Here is a debug log from the polling of the switch. My first impression is that the different channels get polled, but all the meter polls return in scale kwh and thus, the same value. So it returns only the kwh and not the voltage, current or watts. How could that be?
Next to these debug messages, I don’t see any ThingUpdatedEvent that actually changes the OH-value, while at least the kwh-meter should update its channel, shouldn’t it?
01:40:12.458 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling...
01:40:12.458 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling zwave:device:153d3725a86:node5:meter_kwh
01:40:12.459 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 5: Generating poll message for METER, endpoint 0
01:40:12.460 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Creating new message for application command METER_GET
01:40:12.460 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling zwave:device:153d3725a86:node5:meter_current
01:40:12.461 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 5: Generating poll message for METER, endpoint 0
01:40:12.462 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 5: Generating poll message for METER, endpoint 0
01:40:12.462 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Creating new message for application command METER_GET
01:40:12.463 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling zwave:device:153d3725a86:node5:meter_voltage
01:40:12.463 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 5: Generating poll message for METER, endpoint 0
01:40:12.464 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Creating new message for application command METER_GET
01:40:12.464 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling zwave:device:153d3725a86:node5:meter_watts
01:40:12.464 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 5: Generating poll message for METER, endpoint 0
01:40:12.465 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 5: Generating poll message for METER, endpoint 0
01:40:12.465 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Creating new message for application command METER_GET
01:40:12.465 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling zwave:device:153d3725a86:node5:meter_reset
01:40:12.466 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 5: Generating poll message for METER, endpoint 0
01:40:12.466 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Creating new message for application command METER_GET
01:40:12.467 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling zwave:device:153d3725a86:node5:switch_binary
01:40:12.467 [DEBUG] [converter.ZWaveBinarySwitchConverter] - NODE 5: Generating poll message for SWITCH_BINARY, endpoint 0
01:40:12.468 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 5: Creating new message for application command SWITCH_BINARY_GET
01:40:12.468 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
01:40:12.469 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 2. Queue={}
01:40:12.469 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 1
01:40:12.470 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 3. Queue={}
01:40:12.470 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 4. Queue={}
01:40:12.470 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 05 02 32 01 25 E3 17
01:40:12.471 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 5. Queue={}
01:40:12.471 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 5: Sending REQUEST Message = 01 09 00 13 05 02 32 01 25 E3 17
01:40:12.480 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
01:40:12.481 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
01:40:12.482 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
01:40:12.483 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
01:40:12.484 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, payload=01
01:40:12.484 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: Sent Data successfully placed on stack.
01:40:12.498 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 E3 00 00 02 0A
01:40:12.500 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
01:40:12.502 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 E3 00 00 02 00 00 04
01:40:12.506 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 E3 00 00 02 00 00 04
01:40:12.510 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 04 00 05 12 32 02 21 64 00 00 01 42 00 1D 00 00 01 42 00 00 00 00 9C
01:40:12.511 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, payload=E3 00 00 02
01:40:12.512 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: SendData Request. CallBack ID = 227, Status = Transmission complete and ACK received(0)
01:40:12.513 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent message Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=5, payload=05 02 32 01
01:40:12.514 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv message Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, payload=E3 00 00 02
01:40:12.515 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=227, expected=ApplicationCommandHandler, cancelled=false MISMATCH
01:40:12.515 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
01:40:12.517 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 18 00 04 00 05 12 32 02 21 64 00 00 01 42 00 1D 00 00 01 42 00 00 00 00 9C
01:40:12.520 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 18 00 04 00 05 12 32 02 21 64 00 00 01 42 00 1D 00 00 01 42 00 00 00 00 9C
01:40:12.522 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, payload=00 05 12 32 02 21 64 00 00 01 42 00 1D 00 00 01 42 00 00 00 00
01:40:12.524 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE)
01:40:12.527 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Incoming command class METER
01:40:12.528 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Received Meter Request
01:40:12.529 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Meter: Type=Electric(1), Scale=kWh(0), Value=0.322, Delta=29
01:40:12.531 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMeterValueEvent
01:40:12.532 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent message Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=5, payload=05 02 32 01
01:40:12.534 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv message Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, payload=00 05 12 32 02 21 64 00 00 01 42 00 1D 00 00 01 42 00 00 00 00
01:40:12.534 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=227, expected=ApplicationCommandHandler, cancelled=false transaction complete!
