I’ve recently installed a MCO Home MH-S411 and MH-S412 switch. The MH-S412 switch was correctly recognised in openHAB (v2.5.10), but the MH-S411 was not. It is displayed with the following ID: ‘015F:4111:5102:5.10’.
The MH-S411 device apparently already exists in the Z-Wave database, but it has a different device type and device ID (4102:0201). However, I have also found another device in the database TPS411 that does have a device type and device ID that corresponds with my device, but it has a firmware limitation <5.5 (which is probably the reason why my device is still not recognised).
I’m quite new at this, so I wonder if anyone could help in correctly adding my device to the database?
Here is the xml file for my device: network_d456e2a4__node_3.xml (17.4 KB)
The manual for the device can be found on this page of the MCO Home website (it is the same manual for all the MH-S4xx switches).
Let me know if there is any additional information I need to provide.
