[SOLVED] Z Wave nano switch in France shows up unknown
Thank you so much @chris,
It worked. The binding org.openhab.binding.zwave-2.2.0-SNAPSHOT.jar was active.
Must do that " feature:install openhab-transport-serial " to make binding active.
Again, thank you so much :slight_smile:
Hi there,
I’m having the same issue but it seems to be another (newer?) device?
I uninstalled the binding (not the thing, right?) and reinstalled it. Still having an “Unknown Device”.
As I see the thing has different manufacturer IDs in PaperUI and Habmin. ???habminpaperui
Can anybody help?
I am having the same problem and I think it’s because I have the AU/NZ version of the Aeotec devices (Aeotec Duel Nano Switch with energy meeting ZW132-B). I get this:
Z-Wave Node 2 (0086:0203:0084:1.4)
Unknown Device
zwave:device:e622be53:node2
can you help me please!
Thanks,
These codes are already in the database, so the device should be found if youre using the latest snapshot at least.
Hi Chris,
Thanks so much for the quick reply. I am using:
https://openhab.ci.cloudbees.com/job/openHAB2-Bundles/lastSuccessfulBuild/artifact/bindings/org.openhab.binding.zwave/target/
and its showing:
211 | Active | 80 | 2.3.0.201803101457 | ZWave Binding
I cant find anything newer
not sure if this helps, this is what its coming up with:
Unknown Device
This device has not been fully discovered by the binding. There are a few possible reasons for this -:
The device is not in the database. If the device attributes show that this device has a valid manufacturer ID, device ID and type, then this is likely the case (eg. you see a label like “Z-Wave node 1 (0082:6015:020D::2.0)”). Even if the device appears to be in the database, some manufacturers use multiple sets of references for different regions or versions, and your device references may not be in the database. In either case, the database must be updated and you should raise an issue to get this addressed.
The device initialisation is not complete. Once the device is included into the network, the binding must interrogate it to find out what type of device it is. One part of this process is to get the manufacturer information required to identify the device, and until this is done, the device will remain unknown. For mains powered devices, this will occur quickly, however for battery devices the device must be woken up a number of times to allow the discovery phase to complete. This must be performed with the device close to the controller.
Status: ONLINE
zwave_class_basic ROUTING_SLAVE
zwave_class_generic BINARY_SWITCH
zwave_frequent false
zwave_neighbours 1
zwave_version 1.4
zwave_listening true
zwave_plus_devicetype ON_OFF_POWER_SWITCH
zwave_deviceid 132
zwave_nodeid 2
zwave_routing true
zwave_beaming true
zwave_class_specific POWER_SWITCH_BINARY
zwave_manufacturer 134
zwave_devicetype 515
As I said before, this device is already in the database so I’m not sure why it would not be discovered unless this addition was only added in the last few days (I think not though as the last update was 5 days ago).
Is there a different version I can try? even if it’s older.
is there a workaround?
I am not sure where to go from here. Any help would be appreciated
This is what the log file says:
2018-03-15 00:34:02.247 [ThingAddedEvent ] - Thing ‘zwave:device:e622be53:node2’ has been added.
2018-03-15 00:34:02.254 [hingStatusInfoChangedEvent] - ‘zwave:device:e622be53:node2’ changed from UNINITIALIZED to INITIALIZING
2018-03-15 00:34:02.255 [hingStatusInfoChangedEvent] - ‘zwave:device:e622be53:node2’ changed from INITIALIZING to OFFLINE (BRIDGE_OFFLINE): Controller is offline
2018-03-15 00:34:02.257 [hingStatusInfoChangedEvent] - ‘zwave:device:e622be53:node2’ changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2018-03-15 00:34:04.408 [ItemStateChangedEvent ] - zwave_serial_zstick_e622be53_serial_ack changed from 38 to 39
2018-03-15 00:34:04.495 [ItemStateChangedEvent ] - zwave_serial_zstick_e622be53_serial_sof changed from 75 to 76
2018-03-15 00:34:04.498 [BindingEvent ] - org.openhab.binding.zwave.event.BindingEvent@1ab700e
2018-03-15 00:34:04.503 [ItemStateChangedEvent ] - zwave_serial_zstick_e622be53_serial_ack changed from 39 to 40
2018-03-15 00:34:04.504 [ItemStateChangedEvent ] - zwave_serial_zstick_e622be53_serial_sof changed from 76 to 77
2018-03-15 00:34:04.507 [BindingEvent ] - org.openhab.binding.zwave.event.BindingEvent@1dcbe52
2018-03-15 00:34:07.257 [ThingUpdatedEvent ] - Thing ‘zwave:device:e622be53:node2’ has been updated.
