I have reinstalled openhabian 2.4 on my raspi and am running into issue of temperarure being displayed in Celsius by setting the value Operation Mode in the zwave binding config.
The PST02 sensor out of the box displays temperatue in Fahrenheit, so a change in a specific bit needs to be done so that the temperature can be displayed in Celsius. I have done that before a number of times in the 1.x, 2.2 and 2.4-SNAPSHOT versions of zwave.
However, now I am having a number of issues with setting the bits (Celsius being one of them).
a) The only value selectable from a dropdown in habmin and paperui is “Preset: Celsius and LED on = Bits: 00001010 = 10”. Changing to that value did not change F to C after the wakeup (I have two sensors, by the way - sam ebad luck with both).
b) it should be possible to make the change to the bits in the Op Mode parameter as described in the PST02 manual table - operation mode 5: https://doc.eedomus.com/files/PST02_Manual-2014-09-17.pdf
For example if I want to have a number of parameters changed, like switching to Celsius and having Led turned off, and more, I would need to change the Op mode vale to 140
Bit: 7 6 5 4 3 2 1 0 ON(1) 1 0 0 0 1 1 0 0 Value 128 64 32 16 8 4 2 1 ------------------------------------- 128 + 0 + 0 +0 + 8 + 4 + 0 + 0 = 140
However, it seems that there is no way of changing the operation mode value to 140:
- in habmin, I can change the value and save successfully, but upon refresh the value is gone.
- in paperui, I cannot change the value. When saving I get ERROR 400 - bad request.
Any idea, guys of what to do, i tried to revert to the old z-wave 2.4 snapshot, but get an error
"Error starting bundle 234: Could not resolve module: org.openhab.binding.zwave [234] Another singleton bundle selected: osgi.identity; type="osgi.bundle"; version:Version="2.4.0"; osgi.identity="org.openhab.binding.zwave"; singleton:="true""
Thanks,
Tom
