- Platform information:
- OS: Debian 9.4 64-bit
- Java Runtime Environment: openjdk version “1.8.0_181” OpenJDK Runtime Environment (build 1.8.0_181-8u181-b13-1~deb9u1-b13)
- openHAB version: 2.3.0
- z-wave version: 2.4.0.201809081506
- z-wave controller: aeotec gen5
HI all,
Some time has passed and I have been happy with my OH install. Z-wave started working after installing the 2.4 version. Thanks Chris and everyone who works with this!
But since then I’ve extended the network with a multisensor (MH9-CO2-WD CO2 Monitor Air quality detector) and everything worked nicely until the sensor stoped reporting values. I cant understand by the logs what the problem is. Can someone point me in the right direction? The sensor is Node 6.
It all goes south after the healing of the network. The log starts with the last value update from the sensor. After this its all “NODE 6: Polling deferred until initialisation complete”
Thanks!
Log;
13-Nov-2018 23:59:15.839 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
13-Nov-2018 23:59:15.839 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
14-Nov-2018 00:01:11.682 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 06 06 31 05 11 02 03 36 E5
14-Nov-2018 00:01:11.683 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=6, callback=0, payload=00 06 06 31 05 11 02 03 36
14-Nov-2018 00:01:11.684 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=ApplicationCommandHandler[4], type=Request[0], dest=6, callback=0, payload=00 06 06 31 05 11 02 03 36
14-Nov-2018 00:01:11.685 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=6, callback=0, payload=00 06 06 31 05 11 02 03 36
14-Nov-2018 00:01:11.685 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
14-Nov-2018 00:01:11.685 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 6: Application Command Request (ALIVE:DONE)
14-Nov-2018 00:01:11.685 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 6: resetResendCount initComplete=true isDead=false
14-Nov-2018 00:01:11.685 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 6: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
14-Nov-2018 00:01:11.685 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 6: SECURITY not supported
14-Nov-2018 00:01:11.685 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 6: Received COMMAND_CLASS_SENSOR_MULTILEVEL V5 SENSOR_MULTILEVEL_REPORT
14-Nov-2018 00:01:11.686 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 6: Sensor Type = CO2(17), Scale = 0
14-Nov-2018 00:01:11.686 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 6: Sensor Value = 822
14-Nov-2018 00:01:11.686 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
14-Nov-2018 00:01:11.686 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SENSOR_MULTILEVEL, value = 822
14-Nov-2018 00:01:11.686 [DEBUG] [.internal.converter.ZWaveMultiLevelSensorConverter] - NODE 6: Sensor conversion not performed for CO2.
14-Nov-2018 00:01:11.686 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Updating channel state zwave:device:dd005807:node6:sensor_co2 to 822 [DecimalType]
14-Nov-2018 00:01:11.689 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 6: Commands processed 1.
14-Nov-2018 00:01:11.689 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 6: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@7503f96c.
14-Nov-2018 00:01:11.690 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
14-Nov-2018 00:01:11.691 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
14-Nov-2018 00:01:11.691 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
14-Nov-2018 00:27:01.928 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling...
14-Nov-2018 00:27:01.928 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling zwave:device:dd005807:node2:switch_binary
14-Nov-2018 00:27:01.928 [DEBUG] [wave.internal.converter.ZWaveBinarySwitchConverter] - NODE 2: Generating poll message for COMMAND_CLASS_SWITCH_BINARY, endpoint 0
14-Nov-2018 00:27:01.928 [DEBUG] [rotocol.commandclass.ZWaveBinarySwitchCommandClass] - NODE 2: Creating new message for application command SWITCH_BINARY_GET
14-Nov-2018 00:27:01.929 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 2: SECURITY not supported
14-Nov-2018 00:27:01.929 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 2: Command Class COMMAND_CLASS_SWITCH_BINARY is NOT required to be secured
14-Nov-2018 00:27:01.929 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling skipped for zwave:device:dd005807:node2:switch_binary on COMMAND_CLASS_BASIC
14-Nov-2018 00:27:01.929 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: Adding to device queue
14-Nov-2018 00:27:01.929 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
14-Nov-2018 00:27:01.930 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 02 02 25 02 25 BF 58
14-Nov-2018 00:27:01.930 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 2: Sending REQUEST Message = 01 09 00 13 02 02 25 02 25 BF 58
14-Nov-2018 00:27:01.930 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Polling...
