git clone -b dbadia-security-mmerge https://github.com/cdjackson/openhab.git is what I am trying to build… that should do it right?
Oh yeah… so i got some MVN errors when I tried to build that. so I copied over the zwave bundle to a branch that works. i must have missed something…
Here are my build errors when I run “mvn package” in the cloned directory
root@p0larnix:~/openhab/openhabZLocks/openhab# mvn
[INFO] Scanning for projects…
[ERROR] [ERROR] Some problems were encountered while processing the POMs:
[ERROR] Child module /root/openhab/openhabZLocks/openhab/bundles/binding/org.openhab.binding.zwave.test of /root/openhab/openhabZLocks/openhab/bundles/binding/pom.xml does not exist @
[ERROR] The build could not read 1 project -> [Help 1]
[ERROR]
[ERROR] The project org.openhab.bundles:binding:1.9.0-SNAPSHOT (/root/openhab/openhabZLocks/openhab/bundles/binding/pom.xml) has 1 error
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildingException
Try going into the binding directory and then building:
root@maggie ~ # git clone -b dbadia-security-mmerge https://github.com/cdjackson/openhab.git
root@maggie ~ # cd openhab/bundles/binding/org.openhab.binding.zwave/
root@maggie org.openhab.binding.zwave # mvn package
[INFO] Scanning for projects...
[INFO] Computing target platform for MavenProject: org.openhab.binding:org.openhab.binding.zwave:1.9.0-SNAPSHOT @ /root/openhab/bundles/binding/org.openhab.binding.zwave/pom.xml
[INFO] Adding repository http://download.eclipse.org/smarthome/updates-stable
[INFO] Adding repository https://dl.bintray.com/openhab/p2/openhab-core/2.0.0.x
[INFO] Adding repository https://dl.bintray.com/openhab/p2/openhab-deps-repo/1.0.0
[INFO] Resolving dependencies of MavenProject: org.openhab.binding:org.openhab.binding.zwave:1.9.0-SNAPSHOT @ /root/openhab/bundles/binding/org.openhab.binding.zwave/pom.xml
[WARNING] The following locally built units have been used to resolve project dependencies:
[WARNING] org.openhab.core.library/1.8.3
[WARNING] org.openhab.model.item/1.8.3
[WARNING] org.openhab.core.scriptengine/1.8.3
[WARNING] org.openhab.core.scheduler/1.8.3
[WARNING] org.openhab.core.autoupdate/1.8.3
[WARNING] org.openhab.core/1.8.3
[WARNING] org.openhab.config.core/1.8.3
[WARNING] org.openhab.model.core/1.8.3
[INFO] Resolving class path of MavenProject: org.openhab.binding:org.openhab.binding.zwave:1.9.0-SNAPSHOT @ /root/openhab/bundles/binding/org.openhab.binding.zwave/pom.xml
[INFO]
[INFO] ------------------------------------------------------------------------
[INFO] Building openHAB ZWave Binding 1.9.0-SNAPSHOT
[INFO]
[INFO] --- tycho-packaging-plugin:0.24.0:build-qualifier (default-build-qualifier) @ org.openhab.binding.zwave ---
[INFO] The project's OSGi version is 1.9.0.201608171602
[INFO]
[INFO] --- tycho-packaging-plugin:0.24.0:validate-id (default-validate-id) @ org.openhab.binding.zwave ---
[INFO]
[INFO] --- tycho-packaging-plugin:0.24.0:validate-version (default-validate-version) @ org.openhab.binding.zwave ---
[INFO]
[INFO] --- maven-resources-plugin:2.4.3:resources (default-resources) @ org.openhab.binding.zwave ---
[INFO] Using 'UTF-8' encoding to copy filtered resources.
[INFO] Copying 1 resource
[INFO]
[INFO] --- tycho-compiler-plugin:0.24.0:compile (default-compile) @ org.openhab.binding.zwave ---
[INFO] Compiling 174 source files to /root/openhab/bundles/binding/org.openhab.binding.zwave/target/classes
[INFO]
[INFO] --- maven-resources-plugin:2.4.3:testResources (default-testResources) @ org.openhab.binding.zwave ---
[INFO] skip non existing resourceDirectory /root/openhab/bundles/binding/org.openhab.binding.zwave/src/test/resources
[INFO]
[INFO] --- target-platform-configuration:0.24.0:target-platform (default-target-platform) @ org.openhab.binding.zwave ---
[INFO]
[INFO] --- tycho-packaging-plugin:0.24.0:package-plugin (default-package-plugin) @ org.openhab.binding.zwave ---
[INFO] Building jar: /root/openhab/bundles/binding/org.openhab.binding.zwave/target/org.openhab.binding.zwave-1.9.0-SNAPSHOT.jar
[INFO]
[INFO] --- tycho-p2-plugin:0.24.0:p2-metadata-default (default-p2-metadata-default) @ org.openhab.binding.zwave ---
[INFO] BUILD SUCCESS
[INFO] Total time: 24.902 s
[INFO] Finished at: 2016-08-17T12:02:21-04:00
[INFO] Final Memory: 40M/446M
I would remove this from the pom - it should fix it. I’m not sure why it’s there as the tests were added later.
I’ll also update the git repo shortly to remove it.
