I have Fakro window and USB ZME – UZB1. When i added a z-wave binding openhab found a controller and window’s nodes (screens). What now I have to do to control the window? Can You help me and write some examples of thing or items which I have to add? Thanks for help in advice.
things:
Bridge zwave:serial_zstick:4fe7657b “Z-Wave Serial Controller” @ “Z-Wave” [ port="/dev/ttyACM0", controller_softreset=“false”, controller_master=“true”, heal_enable=“true”, security_networkkey="" ]
items:
Switch okno_zasilanie2 “Okno 2 zasilanie” {channel=“zwave:device:4fe7657b:node5:switch_binary”,autoupdate=“false”}
But it does not work
Node 5 shows as an Unknown Device. That means the binding has not yet fully discovered the device and its capabilities. Battery operated devices need to be woken up many times to allow discovery to complete.
Did you manually create the Fakro Thing or was it auto discovered?
Every node (or z wave things) was auto discovered.
