I have the devolo humidity sensor which is already secured included in the controller by using zway. Now I try use it with the zwave binding. But I only get the message ‘unkown device’ and no node xml file is created.
Currently I use the Openhab 2 stable version.
Any idea?
UPDATE: If have now excluded the device and include them from the openhab. Now I get the node xml file, but the thing does not show any channels. The device is not yet in the database. Is it possible to create the item for humanity and temperature manually?
UPDATE: I have added the device to the database and now it works with the 2.1 builds
Kind regards,
Michael
