Yesterday evening I updated my openhabian. After the update all of my z-wave devices (things) were offline including the controller (Aeotec AEOEZW090-C). I readied the controller but again, every z-wave thing stayed offline.
When I try to switch the z-wave wall plug I get the following log in karaf:
Cannot delegate command 'ON' for item 'WallPlug1_Switch' to handler for channel 'zwave:device:95e90737:node2:switch_binary', because no handler is assigned. Maybe the binding is not installed or not propertly initialized.
Today I saw under Habmin, that there are no more Configurations set for the Associated groups. When I set e.g. group1 to openHAB Controller I get the log in karaf:
Exception during HTTP PUT request for update config at 'things/zwave:device:95e90737:node2/config' for thing 'zwave:device:95e90737:node2': Thing with UID zwave:device:95e90737:node2 has no handler attached.
Additional I can see the things again in my inbox under paper UI. I there a possibility to reinitialize the existing things or have I to delete the existing things, add the new ones and link them to the existing items? Thats not bad (only 4 things) but I want to understand what happens and what I did wrong.
Thanks for your help.
