Hi all,
I have always struggled with zwave, and testing every zwave update that @chris was making. After opening a ticket i found out that i had some “spamming” devices. All my Nodon Smart Plug was sending msg with 10-100 in the secound and i had 6 devices witch make my light have a delay of 10-30 sec. After removing the Nodon everything works smoother. I have tried to do the setting to disable the noice without any luck. To bad to just trash them. Do anyone use them? Is there something wrong with the xml.file for this device?
Same error on 2.4 and 2.5 m1
My settings:
Exemple of the noice. This device is not connected to anything at this moment.
tail -f /var/log/openhab2/openhab.log /var/log/openhab2/events.log
2019-03-16 10:32:21.622 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:23.861 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:24.554 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:25.075 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:25.426 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:25.532 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:25.692 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:26.641 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:26.731 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:27.574 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:27.958 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:29.578 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:29.629 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:34.815 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:34.975 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:35.011 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:35.209 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:35.263 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:35.460 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:35.513 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:35.716 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:35.773 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:35.966 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:36.014 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:36.217 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:36.264 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:36.461 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:36.516 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:36.737 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:36.784 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:36.959 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:37.016 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:37.208 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:37.264 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:37.460 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:37.511 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:37.725 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:37.771 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:37.956 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:38.009 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:38.209 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:38.259 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:38.459 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:38.509 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:38.718 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:38.771 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:38.961 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:39.010 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:39.209 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:39.262 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:39.500 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:40.672 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:40.699 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:41.900 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:41.940 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:43.083 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
2019-03-16 10:32:43.118 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 62: Updating channel state zwave:device:512:node62:meter_kwh to 947.944 [DecimalType]
