Parameter #13 is the mode for button #3. i.e. #11=button#1, #12=button #2… etc.).
I tried changing this to ‘5’ (pre configured scenes). I woke the keyfob (which ends up sending out a scene messages as you hold the buttons down to get into wake mode, so ignore them). Log below:
2020-01-25 18:59:59.534 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Configuration update received
2020-01-25 18:59:59.539 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Configuration update set config_13_1 to 5 (BigDecimal)
2020-01-25 18:59:59.540 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 33: Creating new message for application command CONFIGURATION_SET
2020-01-25 18:59:59.543 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: SECURITY not supported
2020-01-25 18:59:59.544 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2020-01-25 18:59:59.545 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Bump transaction 381 priority from Config to Immediate
2020-01-25 18:59:59.547 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Adding to device queue
2020-01-25 18:59:59.548 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Added 381 to queue - size 1
2020-01-25 18:59:59.550 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 33: Creating new message for application command CONFIGURATIONCMD_GET
2020-01-25 18:59:59.552 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: SECURITY not supported
2020-01-25 18:59:59.553 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Command Class COMMAND_CLASS_CONFIGURATION is NOT required to be secured
2020-01-25 18:59:59.558 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Bump transaction 382 priority from Config to Immediate
2020-01-25 18:59:59.559 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Adding to device queue
2020-01-25 18:59:59.561 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Added 382 to queue - size 2
2020-01-25 19:00:21.402 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Application Command Request (ALIVE:DONE)
2020-01-25 19:00:21.404 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: resetResendCount initComplete=true isDead=false
2020-01-25 19:00:21.406 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Incoming command class COMMAND_CLASS_SCENE_ACTIVATION, endpoint 0
2020-01-25 19:00:21.407 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: SECURITY not supported
2020-01-25 19:00:21.408 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Received COMMAND_CLASS_SCENE_ACTIVATION V0 SCENEACTIVATION_SET
2020-01-25 19:00:21.410 [DEBUG] [ass.ZWaveSceneActivationCommandClass] - NODE 33: Scene activation: Scene 33, Time 255
2020-01-25 19:00:21.412 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2020-01-25 19:00:21.414 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SCENE_ACTIVATION, value=33
2020-01-25 19:00:21.418 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Commands processed 1.
2020-01-25 19:00:21.420 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1a8ec85.
2020-01-25 19:00:21.472 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Application Command Request (ALIVE:DONE)
2020-01-25 19:00:21.473 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: resetResendCount initComplete=true isDead=false
2020-01-25 19:00:21.476 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Incoming command class COMMAND_CLASS_SCENE_ACTIVATION, endpoint 0
2020-01-25 19:00:21.477 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: SECURITY not supported
2020-01-25 19:00:21.479 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Received COMMAND_CLASS_SCENE_ACTIVATION V0 SCENEACTIVATION_SET
2020-01-25 19:00:21.481 [DEBUG] [ass.ZWaveSceneActivationCommandClass] - NODE 33: Scene activation: Scene 43, Time 255
2020-01-25 19:00:21.483 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2020-01-25 19:00:21.485 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SCENE_ACTIVATION, value=43
2020-01-25 19:00:21.487 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Commands processed 1.
2020-01-25 19:00:21.489 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1f9b12b.
2020-01-25 19:00:21.545 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Application Command Request (ALIVE:DONE)
2020-01-25 19:00:21.547 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: resetResendCount initComplete=true isDead=false
2020-01-25 19:00:21.548 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Incoming command class COMMAND_CLASS_SCENE_ACTIVATION, endpoint 0
2020-01-25 19:00:21.551 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: SECURITY not supported
2020-01-25 19:00:21.552 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Received COMMAND_CLASS_SCENE_ACTIVATION V0 SCENEACTIVATION_SET
2020-01-25 19:00:21.555 [DEBUG] [ass.ZWaveSceneActivationCommandClass] - NODE 33: Scene activation: Scene 13, Time 255
2020-01-25 19:00:21.556 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2020-01-25 19:00:21.559 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SCENE_ACTIVATION, value=13
2020-01-25 19:00:21.561 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Commands processed 1.
