Z-Wave not found errors
Using Z-Wave binding started. Version 2.1.0.201704232237. All devices are included and no broken links, but when I try to turn on a fan or lock a door I get a not found error:
2017-05-15 11:56:12.580 [ZWaveThingHandler         ] - NODE 43: Command received zwave:ge_zw4002_00_000:controller:node43:switch_dimmer --> 68
2017-05-15 11:56:12.581 [eMultiLevelSwitchConverter] - NODE 43: Command class SWITCH_MULTILEVEL not found when processing command on endpoint 0
2017-05-15 11:56:12.581 [ZWaveThingHandler         ] - NODE 43: No messages returned from converter
2017-05-15 11:57:01.292 [ZWaveThingHandler         ] - NODE 54: Command received zwave:yale_yrd220_00_000:controller:node54:lock_door --> ON
2017-05-15 11:57:01.293 [ZWaveDoorLockConverter    ] - NODE 54: Command class COMMAND_CLASS_DOOR_LOCK not found
2017-05-15 11:57:01.293 [ZWaveThingHandler         ] - NODE 54: No messages returned from converter