14-Nov-2018 00:27:01.930 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Polling zwave:device:dd005807:node4:switch_binary
14-Nov-2018 00:27:01.930 [DEBUG] [wave.internal.converter.ZWaveBinarySwitchConverter] - NODE 4: Generating poll message for COMMAND_CLASS_SWITCH_BINARY, endpoint 0
14-Nov-2018 00:27:01.931 [DEBUG] [rotocol.commandclass.ZWaveBinarySwitchCommandClass] - NODE 4: Creating new message for application command SWITCH_BINARY_GET
14-Nov-2018 00:27:01.931 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: SECURITY not supported
14-Nov-2018 00:27:01.931 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 4: Command Class COMMAND_CLASS_SWITCH_BINARY is NOT required to be secured
14-Nov-2018 00:27:01.931 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Polling skipped for zwave:device:dd005807:node4:switch_binary on COMMAND_CLASS_BASIC
14-Nov-2018 00:27:02.392 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - Message SENT
14-Nov-2018 00:27:02.392 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 206: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 191
14-Nov-2018 00:27:02.393 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Adding to device queue
14-Nov-2018 00:27:02.393 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
14-Nov-2018 00:27:04.394 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - NODE 2: TID 206: Timeout at state WAIT_RESPONSE. 3 retries remaining.
14-Nov-2018 00:27:04.394 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - Aborting Transaction!
14-Nov-2018 00:27:04.394 [DEBUG] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 206: Transaction ABORTED
14-Nov-2018 00:27:04.394 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 16 EA
14-Nov-2018 00:27:04.394 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 16 EA
14-Nov-2018 00:27:04.398 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - Message SENT
14-Nov-2018 00:27:04.398 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
14-Nov-2018 00:27:16.394 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - NODE 2: TID 206: Timeout at state ABORTED. 3 retries remaining.
14-Nov-2018 00:27:16.394 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - TID 206: Transaction is current transaction, so clearing!!!!!
14-Nov-2018 00:27:16.394 [DEBUG] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 206: Transaction CANCELLED
14-Nov-2018 00:27:16.394 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 2: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
14-Nov-2018 00:27:16.394 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 2: notifyTransactionResponse TID:206 CANCELLED
14-Nov-2018 00:27:16.395 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
14-Nov-2018 00:27:16.395 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 04 02 25 02 25 C0 21
14-Nov-2018 00:27:16.396 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 4: Sending REQUEST Message = 01 09 00 13 04 02 25 02 25 C0 21
14-Nov-2018 00:27:16.455 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - Message SENT
14-Nov-2018 00:27:16.455 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 207: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 192
14-Nov-2018 00:27:18.455 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - NODE 4: TID 207: Timeout at state WAIT_RESPONSE. 3 retries remaining.
14-Nov-2018 00:27:18.456 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - Aborting Transaction!
14-Nov-2018 00:27:18.457 [DEBUG] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 207: Transaction ABORTED
14-Nov-2018 00:27:18.457 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 16 EA
14-Nov-2018 00:27:18.458 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 16 EA
14-Nov-2018 00:27:18.463 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - Message SENT
14-Nov-2018 00:27:18.464 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
14-Nov-2018 00:27:27.040 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling...