01:40:12.535 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
01:40:12.537 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 5: Response processed after 65ms/4196ms.
01:40:12.538 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 4
01:40:12.542 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 05 02 32 01 25 E4 10
01:40:12.544 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 5: Sending REQUEST Message = 01 09 00 13 05 02 32 01 25 E4 10
01:40:12.556 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
01:40:12.558 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
01:40:12.559 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
01:40:12.559 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
01:40:12.560 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, payload=01
01:40:12.561 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: Sent Data successfully placed on stack.
01:40:12.570 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 E4 00 00 02 0D
01:40:12.572 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
01:40:12.576 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 E4 00 00 02 00 00 03
01:40:12.579 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 E4 00 00 02 00 00 03
01:40:12.582 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, payload=E4 00 00 02
01:40:12.584 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: SendData Request. CallBack ID = 228, Status = Transmission complete and ACK received(0)
01:40:12.585 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent message Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=5, payload=05 02 32 01
01:40:12.586 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv message Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, payload=E4 00 00 02
01:40:12.587 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 04 00 05 12 32 02 21 64 00 00 01 42 00 00 00 00 01 42 00 00 00 00 81
01:40:12.587 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=228, expected=ApplicationCommandHandler, cancelled=false MISMATCH
01:40:12.591 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
01:40:12.593 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 18 00 04 00 05 12 32 02 21 64 00 00 01 42 00 00 00 00 01 42 00 00 00 00 81
01:40:12.596 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 18 00 04 00 05 12 32 02 21 64 00 00 01 42 00 00 00 00 01 42 00 00 00 00 81
01:40:12.599 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, payload=00 05 12 32 02 21 64 00 00 01 42 00 00 00 00 01 42 00 00 00 00
01:40:12.601 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE)
01:40:12.602 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Incoming command class METER
01:40:12.604 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Received Meter Request
01:40:12.605 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Meter: Type=Electric(1), Scale=kWh(0), Value=0.322, Delta=0
01:40:12.606 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMeterValueEvent
01:40:12.607 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent message Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=5, payload=05 02 32 01
01:40:12.608 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv message Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, payload=00 05 12 32 02 21 64 00 00 01 42 00 00 00 00 01 42 00 00 00 00
01:40:12.609 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=228, expected=ApplicationCommandHandler, cancelled=false transaction complete!
01:40:12.609 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
01:40:12.609 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 5: Response processed after 64ms/4196ms.
01:40:12.610 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 3
01:40:12.611 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 05 02 32 01 25 E5 11
01:40:12.612 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 5: Sending REQUEST Message = 01 09 00 13 05 02 32 01 25 E5 11
01:40:12.621 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
01:40:12.624 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
01:40:12.625 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
01:40:12.626 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
01:40:12.627 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, payload=01
01:40:12.627 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: Sent Data successfully placed on stack.