2020-01-25 19:00:21.563 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1d62a68.
2020-01-25 19:00:21.591 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Application Command Request (ALIVE:DONE)
2020-01-25 19:00:21.592 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: resetResendCount initComplete=true isDead=false
2020-01-25 19:00:21.593 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Incoming command class COMMAND_CLASS_SCENE_ACTIVATION, endpoint 0
2020-01-25 19:00:21.594 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: SECURITY not supported
2020-01-25 19:00:21.595 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Received COMMAND_CLASS_SCENE_ACTIVATION V0 SCENEACTIVATION_SET
2020-01-25 19:00:21.597 [DEBUG] [ass.ZWaveSceneActivationCommandClass] - NODE 33: Scene activation: Scene 23, Time 255
2020-01-25 19:00:21.598 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2020-01-25 19:00:21.599 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_SCENE_ACTIVATION, value=23
2020-01-25 19:00:21.601 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Commands processed 1.
2020-01-25 19:00:21.602 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@8cdf4c.
2020-01-25 19:00:30.850 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 33: Application update request. Node information received. Transaction null
2020-01-25 19:00:30.852 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: resetResendCount initComplete=true isDead=false
2020-01-25 19:00:30.854 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 33: Application update - no transaction.
2020-01-25 19:00:30.872 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Application Command Request (ALIVE:DONE)
2020-01-25 19:00:30.873 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: resetResendCount initComplete=true isDead=false
2020-01-25 19:00:30.875 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Is awake with 2 messages in the queue
2020-01-25 19:00:30.877 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Start sleep timer at 1000ms
2020-01-25 19:00:30.879 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2020-01-25 19:00:30.890 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 33: Node Status event - Node is AWAKE
2020-01-25 19:00:30.892 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Commands processed 1.
2020-01-25 19:00:30.893 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@9ec65c.
2020-01-25 19:00:30.908 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Application Command Request (ALIVE:DONE)
2020-01-25 19:00:30.911 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: resetResendCount initComplete=true isDead=false
2020-01-25 19:00:30.913 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Incoming command class COMMAND_CLASS_BATTERY, endpoint 0
2020-01-25 19:00:30.915 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: SECURITY not supported
2020-01-25 19:00:30.916 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Received COMMAND_CLASS_BATTERY V1 BATTERY_REPORT
2020-01-25 19:00:30.919 [DEBUG] [ommandclass.ZWaveBatteryCommandClass] - NODE 33: Battery report value = 73
2020-01-25 19:00:30.921 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2020-01-25 19:00:30.923 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_BATTERY, value=73
2020-01-25 19:00:30.924 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Updating channel state zwave:device:1139f694:node33:battery-level to 73 [DecimalType]
2020-01-25 19:00:30.925 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Commands processed 1.
2020-01-25 19:00:30.927 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@bc550d.
2020-01-25 19:00:30.935 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 33: Sending REQUEST Message = 01 0C 00 13 21 05 70 04 0D 01 05 25 50 CC
2020-01-25 19:00:31.001 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 33: sentData successfully placed on stack.
2020-01-25 19:00:31.003 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: TID 381: Transaction not completed
2020-01-25 19:00:31.076 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 33: SendData Request. CallBack ID = 80, Status = Transmission complete and ACK received(0)
2020-01-25 19:00:31.077 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: resetResendCount initComplete=true isDead=false
2020-01-25 19:00:31.079 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Response processed after 113ms
2020-01-25 19:00:31.080 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: TID 381: Transaction completed
2020-01-25 19:00:31.084 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: notifyTransactionResponse TID:381 DONE
2020-01-25 19:00:31.087 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-01-25 19:00:31.093 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 33: Sending REQUEST Message = 01 0A 00 13 21 03 70 05 0D 25 51 C8
2020-01-25 19:00:31.162 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 33: sentData successfully placed on stack.