14-Nov-2018 00:27:27.040 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling zwave:device:dd005807:node6:sensor_temperature
14-Nov-2018 00:27:27.040 [DEBUG] [.internal.converter.ZWaveMultiLevelSensorConverter] - NODE 6: Generating poll message for COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
14-Nov-2018 00:27:27.040 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 6: Creating new message for command SENSOR_MULTILEVEL_GET
14-Nov-2018 00:27:27.041 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 6: SECURITY not supported
14-Nov-2018 00:27:27.041 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 6: Command Class COMMAND_CLASS_SENSOR_MULTILEVEL is NOT required to be secured
14-Nov-2018 00:27:27.041 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling zwave:device:dd005807:node6:sensor_relhumidity
14-Nov-2018 00:27:27.041 [DEBUG] [.internal.converter.ZWaveMultiLevelSensorConverter] - NODE 6: Generating poll message for COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
14-Nov-2018 00:27:27.041 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 6: Creating new message for command SENSOR_MULTILEVEL_GET
14-Nov-2018 00:27:27.041 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling zwave:device:dd005807:node6:sensor_co2
14-Nov-2018 00:27:27.042 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 6: Creating new message for command SENSOR_MULTILEVEL_GET
14-Nov-2018 00:27:27.042 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 6: SECURITY not supported
14-Nov-2018 00:27:27.042 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 6: Command Class COMMAND_CLASS_SENSOR_MULTILEVEL is NOT required to be secured
14-Nov-2018 00:27:27.042 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 6: Adding to device queue
14-Nov-2018 00:27:27.042 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
14-Nov-2018 00:27:27.043 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
14-Nov-2018 00:27:30.457 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - NODE 4: TID 207: Timeout at state ABORTED. 3 retries remaining.
14-Nov-2018 00:27:30.457 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - TID 207: Transaction is current transaction, so clearing!!!!!
14-Nov-2018 00:27:30.458 [DEBUG] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 207: Transaction CANCELLED
14-Nov-2018 00:27:30.458 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
14-Nov-2018 00:27:30.458 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: notifyTransactionResponse TID:207 CANCELLED
14-Nov-2018 00:27:30.458 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
14-Nov-2018 00:27:30.459 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0B 00 13 06 04 31 04 01 00 25 C1 35
14-Nov-2018 00:27:30.459 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 6: Sending REQUEST Message = 01 0B 00 13 06 04 31 04 01 00 25 C1 35
14-Nov-2018 00:27:30.515 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - Message SENT
14-Nov-2018 00:27:30.516 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 208: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 193
14-Nov-2018 00:27:32.516 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - NODE 6: TID 208: Timeout at state WAIT_RESPONSE. 3 retries remaining.
14-Nov-2018 00:27:32.517 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - Aborting Transaction!
14-Nov-2018 00:27:32.518 [DEBUG] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 208: Transaction ABORTED
14-Nov-2018 00:27:32.518 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 16 EA
14-Nov-2018 00:27:32.519 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 16 EA
14-Nov-2018 00:27:32.520 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - Message SENT
14-Nov-2018 00:27:32.520 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
14-Nov-2018 00:27:44.518 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - NODE 6: TID 208: Timeout at state ABORTED. 3 retries remaining.
14-Nov-2018 00:27:44.518 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - TID 208: Transaction is current transaction, so clearing!!!!!
14-Nov-2018 00:27:44.519 [DEBUG] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 208: Transaction CANCELLED
14-Nov-2018 00:27:44.519 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
14-Nov-2018 00:27:44.519 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 6: notifyTransactionResponse TID:208 CANCELLED
14-Nov-2018 00:27:44.519 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
14-Nov-2018 00:27:44.520 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0B 00 13 06 04 31 04 05 00 25 C2 32
14-Nov-2018 00:27:44.520 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 6: Sending REQUEST Message = 01 0B 00 13 06 04 31 04 05 00 25 C2 32
14-Nov-2018 00:27:44.571 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - Message SENT
14-Nov-2018 00:27:44.572 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 209: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 194
14-Nov-2018 00:27:46.572 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - NODE 6: TID 209: Timeout at state WAIT_RESPONSE. 3 retries remaining.
14-Nov-2018 00:27:46.572 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - Aborting Transaction!
14-Nov-2018 00:27:46.572 [DEBUG] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 209: Transaction ABORTED
14-Nov-2018 00:27:46.573 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 16 EA
14-Nov-2018 00:27:46.573 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 16 EA
14-Nov-2018 00:27:46.576 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - Message SENT
14-Nov-2018 00:27:46.577 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
14-Nov-2018 00:27:58.572 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - NODE 6: TID 209: Timeout at state ABORTED. 3 retries remaining.
14-Nov-2018 00:27:58.572 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - TID 209: Transaction is current transaction, so clearing!!!!!
