.506 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Received ALARM command V0
2017-03-26 09:39:41.507 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Process NOTIFICATION_REPORT V0
2017-03-26 09:39:41.508 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: NOTIFICATION report - 0 = 0, event=0, status=255
2017-03-26 09:39:41.509 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Alarm Type = BURGLAR (0)
2017-03-26 09:39:41.547 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Application Command Request (ALIVE:MANUFACTURER)
2017-03-26 09:39:41.548 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Incoming command class ALARM
2017-03-26 09:39:41.548 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Received ALARM command V0
2017-03-26 09:39:41.549 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Process NOTIFICATION_REPORT V0
2017-03-26 09:39:41.550 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: NOTIFICATION report - 0 = 0, event=0, status=255
2017-03-26 09:39:41.550 [DEBUG] [.commandclass.ZWaveAlarmCommandClass] - NODE 14: Alarm Type = BURGLAR (0)
2017-03-26 09:48:08.226 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Incoming command class SENSOR_BINARY
2017-03-26 09:48:08.227 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 14: Received SENSOR_BINARY command V0
2017-03-26 09:48:08.228 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 14: Sensor Binary report, type=Unknown, value=0
2017-03-26 09:48:08.300 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Application Command Request (ALIVE:MANUFACTURER)
2017-03-26 09:48:08.302 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Incoming command class SENSOR_BINARY
2017-03-26 09:48:08.303 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 14: Received SENSOR_BINARY command V0
2017-03-26 09:48:08.304 [DEBUG] [dclass.ZWaveBinarySensorCommandClass] - NODE 14: Sensor Binary report, type=Unknown, value=0
2017-03-26 09:48:08.467 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Application Command Request (ALIVE:MANUFACTURER)
2017-03-26 09:48:08.468 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Incoming command class BASIC
2017-03-26 09:48:08.470 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 14: Received Basic Request
2017-03-26 09:48:08.471 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 14: Basic Set sent to the controller will be processed as Basic Report
2017-03-26 09:48:08.473 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 14: Basic report, value = 0x00
2017-03-26 09:48:08.544 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Application Command Request (ALIVE:MANUFACTURER)
2017-03-26 09:48:08.546 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 14: Incoming command class BASIC
2017-03-26 09:48:08.547 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 14: Received Basic Request
2017-03-26 09:48:08.549 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 14: Basic Set sent to the controller will be processed as Basic Report
2017-03-26 09:48:08.550 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 14: Basic report, value = 0x00
2017-03-26 09:50:38.335 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 14: Device discovery completed
2017-03-26 09:50:38.335 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 14: Checking zwave:qubino_zmnhaa_00_000
2017-03-26 09:50:38.336 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 14: Checking zwave:cbcc_swzcs1_00_000
2017-03-26 09:50:38.336 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 14: Checking zwave:everspring_sf812_00_000
2017-03-26 09:50:38.337 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 14: Checking zwave:philio_psm02_00_000
2017-03-26 09:50:38.337 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 14: Checking zwave:benext_benextalarmsound_00_000
2017-03-26 09:50:38.338 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 14: Checking zwave:vision_zm1601_00_000
2017-03-26 09:50:38.338 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 14: Checking zwave:aeon_dsb28_00_000
2017-03-26 09:50:38.339 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 14: Checking zwave:dragontech_wd100_00_000
2017-03-26 09:50:38.340 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 14: Checking zwave:cooper_rfwc5_00_000
2017-03-26 09:50:38.340 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 14: Checking zwave:benext_builtindimmer_00_000
2017-03-26 09:50:38.341 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 14: Checking zwave:ufairy_ufairy2gangwallswitch_00_000
2017-03-26 09:50:38.341 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 14: Checking zwave:tkb_tsm02_00_000
2017-03-26 09:50:38.634 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 14: Checking zwave:mcohome_mhs312_00_000
2017-03-26 09:50:38.634 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 14: Checking zwave:ge_zw3101_00_000
2017-03-26 09:50:38.635 [DEBUG] [wave.discovery.ZWaveDiscoveryService] - NODE 14: Checking zwave:aeon_dsc18_00_000
2017-03-26 09:51:50.867 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: MANUFACTURER not set
2017-03-26 09:51:50.868 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Controller status changed to ONLINE.
2017-03-26 09:51:50.868 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Controller is ONLINE. Starting device initialisation.
2017-03-26 09:51:50.870 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Updating node properties.
2017-03-26 09:51:50.871 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Updating node properties. MAN=2147483647
2017-03-26 09:51:50.874 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Properties synchronised
2017-03-26 09:51:50.880 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Configuration synchronised
2017-03-26 09:51:50.928 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Initialising Thing Node…
2017-03-26 09:51:50.931 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Polling intialised at 1800 seconds - start in 1800000 milliseconds.
2017-03-26 10:02:10.413 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 14: Serialise aborted as static stages not complete
2017-03-26 10:02:10.424 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: MANUFACTURER not set
2017-03-26 10:02:10.425 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Controller status changed to ONLINE.
2017-03-26 10:02:10.426 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Controller is ONLINE. Starting device initialisation.
2017-03-26 10:02:10.428 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Updating node properties.
2017-03-26 10:02:10.429 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Updating node properties. MAN=2147483647
2017-03-26 10:02:10.430 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Configuration synchronised
2017-03-26 10:02:10.460 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Initialising Thing Node…
2017-03-26 10:02:10.461 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 14: Polling intialised at 1800 seconds - start in 1800000 milliseconds.
Kind regards,
Paul
