Dear all
I cant change parameters of Z-Wave Node 6: ZW100 MultiSensor 6 cant save parameters from PaperUI.
I see them, I can change them, but save button is not active. Please help.
I need to use this sensor to turn on the light when it is motion and it is dark (common thing). It works good when it is motion, but light information update only once in 3600 sec. It is stupid thing, because if light was turned on 1 h ago, my light will not, work, because it think that there are some luxes, but really it is fully dark.
May be this can help?
2017-03-11 00:15:13.643 [ERROR] [ding.zwave.handler.ZWaveThingHandler] - NODE 6: Size error 4<>1 from config_255_4_wo
2017-03-11 00:15:13.651 [ERROR] [ding.zwave.handler.ZWaveThingHandler] - NODE 12: Size error 4<>1 from config_255_4_wo
How I can check a firmware version of sensor and how to upgrade or change it to be compatible?
I would suggest to try HABmin to see if that works.
This error doesn’t matter.
Check the attributes for the firmware version -:
I saved parameters by Habmin 2, but it takes more than 2 houres before pending finished. Firmware version was 1.7. It is strange - because my device was in wakeup for 10 minutes mode, but dont save parameters.
If one know - what means parameter:
5 (0x05) Which command would be sent when the motion sensor triggered.
1 = send Basic Set CC.
2 = send Sensor Binary Report CC.
Also, my Habmin on server did not work. But it is another question Habmin not working ((
Now I can use it on my notebook only to configure ZWAVE
