I have a small Z-Wave testing network, devices close to each other, around 2 meters:
- controller Aeon Z-Stick Gen5 (ZW090-C)
- Pan04-1B Relay
- Qubino Flush 2 Relay ZMNHBD1
Running on Debian + OH 2.0. This configuration is in this state already for few weeks, so it should be stable from Z-wave network point of view.
My problem is that everything works fine, apart from state reporting. When I press a physical button connected to a relay it changes circuit state, but do not report to OH. After some time (several minutes) state gets updated, but I suspect this is due to pooling. Same problem applied to both relays mentioned above. For each of them I had association configured, pointing switches or default reporting to “openhab controller”, when viewing this value in Habmin.
Because both switches behave in the same way, I suspec that I’m missing something and this is not a device bug. All devices are new ones, so as far as I understood from reading multiple threads, they should work.
I’ll appreciate any advice.
Adam