2018-03-15 00:34:07.258 [ConfigStatusInfoEvent ] - ConfigStatusInfo [configStatusMessages=[]]
Is there any other diagnostic info that I can extract?
Also this might help?
**2018-03-14 23:08:20.790 [WARN ] [ig.xml.osgi.XmlDocumentBundleTracker] - The XML document '/ESH-INF/thing/aeon_zw132_0_0.xml' in module 'org.openhab.binding.zwave' could not be parsed: The document is invalid, it contains further unsupported data: [NodeValue [nodeName=category, value=WallSwitch], NodeList [nodeName=channels, attributes={}, list=[ChannelTypeXmlResult [id=switch_binary, typeId=switch_binary, properties=[NodeValue [nodeName=property, value=SWITCH_BINARY,BASIC]]], ChannelTypeXmlResult [id=scene_number, typeId=scene_number, properties=[NodeValue [nodeName=property, value=SCENE_ACTIVATION]]], ChannelTypeXmlResult [id=meter_kwh, typeId=meter_kwh, properties=[NodeValue [nodeName=property, value=METER;type=E_KWh]]], ChannelTypeXmlResult [id=meter_watts, typeId=meter_watts, properties=[NodeValue [nodeName=property, value=METER;type=E_W]]], ChannelTypeXmlResult [id=meter_current, typeId=meter_current, properties=[NodeValue [nodeName=property, value=METER;type=E_A]]], ChannelTypeXmlResult [id=meter_voltage, typeId=meter_voltage, properties=[NodeValue [nodeName=property, value=METER;type=E_V]]], ChannelTypeXmlResult [id=alarm_power, typeId=alarm_power, properties=[NodeValue [nodeName=property, value=ALARM;type=POWER_MANAGEMENT]]], ChannelTypeXmlResult [id=alarm_heat, typeId=alarm_heat, properties=[NodeValue [nodeName=property, value=ALARM;type=HEAT]]], ChannelTypeXmlResult [id=time_offset, typeId=time_offset, properties=[NodeValue [nodeName=property, value=CLOCK]]], ChannelTypeXmlResult [id=switch_binary1, typeId=switch_binary, properties=[NodeValue [nodeName=property, value=BASIC:1]]], ChannelTypeXmlResult [id=switch_binary1, typeId=switch_binary, properties=[NodeValue [nodeName=property, value=SWITCH_BINARY:1,BASIC:1]]], ChannelTypeXmlResult [id=meter_kwh1, typeId=meter_kwh, properties=[NodeValue [nodeName=property, value=METER:1;type=E_KWh]]], ChannelTypeXmlResult [id=meter_watts1, typeId=meter_watts, properties=[NodeValue [nodeName=property, value=METER:1;type=E_W]]], ChannelTypeXmlResult [id=meter_current1, typeId=meter_current, properties=[NodeValue [nodeName=property, value=METER:1;type=E_A]]], ChannelTypeXmlResult [id=meter_voltage1, typeId=meter_voltage, properties=[NodeValue [nodeName=property, value=METER:1;type=E_V]]], ChannelTypeXmlResult [id=switch_binary2, typeId=switch_binary, properties=[NodeValue [nodeName=property, value=BASIC:2]]], ChannelTypeXmlResult [id=switch_binary2, typeId=switch_binary, properties=[NodeValue [nodeName=property, value=SWITCH_BINARY:2,BASIC:2]]], ChannelTypeXmlResult [id=meter_kwh2, typeId=meter_kwh, properties=[NodeValue [nodeName=property, value=METER:2;type=E_KWh]]], ChannelTypeXmlResult [id=meter_watts2, typeId=meter_watts, properties=[NodeValue [nodeName=property, value=METER:2;type=E_W]]], ChannelTypeXmlResult [id=meter_current2, typeId=meter_current, properties=[NodeValue [nodeName=property, value=METER:2;type=E_A]]], ChannelTypeXmlResult [id=meter_voltage2, typeId=meter_voltage, properties=[NodeValue [nodeName=property, value=METER:2;type=E_V]]]]], NodeList [nodeName=properties, attributes={}, list=[NodeValue [nodeName=property, value=AEON Labs], NodeValue [nodeName=property, value=ZW132], NodeValue [nodeName=property, value=0086], NodeValue [nodeName=property, value=0103:0084,0203:0084], NodeValue [nodeName=property, value=724], NodeValue [nodeName=property, value=1]]], ConfigDescription [uri=thing-type:zwave:aeon_zw132_00_000, parameters=[ConfigDescriptionParameter [name=config_3_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=3: Current Overload Protection., description=Current Overload Protection., defaultValue=1], ConfigDescriptionParameter [name=config_4_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=4: Overheat protection, description=Overheat protection, defaultValue=0], ConfigDescriptionParameter [name=config_20_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=20: Configure the output status after re-power on it., description=Configure the output status after re-power on it., defaultValue=0], ConfigDescriptionParameter [name=config_80_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=80: Group 1 notifications, description=To set which notification would be sent to the associated devices (Group 1), defaultValue=0], ConfigDescriptionParameter [name=config_81_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=81: Group 3 notifications, description=To set which notification would be sent to association group 3, defaultValue=1], ConfigDescriptionParameter [name=config_82_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=82: Group 4 notifications, description=To set which notification would be sent to association group 4, defaultValue=1], ConfigDescriptionParameter [name=config_90_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=90: Enables/disables parameter 91 and 92 below:, description=Enables/disables parameter 91 and 92 below:, defaultValue=0], ConfigDescriptionParameter [name=config_91_2, type=INTEGER, groupName=configuration, min=0, max=60000, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=91: Set the threshold value of wattage., description=Set the threshold value of wattage., defaultValue=25], ConfigDescriptionParameter [name=config_92_1, type=INTEGER, groupName=configuration, min=0, max=100, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=92: Set the threshold value of wattage., description=Set the threshold value of wattage., defaultValue=5], ConfigDescriptionParameter [name=config_101_4, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=101: Set group 1 reports, description=To set which reports need to be sent in Report group 1, defaultValue=0], ConfigDescriptionParameter [name=config_102_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=102: To set which reports need to be sent in Report group 2., description=To set which reports need to be sent in Report group 2., defaultValue=0], ConfigDescriptionParameter [name=config_103_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=103: To set which reports need to be sent in Report group 3, description=To set which reports need to be sent in Report group 3., defaultValue=0], ConfigDescriptionParameter [name=config_111_4, type=INTEGER, groupName=configuration, min=1, max=2147483647, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=111: Set the interval of automatic report for Report group 1., description=Set the interval of automatic report for Report group 1., defaultValue=10], ConfigDescriptionParameter [name=config_112_4, type=INTEGER, groupName=configuration, min=1, max=2147483647, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=112: Set the interval of automatic report for Report group 2, description=Set the interval of automatic report for Report group 2., defaultValue=600], ConfigDescriptionParameter [name=config_113_4, type=INTEGER, groupName=configuration, min=1, max=2147483647, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=113: Set the interval of automatic report for Report group 2., description=Set the interval of automatic report for Report group 2., defaultValue=600], ConfigDescriptionParameter [name=config_120_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=120: Configure the external switch mode for S1, description=Configure the external switch mode for S1, defaultValue=0], ConfigDescriptionParameter [name=config_121_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=121: Configure the external switch mode for S2., description=Configure the external switch mode for S2., defaultValue=0], ConfigDescriptionParameter [name=config_122_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=122: Set the control destination for external switch, description=Set the control destination for external switch, defaultValue=3], ConfigDescriptionParameter [name=config_252_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=252: Lock/unlock configuration parameters, description=Lock/unlock configuration parameters, defaultValue=0], ConfigDescriptionParameter [name=config_255_4, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=255: Reset the Dual Nano Switch, description=Reset the Dual Nano Switch, defaultValue=0], ConfigDescriptionParameter [name=config_100_1_wo, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=100: Set parameter 101-103 to default value, description=Reset the parameter 101-103, defaultValue=0], ConfigDescriptionParameter [name=config_110_1_wo, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=110: Set parameter 111-113 to default value., description=Set parameter 111-113 to default value., defaultValue=0], ConfigDescriptionParameter [name=group_1, type=TEXT, groupName=association, readOnly=false, required=false, verify=false, multiple=true, multipleLimit=5, label=1: Lifeline, description=When the load state of Dual Nano Switch (turn on/off the load) is changed, the Hail CC and Basic Report (configured by parameter 80) can be sent to the associated nodes in this group.], ConfigDescriptionParameter [name=group_2, type=TEXT, groupName=association, readOnly=false, required=false, verify=false, multiple=true, multipleLimit=5, label=2: Forward the Basic Set, description=Switch All, Scene Activation Set to associated nodes in Group 2 when the Dual Nano Switch receives the Basic Set, Switch