Z-Wave on 4.3.2 - Potential Issue?
I’m going to preface this by saying I have no logs to back this up because I wasn’t willing to use my house to test the issue I was seeing. However, I will relate my overall system performance:
  1. After updating from 4.3.1 → 4.3.2, I noticed a significant degradation in Z-Wave performance. Rules that sent messages to multiple devices, such as turning out all the lights on the 2nd floor, usually would turn out everything within a few seconds. After the update, it would take minutes or longer before the first light turned off.
  2. I have a Schlange Z-Wave lock on my front door. The battery had been reporting at 71% when it gave a sudden low-battery warning and stopped functioning. The batteries were so drained that it was immediately dead. I’ve never had that happen before. After swapping out the batteries, I suddenly had them die again just 48 hours later. A battery tester confirmed the batteries were dead.
The door lock, with the performance of the z-wave mesh, is what made me think that my controller was suddenly being overly chatty with my devices. I decided to roll back to 4.3.1 and suddenly the z-wave performance is back to normal. The front door lock seems to be the only battery device that was negatively impacted by this…none of my other battery powered devices are dead.
Not sure what anyone can do with this information without more details but I didn’t know if maybe anyone else was seeing strange behavior.
From a quick review, there have been no changes to the zwave binding (except changing the label (4.3.0 -->4.3.1 -->4.3.2) since OH4.3.0, so there is nothing to suspect without logs.
This is a snippet from last week:
2025-01-30 22:24:14.686 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 41659 to 41660
2025-01-30 22:24:15.304 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 41660 to 41661
2025-01-30 22:24:15.430 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 41661 to 41662
2025-01-30 22:24:15.533 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 41662 to 41663
2025-01-30 22:24:15.896 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 41663 to 41664
2025-01-30 22:24:15.942 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 41664 to 41665
2025-01-30 22:24:16.022 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 41665 to 41666
2025-01-30 22:24:16.094 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 41666 to 41667
2025-01-30 22:24:16.272 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 41667 to 41668
2025-01-30 22:24:16.333 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 41668 to 41669
2025-01-30 22:24:16.629 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 41669 to 41670
2025-01-30 22:24:17.006 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 41670 to 41671
2025-01-30 22:24:17.025 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 41671 to 41672
2025-01-30 22:24:19.153 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 41672 to 41673
2025-01-30 22:24:19.447 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 41673 to 41674
2025-01-30 22:24:19.652 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 41674 to 41675
2025-01-30 22:24:19.877 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 41675 to 41676
This is a similar snippet from today:
2025-02-05 10:23:46.388 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 1722 to 1723
2025-02-05 10:23:46.394 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5235 to 5236
2025-02-05 10:23:46.577 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5236 to 5237
2025-02-05 10:23:46.648 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5237 to 5238
2025-02-05 10:23:46.651 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 1723 to 1724
2025-02-05 10:23:46.657 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5238 to 5239
2025-02-05 10:23:46.816 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5239 to 5240
2025-02-05 10:23:46.899 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5240 to 5241
2025-02-05 10:23:46.903 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 1724 to 1725
2025-02-05 10:23:46.909 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5241 to 5242
2025-02-05 10:23:47.065 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5242 to 5243
2025-02-05 10:23:47.149 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5243 to 5244
2025-02-05 10:23:47.151 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 1725 to 1726
2025-02-05 10:23:47.159 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5244 to 5245
2025-02-05 10:23:47.314 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5245 to 5246
2025-02-05 10:23:47.399 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5246 to 5247
2025-02-05 10:23:47.402 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 1726 to 1727
2025-02-05 10:23:47.409 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5247 to 5248
2025-02-05 10:23:47.548 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5248 to 5249
2025-02-05 10:23:47.631 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5249 to 5250
2025-02-05 10:23:47.633 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 1727 to 1728
2025-02-05 10:23:47.640 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5250 to 5251
2025-02-05 10:23:47.836 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5251 to 5252
2025-02-05 10:23:47.917 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5252 to 5253
2025-02-05 10:23:47.921 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 1728 to 1729
2025-02-05 10:23:47.928 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5253 to 5254
2025-02-05 10:23:48.058 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5254 to 5255
2025-02-05 10:23:48.138 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5255 to 5256
2025-02-05 10:23:48.141 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_FramesAcknowledged' changed from 1729 to 1730
2025-02-05 10:23:48.149 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5256 to 5257
2025-02-05 10:23:48.279 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5257 to 5258
2025-02-05 10:23:48.358 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item 'ZWaveSerialController_StartFrames' changed from 5258 to 5259
Honestly, while they are slightly different I’m not sure if either of these indicate I should adjust anything on the controller itself. It does seem to have a lot of ItemStateChangedEvents and I don’t know if there’s a way to turn that down.
I don’t usually look at these serial communication items (or have them linked), but on general ZW principals the missing FramesAcknowledged is a concern. It means that the controller on the serial port is not acknowledging messages sent from the binding on the server (at least in a time period shown). Nothing good can happen. In the future you could try a restart of the ZW binding, OH or lastly the server (in that order) to see if any of that helps clear up/reset the connection
Interestingly, the missing FramesAcknowledged was happening on 4.3.2 and returned after 4.3.1. In your opinion, would I be better off removing those items though?
As it stands now, I’m not going to upgrade to 4.3.2 for now because I don’t have time to troubleshoot this issue and I don’t want to get locked out of my house (that almost happened because of the dead battery :sweat_smile: )