01:40:12.636 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 E5 00 00 03 0D
01:40:12.640 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
01:40:12.641 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 E5 00 00 03 00 00 03
01:40:12.642 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 E5 00 00 03 00 00 03
01:40:12.642 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, payload=E5 00 00 03
01:40:12.643 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: SendData Request. CallBack ID = 229, Status = Transmission complete and ACK received(0)
01:40:12.644 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent message Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=5, payload=05 02 32 01
01:40:12.645 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv message Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, payload=E5 00 00 03
01:40:12.646 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=229, expected=ApplicationCommandHandler, cancelled=false MISMATCH
01:40:12.652 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 04 00 05 12 32 02 21 64 00 00 01 42 00 01 00 00 01 42 00 00 00 00 80
01:40:12.656 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
01:40:12.658 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 18 00 04 00 05 12 32 02 21 64 00 00 01 42 00 01 00 00 01 42 00 00 00 00 80
01:40:12.660 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 18 00 04 00 05 12 32 02 21 64 00 00 01 42 00 01 00 00 01 42 00 00 00 00 80
01:40:12.662 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, payload=00 05 12 32 02 21 64 00 00 01 42 00 01 00 00 01 42 00 00 00 00
01:40:12.663 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE)
01:40:12.664 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Incoming command class METER
01:40:12.665 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Received Meter Request
01:40:12.666 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Meter: Type=Electric(1), Scale=kWh(0), Value=0.322, Delta=1
01:40:12.667 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMeterValueEvent
01:40:12.669 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent message Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=5, payload=05 02 32 01
01:40:12.670 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv message Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, payload=00 05 12 32 02 21 64 00 00 01 42 00 01 00 00 01 42 00 00 00 00
01:40:12.671 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=229, expected=ApplicationCommandHandler, cancelled=false transaction complete!
01:40:12.671 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
01:40:12.672 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 5: Response processed after 59ms/4196ms.
01:40:12.672 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 2
01:40:12.673 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 05 02 32 01 25 E6 12
01:40:12.673 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 5: Sending REQUEST Message = 01 09 00 13 05 02 32 01 25 E6 12
01:40:12.684 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
01:40:12.685 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
01:40:12.686 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
01:40:12.687 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
01:40:12.689 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, payload=01
01:40:12.689 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: Sent Data successfully placed on stack.
01:40:12.698 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 E6 00 00 02 0F
01:40:12.701 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
01:40:12.703 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 E6 00 00 02 00 00 01
01:40:12.706 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 E6 00 00 02 00 00 01
01:40:12.708 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, payload=E6 00 00 02
01:40:12.710 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: SendData Request. CallBack ID = 230, Status = Transmission complete and ACK received(0)
01:40:12.713 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent message Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=5, payload=05 02 32 01
01:40:12.715 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv message Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, payload=E6 00 00 02
01:40:12.716 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 04 00 05 12 32 02 21 64 00 00 01 42 00 00 00 00 01 42 00 00 00 00 81
01:40:12.718 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=230, expected=ApplicationCommandHandler, cancelled=false MISMATCH
01:40:12.723 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
01:40:12.725 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 18 00 04 00 05 12 32 02 21 64 00 00 01 42 00 00 00 00 01 42 00 00 00 00 81
01:40:12.728 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 18 00 04 00 05 12 32 02 21 64 00 00 01 42 00 00 00 00 01 42 00 00 00 00 81
01:40:12.730 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, payload=00 05 12 32 02 21 64 00 00 01 42 00 00 00 00 01 42 00 00 00 00
01:40:12.731 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE)
01:40:12.732 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Incoming command class METER
01:40:12.733 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Received Meter Request
01:40:12.734 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Meter: Type=Electric(1), Scale=kWh(0), Value=0.322, Delta=0
01:40:12.735 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMeterValueEvent
01:40:12.736 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent message Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=5, payload=05 02 32 01
01:40:12.738 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv message Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, payload=00 05 12 32 02 21 64 00 00 01 42 00 00 00 00 01 42 00 00 00 00
01:40:12.739 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=230, expected=ApplicationCommandHandler, cancelled=false transaction complete!
01:40:12.739 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
01:40:12.742 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 5: Response processed after 67ms/4196ms.
01:40:12.743 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 1
01:40:12.744 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 05 02 32 01 25 E7 13
01:40:12.745 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 5: Sending REQUEST Message = 01 09 00 13 05 02 32 01 25 E7 13
01:40:12.755 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
01:40:12.757 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
01:40:12.758 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
01:40:12.759 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
01:40:12.760 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, payload=01
01:40:12.761 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: Sent Data successfully placed on stack.
