I have the following error which comes several times per seconds, which makes my logs grow like crazy (> 1 Go for now) :
2016-02-19 20:57:19.114 [DEBUG] [eController$ZWaveReceiveThread:1528]- Receive Message = 01 0E 00 04 00 03 08 32 02 21 12 00 E6 00 00 1B
2016-02-19 20:57:19.154 [DEBUG] [eController$ZWaveReceiveThread:1452]- Receive queue ADD: Length=1
2016-02-19 20:57:19.154 [DEBUG] [b.z.i.protocol.ZWaveController:1210]- Receive queue TAKE: Length=0
2016-02-19 20:57:19.165 [DEBUG] [o.b.z.i.protocol.SerialMessage:233 ]- Assembled message buffer = 01 0E 00 04 00 03 08 32 02 21 12 00 E6 00 00 1B
2016-02-19 20:57:19.183 [DEBUG] [b.z.i.protocol.ZWaveController:1211]- Process Message = 01 0E 00 04 00 03 08 32 02 21 12 00 E6 00 00 1B
2016-02-19 20:57:19.192 [DEBUG] [b.z.i.protocol.ZWaveController:190 ]- Message: class = ApplicationCommandHandler (0x04), type = Request (0x00), payload = 00 03 08 32 02 21 12 00 E6 00 00
2016-02-19 20:57:19.194 [DEBUG] [ApplicationCommandMessageClass:38 ]- NODE 3: Application Command Request (ALIVE:DONE)
2016-02-19 20:57:19.197 [DEBUG] [ApplicationCommandMessageClass:56 ]- NODE 3: Incoming command class METER
2016-02-19 20:57:19.200 [DEBUG] [z.i.p.c.ZWaveMeterCommandClass:109 ]- NODE 3: Received Meter Request
2016-02-19 20:57:19.203 [DEBUG] [z.i.p.c.ZWaveMeterCommandClass:157 ]- NODE 3: Meter: Type=Electric(1), Scale=W(2), Value=2.3E+2
2016-02-19 20:57:19.206 [DEBUG] [b.z.i.protocol.ZWaveController:682 ]- Notifying event listeners: ZWaveMeterValueEvent
2016-02-19 20:57:19.208 [DEBUG] [.z.internal.ZWaveActiveBinding:433 ]- ZwaveIncomingEvent
2016-02-19 20:57:19.211 [DEBUG] [.z.internal.ZWaveActiveBinding:450 ]- NODE 3: Got a value event from Z-Wave network, endpoint = 0, command class = METER, value = 2.3E+2
2016-02-19 20:57:19.215 [DEBUG] [ApplicationCommandMessageClass:85 ]- Transaction not completed: node address inconsistent.
It comes from a Everspring wall plug switch and energy meter. The switch & meter works but sometime report false states, which could be related to the issue.
What can I do ?
I am using openhab 1 on a RPi2 with a Sigma UZB stick and the zwave binding 1.7.1 (1.8 does not work for some reasons).
