hibeck
(Henrik Beck)
January 10, 2017, 11:13pm
1
Hello, I am trying to get my first z-wave thing to work in openHAB2, but I am having some issues with the Initialisation-process. It keeps trying to complete the initialisation but halts on:
“NODE 2: Node advancer: Retries exceeded at STATIC_VALUES” if I look in the openhab.log-file.
I am not sure if I am during something wrong, or my z-wave thing just doesn’t work in openHAB?
Info from HABmin about the device :
Manufacturer 0099 GreenWave Reality Inc.
Type / ID 0003:0004
Firmware Version4.20
Basic ClassROUTING_SLAVE
Generic ClassBINARY_SWITCH
Specific ClassPOWER_SWITCH_BINARY
Using Security
Routing
Listening
Frequently Listening
Beaming
Neighbours 1 nodes 1
openhab.log with DEBUG from z-wave:
Shared with Dropbox
I have been searching around for a couple of evenings now and I can’t seem to figure it out, so I hope someone can help
Hi, I’ve got the same problem with this Greenwave GWPN6 device and Openhab2, i won’t get initialized:
2017-01-16 18:12:15.325 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer - STATIC_VALUES: Transaction complete (SendData:Request) success(true)
2017-01-16 18:12:15.325 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer - checking initialisation queue. Queue size 1.
2017-01-16 18:12:15.326 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer - message removed from queue. Queue size 0.
2017-01-16 18:12:15.327 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer - STATIC_VALUES: queue length(0), free to send(true)
2017-01-16 18:12:15.327 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Initialisation retry timer started 1800000
2017-01-16 18:12:15.328 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-16 18:12:15.328 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Retry timout: Can’t advance
2017-01-16 18:12:15.329 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2017-01-16 18:12:15.330 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 13: Response processed after 60ms/4888ms.
2017-01-16 18:12:36.393 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 13: Transaction not completed: node address inconsistent. lastSent=13, incoming=255
2017-01-16 18:12:36.917 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 13: Transaction not completed: node address inconsistent. lastSent=13, incoming=255
2017-01-16 18:12:37.978 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 13: Transaction not completed: node address inconsistent. lastSent=13, incoming=255
2017-01-16 18:12:38.176 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 13: Transaction not completed: node address inconsistent. lastSent=13, incoming=255
2017-01-16 18:13:37.923 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 13: Transaction not completed: node address inconsistent. lastSent=13, incoming=255
2017-01-16 18:13:38.604 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 13: Transaction not completed: node address inconsistent. lastSent=13, incoming=255
2017-01-16 18:13:39.585 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 13: Transaction not completed: node address inconsistent. lastSent=13, incoming=255
2017-01-16 18:13:39.863 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 13: Transaction not completed: node address inconsistent. lastSent=13, incoming=255
2017-01-16 18:13:52.673 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 13: Transaction not completed: node address inconsistent. lastSent=13, incoming=255
2017-01-16 18:13:54.266 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 13: Transaction not completed: node address inconsistent. lastSent=13, incoming=255
2017-01-16 18:14:02.267 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 13: Transaction not completed: node address inconsistent. lastSent=13, incoming=255
2017-01-16 18:42:17.583 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-16 19:12:19.962 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-16 19:42:25.608 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 13: Timeout while sending message. Requeueing - 2 attempts left!
2017-01-16 19:42:25.612 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 13: Got an error while sending data. Resending message.
2017-01-16 19:42:27.752 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-16 20:12:30.222 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-16 20:42:32.736 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-16 21:12:35.041 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-16 21:42:37.433 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-16 22:12:39.835 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-16 22:42:42.298 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-16 23:12:44.534 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-16 23:42:46.902 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-17 00:12:49.263 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-17 00:42:51.629 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-17 01:12:53.979 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-17 01:42:56.429 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-17 02:12:58.842 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-17 02:43:01.324 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-17 03:13:03.727 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-17 03:43:06.071 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-17 04:13:08.479 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-17 04:43:10.851 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 13: Node advancer: Retries exceeded at STATIC_VALUES
2017-01-17 05:13:17.207 [ERROR] [ocol.ZWaveController$ZWaveSendThread] - NODE 13: Timeout while sending message. Requeueing - 2 attempts left!
2017-01-17 05:13:17.212 [ERROR] [l.serialmessage.SendDataMessageClass] - NODE 13: Got an error while sending data. Resending message.
What can I do to solve this?
Tomek
(Tomek)
January 20, 2017, 11:10am
3
Hi Frank
Did You find any solusion ?
Regards
No solution found…
@chris how can we troubleshoot this device? The device worked in version 1.8.?..
Regards,
Frank
chris
(Chris Jackson)
January 21, 2017, 1:18pm
5
These devices have some bugs. The fix for this that was used in OH1 had to be removed as it’s not compatible with the latest ZWave spec. There’s an open PR to fix this but it’s waiting changes from the author - this might solve the problem. I’ll have a look at this next week.
chris
(Chris Jackson)
January 27, 2017, 7:42pm
6
I’ve merged some changes yesterday that may (or not!) help with this. The issue appears to be endpoint related, so hopefully the following change will resolve this issue - if not, please provide a new log.
Additionally, from one of the logs above I found another bug that only shows up because of this devices bug ;). This is just merged so I’d suggest to try the snapshot from tonight (I’ve just kicked off a build).
I am experiencing the same problem with the same device. I am running the release version of openhab2. Does that include the mentioned updates, or will I have to run a snapshot version?
From the log:
2017-04-29 09:35:34.573 [ERROR] [alization.ZWaveNodeInitStageAdvancer] - NODE 2: Node advancer: Retries exceeded at STATIC_VALUES
Thanks,
Andreas
chris
(Chris Jackson)
April 29, 2017, 8:34am
9
It looks like this was merged after the release version was released.
Ok, I will try the snapshot then. Thanks.
