Hi
I’ve migrate from OH2 to OH3 and made a fresh installation on it. All works fine, except z-wave. I see the controller online and also discover all nodes. But when I switch the state of an item, nothing happens and also I receive no data from nodes. This on all my arround 50 nodes.
And also the network map is empty.
On OH2 (same hardware) has all worked fine.
I use Aeotech zStick GEN5.
In the log I see only:
2022-07-27 16:15:02.302 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2022-07-27 16:15:02.306 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2022-07-27 16:15:05.294 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 42: Not initialized (ie node unknown), ignoring message.
2022-07-27 16:15:07.930 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 40: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:15:08.000 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 24: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:15:08.140 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 27: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:15:08.122 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 21: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:15:08.159 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 25: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:15:08.212 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 53: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:15:08.272 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 11: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:15:08.344 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 51: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:15:08.344 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 44: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:15:08.394 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 45: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:15:08.370 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 39: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:15:08.373 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 19: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:15:08.366 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 52: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:15:08.360 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 26: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:15:08.521 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 28: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:15:09.325 [WARN ] [nal.protocol.ZWaveTransactionManager] - NODE 3: Not initialized (ie node unknown), ignoring message.
2022-07-27 16:19:13.392 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 52: Device discovery could not resolve to a thingType! Manufacturer data not known.
2022-07-27 16:20:59.819 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 44: Device discovery could not resolve to a thingType! Manufacturer data not known.
2022-07-27 16:21:56.090 [INFO ] [ng.zwave.internal.protocol.ZWaveNode] - NODE 55: Maximum Awake time period reached, state DYNAMIC_VALUES count 20, messages 1
2022-07-27 16:25:07.134 [INFO ] [ve.internal.protocol.ZWaveController] - Starting ZWave controller
2022-07-27 16:25:07.138 [INFO ] [ve.internal.protocol.ZWaveController] - ZWave timeout is set to 5000ms. Soft reset is false.
2022-07-27 16:25:10.964 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 11: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:25:11.253 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 24: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:25:11.266 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 21: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:25:11.342 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 19: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:25:11.456 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 27: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:25:11.497 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 53: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:25:11.539 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 25: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:25:11.522 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 26: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:25:11.726 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 40: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:25:11.815 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 28: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:25:11.849 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 44: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:25:11.861 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 51: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:25:11.884 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 52: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:25:11.899 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 39: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:25:11.949 [WARN ] [ve.internal.protocol.ZWaveController] - NODE 45: Restore from config: Error. Data invalid, ignoring config.
2022-07-27 16:31:39.435 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 51: Device discovery could not resolve to a thingType! Manufacturer data not known.
2022-07-27 16:33:48.793 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 40: Device discovery could not resolve to a thingType! Manufacturer data not known.
2022-07-27 16:34:28.444 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 44: Device discovery could not resolve to a thingType! Manufacturer data not known.
2022-07-27 16:37:00.006 [INFO ] [ng.zwave.internal.protocol.ZWaveNode] - NODE 55: Maximum Awake time period reached, state REQUEST_NIF count 20, messages 1
2022-07-27 16:37:10.780 [INFO ] [ng.zwave.internal.protocol.ZWaveNode] - NODE 55: Maximum Awake time period reached, state DYNAMIC_VALUES count 20, messages 1
2022-07-27 16:37:19.383 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 28: Device discovery could not resolve to a thingType! Manufacturer data not known.
2022-07-27 16:38:48.799 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 39: Device discovery could not resolve to a thingType! Manufacturer data not known.
2022-07-27 16:42:42.750 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 45: Device discovery could not resolve to a thingType! Manufacturer data not known.
2022-07-27 16:46:20.993 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 24: Device discovery could not resolve to a thingType! Manufacturer data not known.
2022-07-27 16:48:08.486 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 21: Device discovery could not resolve to a thingType! Manufacturer data not known.
2022-07-27 16:50:44.530 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 53: Device discovery could not resolve to a thingType! Manufacturer data not known.
2022-07-27 16:51:57.488 [INFO ] [ng.zwave.internal.protocol.ZWaveNode] - NODE 55: Maximum Awake time period reached, state DYNAMIC_VALUES count 20, messages 1
2022-07-27 16:54:25.790 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 52: Device discovery could not resolve to a thingType! Manufacturer data not known.
2022-07-27 16:56:10.962 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 27: Device discovery could not resolve to a thingType! Manufacturer data not known.
