Ok thanks Chris, a question regarding the trick to override the Manufacturer ID in the node[n].xml file… ist it the value or the value? My xml file has the following…
0xffff
65535
Many thanks in advance!
Vincent
0xffff
65535
Vincent
I think the XML uses the hex values (so FFFF). Note though that if the device is not completing initialisation, then the XML file will just get overwritten and it will ignore whatever you change.
