Please be aware that the MULTILEVEL_SENSOR command is broken in the latest build (1415). This impacts temperature, humidity, luminance, etc. readings received via the MULTILEVEL_SENSOR command class. Readings received using this command class are not being processed by the binding.
If you have devices that produce this command class (thermostats, sensors, etc.) you might want to avoid upgrading until this is fixed.
@chris I left some comments on your most recent PR.