2020-01-25 19:00:31.169 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: TID 382: Transaction not completed
2020-01-25 19:00:31.194 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 33: SendData Request. CallBack ID = 81, Status = Transmission complete and ACK received(0)
2020-01-25 19:00:31.195 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: resetResendCount initComplete=true isDead=false
2020-01-25 19:00:31.197 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: TID 382: Transaction not completed
2020-01-25 19:00:31.299 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Application Command Request (ALIVE:DONE)
2020-01-25 19:00:31.300 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: resetResendCount initComplete=true isDead=false
2020-01-25 19:00:31.302 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Incoming command class COMMAND_CLASS_CONFIGURATION, endpoint 0
2020-01-25 19:00:31.303 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: SECURITY not supported
2020-01-25 19:00:31.304 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 33: Received COMMAND_CLASS_CONFIGURATION V1 CONFIGURATIONCMD_REPORT
2020-01-25 19:00:31.305 [DEBUG] [class.ZWaveConfigurationCommandClass] - NODE 33: Node configuration report, parameter = 13, value = 5, size = 1
2020-01-25 19:00:31.307 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got an event from Z-Wave network: ZWaveConfigurationParameterEvent
2020-01-25 19:00:31.308 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got a value event from Z-Wave network, endpoint=0, command class=COMMAND_CLASS_CONFIGURATION, value=org.openhab.binding.zwave.internal.protocol.ZWaveConfigurationParameter@18accc8
2020-01-25 19:00:31.310 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Update CONFIGURATION 13/1 to 5
2020-01-25 19:00:31.311 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Commands processed 1.
2020-01-25 19:00:31.312 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@bbbad8.
2020-01-25 19:00:31.313 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@bbbad8.
2020-01-25 19:00:31.315 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: notifyTransactionResponse TID:382 DONE
2020-01-25 19:00:31.316 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-01-25 19:00:31.379 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: WakeupTimerTask 0 Messages waiting, state DONE
2020-01-25 19:00:31.880 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: WakeupTimerTask 0 Messages waiting, state DONE
2020-01-25 19:00:31.881 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: No more messages, go back to sleep
2020-01-25 19:00:31.885 [DEBUG] [commandclass.ZWaveWakeUpCommandClass] - NODE 33: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
2020-01-25 19:00:31.886 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: SECURITY not supported
2020-01-25 19:00:31.888 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Command Class COMMAND_CLASS_WAKE_UP is NOT required to be secured
2020-01-25 19:00:31.889 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: sendTransaction org.openhab.binding.zwave.internal.protocol.transaction.ZWaveCommandClassTransactionPayload@10985f1
2020-01-25 19:00:31.891 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Bump transaction 383 priority from Immediate to Immediate
2020-01-25 19:00:31.893 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Adding to device queue
2020-01-25 19:00:31.894 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Added 383 to queue - size 1
2020-01-25 19:00:31.900 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 33: Sending REQUEST Message = 01 09 00 13 21 02 84 08 25 52 3D
2020-01-25 19:00:31.979 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 33: sentData successfully placed on stack.
2020-01-25 19:00:31.982 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: TID 383: Transaction not completed
2020-01-25 19:00:32.023 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 33: SendData Request. CallBack ID = 82, Status = Transmission complete and ACK received(0)
2020-01-25 19:00:32.028 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: resetResendCount initComplete=true isDead=false
2020-01-25 19:00:32.034 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: Response processed after 98ms
2020-01-25 19:00:32.035 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: TID 383: Transaction completed
2020-01-25 19:00:32.036 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 33: notifyTransactionResponse TID:383 DONE
2020-01-25 19:00:32.037 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 33: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2020-01-25 19:00:32.038 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 33: Went to sleep COMPLETE
However subsequent presses of button #3 no longer send anything (nothing in the log).
I’m not sure what the pre-configured scenes are either - there is no other mention of them in the manual that I can see, apart from the entry in the config table.
