Hello Everybody,
I started with Z-Wave a few days (weeks) ago. I am using HABmin to configure my network.
I have a
- Raspberry Pi 3
- UZB (Controller)
- 3 Popp Smoke detectors
- 1 Greenwave power node
- 1 Cyrus 4in1 sensor
The 3 smoke sensores and the Greenwave power node are working probperly.
1 smoke detector is using the power node as repeater.
The Cyrus 4in1 sensor is working good if it is in the range of my UZB-Stick (node1).
If it is outside of range of node1 it should make a connection over my power switch (node2).
But this seems that it is not working.
I already healed the network (in the night) i synchronized … nothing happend.
If I put back the Cyrus next to my UZB-Stick (node1) everything is working. But if I have a look on the Network viewer the connection lines are red (node11 --> node6, node11 -->node1).?
Does anybody has some tipps or ecplenations to this? What can I do that my cyrus is using the power switch as repeater?
Thanks so far.
Nice greetings
Gerhard
