I am considering developing a zwavejs alternative to the current zwave addon that is independent of OH for thread management & device database updates. It would use the web user interface and websocket server of zwavejs2mqtt and HABApp to interface with OH through the REST API.
ZWaveJS supports
Smart Start ( I have not tested this feature personally)
S2 security
700 Series controllers. I currently recommend avoiding those controllers for now due to this firmware issue being investigated by Silicon Labs.
In my testing, I gave had no issues including battery operated devices. In some cases the full interview may take hours, but it completes successfully.
Are you a Z-Wave user who also uses Docker?
Yes
No
0voters
I started looking at alternatives after Kai said I had to wait 3 months before my new 700 Series devices were supported in OH by the Device Database. The entries already existed on the DB server but not in an addon compatible with the stable release at that time.
i am trying to gauge user interest before pouring time into this project idea. ZwaveJS has a group of developers working on it and updating the device database Here is the current list of supported devices.
While I am a Zwave user and Docker user (and voted yes) I would probably just use the MQTT feed directly to maintain Thing/Item separation and be able to take advantage of “create equipment from thing” and stuff like that. Needing to manually create the Items would be a pretty big pain. Having something create a bunch of Items for me automatically would be an even bigger pain.
I also don’t have any 700 series Zwave stuff and have no plans to purchase more Zwave stuff in general. I’m pretty happy with my current set of devices and ZigBee works just as well for me and it’s cheaper.
Very good idea!! I am also sruggling with e.g. Aeotec Sirene 6 which is (still) not supported by OH3.2 (but supported by many other link HA, Zway, Vera..) The inclusion and seting of zwave devices runs perfectly in zwavejs.
Yes, ZwaveJS supports this Siren. I tried to switch to Home Assistant, but complex rules are easier in Openhab to realise. With ZWaveJSMQTT is too much work, to settle up each channel manually. Therefore a direct integration via binding would be perfect. As you wrote, ZWaveJS supports S2 and have a better overview during inclusion process.
I would say different, not complex. With HA using the YAML text file has many more options than available in the WebUI.
I appreciate your interest. I am unsure whether there is little other interest here or others have not discovered this thread. I suspect a lack of interest.
It would take some effort for me to figure out the client portion of it & then translate it to REST API calls. since I no longer use OH I would be unable to support it well either. I approached the developer of HABApp who uses Z-Wave but he was uninterested.
@Joern1
If you our Siren 6 has firmware 1.6, could you please post the xml file from OH here? I am looking at possibly updating the database & there may be some actifity on getting the binding updated to support it.
If you have older firmware, instructions on how to upgrade to 1.06 (reported as 1.6) are on Aeotec’s support site.