01:40:12.771 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 E7 00 00 02 0E
01:40:12.773 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
01:40:12.776 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 E7 00 00 02 00 00 00
01:40:12.778 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 E7 00 00 02 00 00 00
01:40:12.780 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, payload=E7 00 00 02
01:40:12.781 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: SendData Request. CallBack ID = 231, Status = Transmission complete and ACK received(0)
01:40:12.783 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent message Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=5, payload=05 02 32 01
01:40:12.784 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv message Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, payload=E7 00 00 02
01:40:12.785 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=231, expected=ApplicationCommandHandler, cancelled=false MISMATCH
01:40:12.786 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 04 00 05 12 32 02 21 64 00 00 01 42 00 00 00 00 01 42 00 00 00 00 81
01:40:12.789 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
01:40:12.791 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 18 00 04 00 05 12 32 02 21 64 00 00 01 42 00 00 00 00 01 42 00 00 00 00 81
01:40:12.794 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 18 00 04 00 05 12 32 02 21 64 00 00 01 42 00 00 00 00 01 42 00 00 00 00 81
01:40:12.795 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, payload=00 05 12 32 02 21 64 00 00 01 42 00 00 00 00 01 42 00 00 00 00
01:40:12.796 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE)
01:40:12.797 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Incoming command class METER
01:40:12.798 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Received Meter Request
01:40:12.799 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 5: Meter: Type=Electric(1), Scale=kWh(0), Value=0.322, Delta=0
01:40:12.800 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMeterValueEvent
01:40:12.801 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent message Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=5, payload=05 02 32 01
01:40:12.804 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv message Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, payload=00 05 12 32 02 21 64 00 00 01 42 00 00 00 00 01 42 00 00 00 00
01:40:12.806 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=231, expected=ApplicationCommandHandler, cancelled=false transaction complete!
01:40:12.807 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
01:40:12.809 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 5: Response processed after 63ms/4196ms.
01:40:12.810 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
01:40:12.811 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 05 02 25 02 25 E8 08
01:40:12.813 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 5: Sending REQUEST Message = 01 09 00 13 05 02 25 02 25 E8 08
01:40:12.823 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
01:40:12.824 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
01:40:12.825 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
01:40:12.826 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
01:40:12.826 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, payload=01
01:40:12.827 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: Sent Data successfully placed on stack.
01:40:12.838 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 E8 00 00 02 01
01:40:12.840 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
01:40:12.842 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 E8 00 00 02 00 00 0F
01:40:12.843 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 E8 00 00 02 00 00 0F
01:40:12.845 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, payload=E8 00 00 02
01:40:12.846 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 5: SendData Request. CallBack ID = 232, Status = Transmission complete and ACK received(0)
01:40:12.848 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent message Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=5, payload=05 02 25 02
01:40:12.850 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv message Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, payload=E8 00 00 02
01:40:12.850 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 05 03 25 03 FF 2D
01:40:12.852 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=232, expected=ApplicationCommandHandler, cancelled=false MISMATCH
01:40:12.853 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
01:40:12.855 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 05 03 25 03 FF 2D
01:40:12.858 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 05 03 25 03 FF 2D
01:40:12.859 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, payload=00 05 03 25 03 FF
01:40:12.859 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Application Command Request (ALIVE:DONE)
01:40:12.860 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 5: Incoming command class SWITCH_BINARY
01:40:12.860 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - Received Switch Binary Request for Node ID = 5
01:40:12.861 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 5: Switch Binary report, value = 255
01:40:12.861 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
01:40:12.863 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent message Message: class=SendData[0x13], type=Request[0x00], priority=Get, dest=5, payload=05 02 25 02
01:40:12.865 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv message Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, payload=00 05 03 25 03 FF
01:40:12.865 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=232, expected=ApplicationCommandHandler, cancelled=false transaction complete!
01:40:12.866 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
01:40:12.867 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 5: Response processed after 53ms/4196ms.
