My Z-wave was working fine with OH 2.5. When I wanted to experience with Telegram the problem started. At then end I got the perfect solution to get remove the telegram action and binding.
I needed to restart OH a few times and found that Z-wave didn’t work anymore for almost all devices Only the PIR devices are still working.
The z-wave network viewer still looks fine.
In event.log I get about every 100 ms a entry (see below)
This will be the startframe counter.
The ack counter is updated very slow and assume only on frames from the PIR devices.
The other counters are not updated
What does this mean and how to troubleshoot / fix the issue.
2021-09-17 09:13:16.841 [vent.ItemStateChangedEvent] - ZWaveControllerSerialSof changed from 1620519 to 1620520
2021-09-17 09:13:17.153 [vent.ItemStateChangedEvent] - ZWaveControllerSerialSof changed from 1620520 to 1620521
2021-09-17 09:13:17.179 [vent.ItemStateChangedEvent] - ZWaveControllerSerialSof changed from 1620521 to 1620522
2021-09-17 09:13:17.307 [vent.ItemStateChangedEvent] - ZWaveControllerSerialSof changed from 1620522 to 1620523
2021-09-17 09:13:17.352 [vent.ItemStateChangedEvent] - ZWaveControllerSerialSof changed from 1620523 to 1620524
2021-09-17 09:13:17.398 [vent.ItemStateChangedEvent] - ZWaveControllerSerialSof changed from 1620524 to 1620525
2021-09-17 09:13:17.410 [vent.ItemStateChangedEvent] - ZWaveControllerSerialSof changed from 1620525 to 1620526
2021-09-17 09:13:17.434 [vent.ItemStateChangedEvent] - ZWaveControllerSerialSof changed from 1620526 to 1620527
2021-09-17 09:13:17.449 [vent.ItemStateChangedEvent] - ZWaveControllerSerialSof changed from 1620527 to 1620528
2021-09-17 09:13:17.487 [vent.ItemStateChangedEvent] - ZWaveControllerSerialSof changed from 1620528 to 1620529
2021-09-17 09:13:17.695 [vent.ItemStateChangedEvent] - ZWaveControllerSerialSof changed from 1620529 to 1620530
2021-09-17 09:13:17.710 [vent.ItemStateChangedEvent] - ZWaveControllerSerialSof changed from 1620530 to 1620531
2021-09-17 09:13:17.794 [vent.ItemStateChangedEvent] - ZWaveControllerSerialSof changed from 1620531 to 1620532
2021-09-17 09:13:17.811 [vent.ItemStateChangedEvent] - ZWaveControllerSerialSof changed from 1620532 to 1620533
2021-09-17 09:13:17.849 [vent.ItemStateChangedEvent] - ZWaveControllerSerialSof changed from 1620533 to 1620534
2021-09-17 09:13:18.028 [vent.ItemStateChangedEvent] - ZWaveControllerSerialSof changed from 1620534 to 1620535
2021-09-17 09:13:18.250 [vent.ItemStateChangedEvent] - ZWaveControllerSerialSof changed from 1620535 to 1620536
2021-09-17 09:13:19.903 [vent.ItemStateChangedEvent] - ZWaveControllerSerialSof changed from 1620536 to 1620537
2021-09-17 09:13:19.905 [vent.ItemStateChangedEvent] - Beweging_gBGWoonkamer changed from OFF to ON
