I’m newish to z-wave still so please excuse the question if this is already known, I couldn’t find the answer when searching. For some reason, most nights around 8-9PM my motion sensors refuse to respond for a few minutes. The light on the sensors (which usually blinks green when motion is detected) is stuck on while this is happening. I had originally thought this was the heal process happening and just taking time. My configuration however should only trip the heal at 2AM to avoid those issues. The only thing I can think of is that the heal setting is assuming GMT and not local time (I’m -6HRS CST). I see nothing in the logs of relevance (I have not enabled debug or trace however yet). Any help is appreciated. Thanks!
I’d advise you to do this - debug logging is all that’s needed. Without this we can discuss the possible causes for a while, but it just be speculation without something more solid to go on.
I just turned debugging on, now to wait until it happens again. Any reason to do trace?
There are reasons to do trace, but not here. Trace level is really getting into the nitty gritty - any issue will show up with debug and its only if we need to go deeper will we need trace. Trace logging will generate a lot of data which is seldom needed so it’s best left off.
I ask you that question since the binding documentation explicitly says DEBUG. do not filter the logs either.