All, Scene Activation Set commands from main controller. (E.g. Send/forward Basic Set to control the other nodes in association Group], ConfigDescriptionParameter [name=group_3, type=TEXT, groupName=association, readOnly=false, required=false, verify=false, multiple=true, multipleLimit=5, label=3: Send Basic Set, description=(configured by parameter 0x51 ) to the associated nodes in Group 3 when the external switch S1 is operated. Note: The Switch Mode of external switch S1 should be identified successfully, which means that the value of Configuration parameter 0x78 should be], ConfigDescriptionParameter [name=group_4, type=TEXT, groupName=association, readOnly=false, required=false, verify=false, multiple=true, multipleLimit=5, label=4: Send Basic Set, description=Send Basic Set (configured by parameter 0x52) to the associated nodes in Group 4 when the external switch S2 is operated. Note: The Switch Mode of external switch S2 should be identified successfully, which means that the value of Configuration parameter]], groups=[ConfigDescriptionParameterGroup [groupId="configuration", context="setup", advanced="false", label="Configuration Parameters", description="null"], ConfigDescriptionParameterGroup [groupId="actions", context="setup", advanced="false", label="Actions", description="null"], ConfigDescriptionParameterGroup [groupId="association", context="link", advanced="false", label="Association Groups", description="null"]]]]!**
**---- Debugging information ----**
**class               : org.eclipse.smarthome.core.thing.xml.internal.ThingTypeXmlResult**
**required-type       : org.eclipse.smarthome.core.thing.xml.internal.ThingTypeXmlResult**
**converter-type      : org.eclipse.smarthome.core.thing.xml.internal.ThingTypeConverter**
**path                : /thing-descriptions/thing-type**
**line number         : 434**
**class[1]            : java.util.ArrayList**
**converter-type[1]   : com.thoughtworks.xstream.converters.collections.CollectionConverter**
**class[2]            : org.eclipse.smarthome.core.thing.xml.internal.ThingDescriptionList**
**converter-type[2]   : org.eclipse.smarthome.core.thing.xml.internal.ThingDescriptionConverter**
**version             : 1.4.7**
**com.thoughtworks.xstream.converters.ConversionException: The document is invalid, it contains further unsupported data: [NodeValue [nodeName=category, value=WallSwitch], NodeList [nodeName=channels, attributes={}, list=[ChannelTypeXmlResult [id=switch_binary, typeId=switch_binary, properties=[NodeValue [nodeName=property, value=SWITCH_BINARY,BASIC]]], ChannelTypeXmlResult [id=scene_number, typeId=scene_number, properties=[NodeValue [nodeName=property, value=SCENE_ACTIVATION]]], ChannelTypeXmlResult [id=meter_kwh, typeId=meter_kwh, properties=[NodeValue [nodeName=property, value=METER;type=E_KWh]]], ChannelTypeXmlResult [id=meter_watts, typeId=meter_watts, properties=[NodeValue [nodeName=property, value=METER;type=E_W]]], ChannelTypeXmlResult [id=meter_current, typeId=meter_current, properties=[NodeValue [nodeName=property, value=METER;type=E_A]]], ChannelTypeXmlResult [id=meter_voltage, typeId=meter_voltage, properties=[NodeValue [nodeName=property, value=METER;type=E_V]]], ChannelTypeXmlResult [id=alarm_power, typeId=alarm_power, properties=[NodeValue [nodeName=property, value=ALARM;type=POWER_MANAGEMENT]]], ChannelTypeXmlResult [id=alarm_heat, typeId=alarm_heat, properties=[NodeValue [nodeName=property, value=ALARM;type=HEAT]]], ChannelTypeXmlResult [id=time_offset, typeId=time_offset, properties=[NodeValue [nodeName=property, value=CLOCK]]], ChannelTypeXmlResult [id=switch_binary1, typeId=switch_binary, properties=[NodeValue [nodeName=property, value=BASIC:1]]], ChannelTypeXmlResult [id=switch_binary1, typeId=switch_binary, properties=[NodeValue [nodeName=property, value=SWITCH_BINARY:1,BASIC:1]]], ChannelTypeXmlResult [id=meter_kwh1, typeId=meter_kwh, properties=[NodeValue [nodeName=property, value=METER:1;type=E_KWh]]], ChannelTypeXmlResult [id=meter_watts1, typeId=meter_watts, properties=[NodeValue [nodeName=property, value=METER:1;type=E_W]]], ChannelTypeXmlResult [id=meter_current1, typeId=meter_current, properties=[NodeValue [nodeName=property, value=METER:1;type=E_A]]], ChannelTypeXmlResult [id=meter_voltage1, typeId=meter_voltage, properties=[NodeValue [nodeName=property, value=METER:1;type=E_V]]], ChannelTypeXmlResult [id=switch_binary2, typeId=switch_binary, properties=[NodeValue [nodeName=property, value=BASIC:2]]], ChannelTypeXmlResult [id=switch_binary2, typeId=switch_binary, properties=[NodeValue [nodeName=property, value=SWITCH_BINARY:2,BASIC:2]]], ChannelTypeXmlResult [id=meter_kwh2, typeId=meter_kwh, properties=[NodeValue [nodeName=property, value=METER:2;type=E_KWh]]], ChannelTypeXmlResult [id=meter_watts2, typeId=meter_watts, properties=[NodeValue [nodeName=property, value=METER:2;type=E_W]]], ChannelTypeXmlResult [id=meter_current2, typeId=meter_current, properties=[NodeValue [nodeName=property, value=METER:2;type=E_A]]], ChannelTypeXmlResult [id=meter_voltage2, typeId=meter_voltage, properties=[NodeValue [nodeName=property, value=METER:2;type=E_V]]]]], NodeList [nodeName=properties, attributes={}, list=[NodeValue [nodeName=property, value=AEON Labs], NodeValue [nodeName=property, value=ZW132], NodeValue [nodeName=property, value=0086], NodeValue [nodeName=property, value=0103:0084,0203:0084], NodeValue [nodeName=property, value=724], NodeValue [nodeName=property, value=1]]], ConfigDescription [uri=thing-type:zwave:aeon_zw132_00_000, parameters=[ConfigDescriptionParameter [name=config_3_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=3: Current Overload Protection., description=Current Overload Protection., defaultValue=1], ConfigDescriptionParameter [name=config_4_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=4: Overheat protection, description=Overheat protection, defaultValue=0], ConfigDescriptionParameter [name=config_20_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=20: Configure the output status after re-power on it., description=Configure the output status after re-power on it., defaultValue=0], ConfigDescriptionParameter [name=config_80_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=80: Group 1 notifications, description=To set which notification would be sent to the associated devices (Group 1), defaultValue=0], ConfigDescriptionParameter [name=config_81_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=81: Group 3 notifications, description=To set which notification would be sent to association group 3, defaultValue=1], ConfigDescriptionParameter [name=config_82_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=82: Group 4 notifications, description=To set which notification would be sent to association group 4, defaultValue=1], ConfigDescriptionParameter [name=config_90_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=90: Enables/disables parameter 91 and 92 below:, description=Enables/disables parameter 91 and 92 below:, defaultValue=0], ConfigDescriptionParameter [name=config_91_2, type=INTEGER, groupName=configuration, min=0, max=60000, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=91: Set the threshold value of wattage., description=Set the threshold value of wattage., defaultValue=25], ConfigDescriptionParameter [name=config_92_1, type=INTEGER, groupName=configuration, min=0, max=100, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=92: Set the threshold value of wattage., description=Set the threshold value of wattage., defaultValue=5], ConfigDescriptionParameter [name=config_101_4, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=101: Set group 1 reports, description=To set which reports need to be sent in Report group 1, defaultValue=0], ConfigDescriptionParameter [name=config_102_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=102: To set which reports need to be sent in Report group 2., description=To set which reports need to be sent in Report group 2., defaultValue=0], ConfigDescriptionParameter [name=config_103_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=103: To set which reports need to be sent in Report group 3, description=To set which reports need to be sent in Report group 3., defaultValue=0], ConfigDescriptionParameter [name=config_111_4, type=INTEGER, groupName=configuration, min=1, max=2147483647, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=111: Set the interval of automatic report for Report group 1., description=Set the interval of automatic report for Report group 1., defaultValue=10], ConfigDescriptionParameter [name=config_112_4, type=INTEGER, groupName=configuration, min=1, max=2147483647, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=112: Set the interval of automatic report for Report group 2, description=Set the interval of automatic report for Report group 2., defaultValue=600], ConfigDescriptionParameter [name=config_113_4, type=INTEGER, groupName=configuration, min=1, max=2147483647, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=113: Set the interval of automatic report for Report group 2., description=Set the interval of automatic report for Report group 2., defaultValue=600], ConfigDescriptionParameter [name=config_120_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=120: Configure the external switch mode for S1, description=Configure the external switch mode for S1, defaultValue=0], ConfigDescriptionParameter [name=config_121_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=121: Configure the external switch mode for S2., description=Configure the external switch mode for S2., defaultValue=0], ConfigDescriptionParameter [name=config_122_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=122: Set the control destination for external switch, description=Set the control destination for external switch, defaultValue=3], ConfigDescriptionParameter [name=config_252_1, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=252: Lock/unlock configuration parameters, description=Lock/unlock configuration parameters, defaultValue=0], ConfigDescriptionParameter [name=config_255_4, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=255: Reset the Dual Nano Switch, description=Reset the Dual Nano Switch, defaultValue=0], ConfigDescriptionParameter [name=config_100_1_wo, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=100: Set parameter 101-103 to default value, description=Reset the parameter 101-103, defaultValue=0], ConfigDescriptionParameter [name=config_110_1_wo, type=INTEGER, groupName=configuration, readOnly=false, required=false, verify=false, multiple=false, multipleLimit=null, label=110: Set parameter 111-113 to default value., description=Set parameter 111-113 to default value., defaultValue=0], ConfigDescriptionParameter [name=group_1, type=TEXT, groupName=association, readOnly=false, required=false, verify=false, multiple=true, multipleLimit=5, label=1: Lifeline, description=When the load state of Dual Nano Switch (turn on/off the load) is changed, the Hail CC and Basic Report (configured by parameter 80) can be sent to the associated nodes in this group.], ConfigDescriptionParameter [name=group_2, type=TEXT, groupName=association, readOnly=false, required=false, verify=false, multiple=true, multipleLimit=5, label=2: Forward the Basic Set, description=Switch All, Scene Activation Set to associated nodes in Group 2 when the Dual Nano Switch receives the Basic Set, Switch All, Scene Activation Set commands from main controller. (E.g. Send/forward Basic Set to control the other nodes in association Group], ConfigDescriptionParameter [name=group_3, type=TEXT, groupName=association, readOnly=false, required=false, verify=false, multiple=true, multipleLimit=5, label=3: Send Basic Set, description=(configured by parameter 0x51 ) to the associated nodes in Group 3 when the external switch S1 is operated. Note: The Switch Mode of external switch S1 should be identified successfully, which means that the value of Configuration parameter 0x78 should be], ConfigDescriptionParameter [name=group_4, type=TEXT, groupName=association, readOnly=false, required=false, verify=false, multiple=true, multipleLimit=5, label=4: Send Basic Set, description=Send Basic Set (configured by parameter 0x52) to the associated nodes in Group 4 when the external switch S2 is operated. Note: The Switch Mode of external switch S2 should be identified successfully, which means that the value of Configuration parameter]], groups=[ConfigDescriptionParameterGroup [groupId="configuration", context="setup", advanced="false", label="Configuration Parameters", description="null"], ConfigDescriptionParameterGroup [groupId="actions", context="setup", advanced="false", label="Actions", description="null"], ConfigDescriptionParameterGroup [groupId="association", context="link", advanced="false", label="Association Groups", description="null"]]]]!**
**version             : 1.4.7**
**	at org.eclipse.smarthome.config.xml.util.NodeIterator.assertEndOfType(NodeIterator.java:81)[98:org.eclipse.smarthome.config.xml:0.9.0.b5]**
Not really - you need to use the latest version. I would double check that this is the case.
You can try opening the JAR to see if the database file for your device is there, and if it really contains these values. Certainly the version on Github contains them, and I’m pretty confident that it should be detected.
Please can you format it so it’s readable?
not sure how to reformat. I will have to do some research
Use code fences - something like ```xml on the beginning and just the 3 dashes at the end should do.
thanks heaps, I have modified it now. look up
What version of OH are you using?
its 2.1.0 according to karaf. i downladed it last month
Time to upgrade to something newer - 2.2 has been out for 4 months…
not sure how this happened. i only got it recently. i will try this tonight. thanks alot for your help
problem solved!! if that 2.2 has been out for 4 month I seriously dont know how I got 2.1
thanks so much for your help Chris!
I had ZW132 Dual Nano Switch with the following ID. Please help
0086:0003:0084:1.4
I’ve updated the database. I’ll do a binding update tonight or tomorrow.