2022-07-27 17:00:09.570 [WARN ] [wave.discovery.ZWaveDiscoveryService] - NODE 19: Device discovery could not resolve to a thingType! Manufacturer data not known.
And on event log:
2022-07-27 16:25:12.812 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:serial_zstick:71512f5b78' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:12.839 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node56' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:12.857 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node9' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:12.873 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node3' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:12.896 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node10' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:12.902 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node2' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:12.920 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node5' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:12.927 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node6' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:12.935 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node12' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:12.944 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node6' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:12.954 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node7' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:12.962 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node32' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:12.971 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node49' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:12.977 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node43' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:12.984 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node8' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:12.994 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node38' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:12.999 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node47' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:13.005 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node30' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:13.016 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node17' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:13.021 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node12' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.058 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node46' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:13.069 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node8' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.095 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node48' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:13.101 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node42' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:13.122 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node18' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:13.135 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node29' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:13.141 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node57' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:13.166 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node10' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.199 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node35' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:13.211 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node30' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.252 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node36' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:13.269 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node15' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:13.276 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node37' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:13.298 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node36' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.320 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node34' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:13.343 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node54' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:13.350 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node31' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:13.362 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node33' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:13.369 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node42' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.375 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node57' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.382 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node55' changed from OFFLINE (BRIDGE_OFFLINE): Controller is offline to ONLINE
2022-07-27 16:25:13.388 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node17' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.398 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node31' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.404 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node9' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.426 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node2' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.446 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node37' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.452 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node5' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.477 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node7' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.494 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node48' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.501 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node35' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.513 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node49' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.532 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node38' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.545 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node47' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.550 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node18' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.556 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node29' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.578 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node43' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.583 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node33' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.603 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node55' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2022-07-27 16:25:13.609 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node32' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.627 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node56' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.634 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node34' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:25:13.654 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node15' changed from ONLINE to ONLINE: Node initialising: PING
2022-07-27 16:34:54.301 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node6' changed from ONLINE: Node initialising: PING to ONLINE: Node initialising: REQUEST_NIF
2022-07-27 16:34:54.352 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node46' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2022-07-27 16:35:21.298 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node6' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2022-07-27 16:35:21.463 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node12' changed from ONLINE: Node initialising: PING to ONLINE: Node initialising: REQUEST_NIF
2022-07-27 16:35:22.021 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node46' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2022-07-27 16:35:38.303 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node12' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2022-07-27 16:36:21.269 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node8' changed from ONLINE: Node initialising: PING to ONLINE: Node initialising: REQUEST_NIF
2022-07-27 16:39:13.775 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node8' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2022-07-27 16:39:13.787 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node10' changed from ONLINE: Node initialising: PING to ONLINE: Node initialising: REQUEST_NIF
2022-07-27 16:39:13.814 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node54' changed from ONLINE to ONLINE: Node initialising: REQUEST_NIF
2022-07-27 16:39:14.147 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node10' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2022-07-27 16:39:14.197 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node30' changed from ONLINE: Node initialising: PING to ONLINE: Node initialising: REQUEST_NIF
2022-07-27 16:39:14.541 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node54' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2022-07-27 16:39:14.606 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node36' changed from ONLINE: Node initialising: PING to ONLINE: Node initialising: REQUEST_NIF
2022-07-27 16:39:14.667 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node30' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2022-07-27 16:39:14.921 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node42' changed from ONLINE: Node initialising: PING to ONLINE: Node initialising: REQUEST_NIF
2022-07-27 16:39:39.648 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node42' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
2022-07-27 16:39:39.952 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node57' changed from ONLINE: Node initialising: PING to ONLINE: Node initialising: REQUEST_NIF
2022-07-27 16:39:40.536 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zwave:device:71512f5b78:node36' changed from ONLINE: Node initialising: REQUEST_NIF to ONLINE
My system info:
runtimeInfo:
version: 3.3.0
buildString: Release Build
locale: de-CH
systemInfo:
configFolder: /etc/openhab
userdataFolder: /var/lib/openhab
logFolder: /var/log/openhab
javaVersion: 11.0.16
javaVendor: Debian
osName: Linux
osVersion: 5.15.32-v8+
osArchitecture: aarch64
availableProcessors: 4
freeMemory: 65441744
totalMemory: 194838528
startLevel: 100
bindings:
- astro
- gree
- mqtt
- shelly
- zwave
Thanks for your help.
