Ok, then if you confirm that it’s a hub, then it can’t be used with the ZWave binding as a ZWave controller.
I also think the same, but the Hogar guys say that you will require another hub to cover the area I want to.
When all you sell are hammers, everything looks like a nail. That is the only solution THEY sell.
Hmm I guess so…Thanks for your valuable inputs.
Check the attached link out, is this the same you have suggested?
As it shows that it needs some external software to run.
Forget the attachment?
You forgot to attach the link. But if you mean the ZMEEUZB from z-wave.me I guess there is mentioned Z-Way (also from z-wave.me). This is a seperate home automation software. But you do NOT need it (and not even a license) for running a ZMEEUZB with Z-Wave binding of Openhab.
Oops!! I forgot to attach a link , but it is the version you mentioned…so I think that with the links you have provided earlier I would be able to change the frequency.
Thanks man, will try and update here.