14-Nov-2018 00:27:58.572 [DEBUG] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 209: Transaction CANCELLED
14-Nov-2018 00:27:58.572 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
14-Nov-2018 00:27:58.572 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 6: notifyTransactionResponse TID:209 CANCELLED
14-Nov-2018 00:27:58.573 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
14-Nov-2018 00:27:58.573 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0B 00 13 06 04 31 04 11 00 25 C3 27
14-Nov-2018 00:27:58.574 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 6: Sending REQUEST Message = 01 0B 00 13 06 04 31 04 11 00 25 C3 27
14-Nov-2018 00:27:58.626 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - Message SENT
14-Nov-2018 00:27:58.626 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 210: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 195
14-Nov-2018 00:28:00.626 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - NODE 6: TID 210: Timeout at state WAIT_RESPONSE. 3 retries remaining.
14-Nov-2018 00:28:00.626 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - Aborting Transaction!
14-Nov-2018 00:28:00.626 [DEBUG] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 210: Transaction ABORTED
14-Nov-2018 00:28:00.626 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 16 EA
14-Nov-2018 00:28:00.626 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 16 EA
14-Nov-2018 00:28:00.628 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - Message SENT
14-Nov-2018 00:28:00.628 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
14-Nov-2018 00:28:12.626 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - NODE 6: TID 210: Timeout at state ABORTED. 3 retries remaining.
14-Nov-2018 00:28:12.627 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - TID 210: Transaction is current transaction, so clearing!!!!!
14-Nov-2018 00:28:12.627 [DEBUG] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 210: Transaction CANCELLED
14-Nov-2018 00:28:12.627 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
14-Nov-2018 00:28:12.627 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 6: notifyTransactionResponse TID:210 CANCELLED
14-Nov-2018 00:28:12.628 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
14-Nov-2018 00:29:15.252 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling...
14-Nov-2018 00:29:15.252 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling zwave:device:dd005807:node5:switch_dimmer
14-Nov-2018 00:29:15.252 [DEBUG] [.internal.converter.ZWaveMultiLevelSwitchConverter] - NODE 5: Generating poll message for COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 0
14-Nov-2018 00:29:15.253 [DEBUG] [col.commandclass.ZWaveMultiLevelSwitchCommandClass] - NODE 5: Creating new message for command SWITCH_MULTILEVEL_GET
14-Nov-2018 00:29:15.253 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
14-Nov-2018 00:29:15.253 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 5: Command Class COMMAND_CLASS_SWITCH_MULTILEVEL is NOT required to be secured
14-Nov-2018 00:29:15.253 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling skipped for zwave:device:dd005807:node5:switch_dimmer on COMMAND_CLASS_BASIC
14-Nov-2018 00:29:15.253 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 5: Adding to device queue
14-Nov-2018 00:29:15.253 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
14-Nov-2018 00:29:15.253 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 05 02 26 02 25 C4 27
14-Nov-2018 00:29:15.254 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 5: Sending REQUEST Message = 01 09 00 13 05 02 26 02 25 C4 27
14-Nov-2018 00:29:15.796 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - Message SENT
14-Nov-2018 00:29:15.797 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 211: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 196
14-Nov-2018 00:29:17.797 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - NODE 5: TID 211: Timeout at state WAIT_RESPONSE. 3 retries remaining.
14-Nov-2018 00:29:17.797 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - Aborting Transaction!
14-Nov-2018 00:29:17.798 [DEBUG] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 211: Transaction ABORTED
14-Nov-2018 00:29:17.798 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 03 00 16 EA
14-Nov-2018 00:29:17.798 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 03 00 16 EA
14-Nov-2018 00:29:17.801 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - Message SENT
14-Nov-2018 00:29:17.802 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
14-Nov-2018 00:29:29.798 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - NODE 5: TID 211: Timeout at state ABORTED. 3 retries remaining.
14-Nov-2018 00:29:29.799 [DEBUG] [ocol.ZWaveTransactionManager$ZWaveTransactionTimer] - TID 211: Transaction is current transaction, so clearing!!!!!
14-Nov-2018 00:29:29.799 [DEBUG] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 211: Transaction CANCELLED
