[SOLVED] Z-Wave Fibaro Multi Sensor and Flood Sensor does not work
Platform information:
Hardware: Raspberry PI3
OS: Linux raspberrypi 4.14.79-v7+ #1159 SMP Sun Nov 4 17:50:20 GMT 2018 armv7l GNU/Linux
Java™ SE Runtime Environment (build 1.8.0_191-b12)
openHAB version: 2.4.0
I’m running OpenHab with several devices. Two of them does not work as expected.
One of the two Fibaro Multi Sensors does not send motion and tamper events (lumen and temperature works)
One of the two Fibaro Flood Sensors does not send flood and tamper events (temperature works).
I have no clue what I’m doign wrong. No errors are shown at the logfiles.
Do you have any ideas what to do?
Best regards
Tobias
Same as here:
Association group.
Hi Sihui,
hm I think I’m not really sure what you mean exactly. May you can explain it for a beginner?
Set “Controller Updates” (for newer devices it is called “Lifeline”) to your controller.
grafik
It is recommended to use HABmin when changing config parameters for zwave.
Oh great! THANKS!
