I’ve been using Openhab for 2-3 years now, and thanks to the fantastic advice and support on the forums I’ve never needed to post before (so I count myself as a bit of a forum noob, and I apologise in advance if I fail to observe some protocols) but I’ve hit my first wall.
I’ve been trying to install a Qubino Mini Dimmer ZMNHHD through the Paper UI on a RPi running Openhab2 (2.5.1-2). It is recognised, but is missing its association groups and channels.
I can see others have had problems, and have tried to understand the discussions.
It appears there are two entries in the Z-wave database (#1100 and #1188). #1188 is incomplete and has been marked as deleted, but my install absolutely insists on installing #1188 rather than #1100.
I’ve tried using switching between the release, testing and snapshot builds using openhabian-config to no avail.
I’m assuming that the version of the database in my install needs to be updated. Is there a way I can do this manually or force the discovery to #1100?
Will a manual install of the ZWave binding using the following solve it? Having used the Paper UI mostly for setting up bindings and devices I’ve not been brave enough to try yet and I don’t want to proceed down that route without knowing it is necessary.
@struvusmaximus - fabulous - I took the SNAPSHOT.jar and dropped it in the addons directory (openhab2-addons on my machine) et voila - thank you so much for your help
I’m using OH 2.5.10-1, the Qubino Mini dimmer works fine and reliable
However, I miss an on/off switch. The Qubino is able to do that, as it has a command class COMMAND_CLASS_SWITCH_BINARY.
Of course, I can always use the dimmer value to put the lights on, but I cannot put the light in the previous level (minor issue, I know).
In the openhab cli, when I run the command:
smarthome:things show zwave:device:[myzwaveid]:node7
I get the response: (abreviated for clearity):
Label: Dimmer
Type: zwave:switch_dimmer
Description: The brightness channel allows to control the brightness of a light. It is also possible to switch the light on and off.
Label: Electric meter (kWh)
Type: zwave:meter_kwh
Description: Indicates the energy consumption (kWh)
Label: Electric meter (watts)
Type: zwave:meter_watts
Description: Indicates the instantaneous power consumption
Label: Alarm (power)
Type: zwave:alarm_power
Description: Indicates if a power alarm is triggered
I assume the on/off switch is not implemented… ? @chris was this a design issue?
No. We don’t normally provide a switch channel - if you have a dimmer channel you can use this and another channel is normally of no additional use. This is the way OH is meant to work (ie a dimmer extends a switch).