Edit: It’s now updated on github and the latest master is also merged as I fixed a small bug yesterday.
How do I build a jar from a branch? Is there a tutorial?
You just build the JAR in the same way - you need to use git to swap to the branch you want to build.
Probably hundreds - just google something like “git change branch”. However if you look a few lines up, there are already examples of checking out the branch.
Got it built. testing now. weird that habmin stopped working… Ideas?
dpackham@p0larNix:/var/log/openhab$ tail -f openhab.log | grep -i habmin
2016-08-22 22:25:12.100 [DEBUG] [nhab.io.habmin.HABminActivator] - HABmin Interface has been started.
2016-08-22 22:25:12.111 [ERROR] [OSGi ] - Could not bind a reference of component org.openhab.io.habmin.servlet. The reference is: Reference[name = PersistenceService, interface = org.openhab.core.persistence.PersistenceService, policy = dynamic, cardinality = 0..n, target = null, bind = addPersistenceService, unbind = removePersistenceService]
2016-08-22 22:25:12.113 [ERROR] [OSGi ] - Could not bind a reference of component org.openhab.io.habmin.servlet. The reference is: Reference[name = ConfigurationService, interface = org.openhab.binding.zwave.internal.config.OpenHABConfigurationService, policy = dynamic, cardinality = 0..n, target = null, bind = addConfigurationService, unbind = removeConfigurationService]
2016-08-22 22:25:12.114 [ERROR] [OSGi ] - Could not bind a reference of component org.openhab.io.habmin.servlet. The reference is: Reference[name = ConfigurationService, interface = org.openhab.binding.zwave.internal.config.OpenHABConfigurationService, policy = dynamic, cardinality = 0..n, target = null, bind = addConfigurationService, unbind = removeConfigurationService]
2016-08-22 22:25:12.379 [INFO ] [.o.io.habmin.HABminApplication] - Started HABmin REST API at /services/habmin
I have the same BE469 that most people on this post have, here’s the secure inclusion log from my latest attempt. Before this attempt I: excluded the insecurely paired version from openhab, factory reset the lock and restarted the openhab server. The lock is sitting on the table less than a foot from the z-stick; any ideas what the problem could be?
Time Node Entry
21:27:14.186 3
Message retry (0 attempts remaining)
21:27:14.307 3
SECURE ERROR Invalid state! Secure inclusion has not completed and we are not in inclusion mode. Aborting
21:27:19.813 3
Message retry (2 attempts remaining)
21:27:24.815 3
Message retry (1 attempts remaining)
21:27:29.821 3
21:27:39.834 3
21:27:44.837 3
21:27:49.843 3
21:28:01.120 3
21:28:06.124 3
21:28:11.126 3
21:28:21.135 3
21:28:26.139 3
21:28:31.143 3
21:28:41.154 3
21:28:46.159 3
21:29:10.505
21:29:33.996
21:29:39.002
21:29:44.002
21:30:40.668 4
21:30:41.025 4
SECURE ERROR Device message contained nonce that is unknown to us, id=44.
21:30:46.030 4
21:30:46.113 4
SECURE ERROR Device message contained nonce that was previously used, id=44.
21:48:36.711
21:48:41.714
21:48:43.146 4
21:48:46.716
21:48:48.176
21:48:53.178
21:48:58.179
21:49:06.714
21:49:08.185
21:49:11.715
21:49:13.187
21:49:16.717
21:49:18.189
21:49:28.192
21:49:33.193
21:49:38.195
21:49:48.200
21:49:53.203
21:49:58.204
21:59:32.937 5
21:59:33.304 5
SECURE ERROR Device message contained nonce that is unknown to us, id=-85.
21:59:38.307 5
21:59:38.393 5
SECURE ERROR Device message contained nonce that was previously used, id=-85.
21:59:43.658 5
SECURE INCLUSION Failed at step SECURITY_NETWORK_KEY_SET: 10000ms passed since last request was sent, secure inclusion failed.
21:59:49.070 5
21:59:54.073 5
21:59:59.078 5
22:00:09.144 5
22:00:14.148 5
22:00:19.152 5
22:00:29.159 5
22:00:34.225 5
22:00:39.232 5
22:00:49.240 5
22:00:54.243 5
22:00:59.245 5
22:01:09.306 5
22:01:14.311 5
22:01:19.314 5
22:02:24.083 5
22:02:29.085 5
22:02:34.091 5
22:10:24.082 5
22:10:29.086 5
22:10:34.089 5
22:17:55.345
TX REQ Remove Node REMOVE_NODE_ANYRemoveNodeFromNetwork
22:17:55.474
RX REQ Remove Node REMOVE_NODE_STATUS_LEARN_READYRemoveNodeFromNetwork
22:17:58.837
RX REQ Remove Node REMOVE_NODE_STATUS_NODE_FOUNDRemoveNodeFromNetwork
22:17:58.841 5
RX REQ Remove Node REMOVE_NODE_STATUS_REMOVING_SLAVE NODE 5RemoveNodeFromNetwork
22:17:58.844 5
RX REQ Remove Node REMOVE_NODE_STATUS_DONE NODE 5RemoveNodeFromNetwork
22:18:01.851
TX REQ GetVersionGetVersion
22:18:01.856
RX RES GetVersionGetVersion
22:18:01.861
TX REQ MemoryGetIdMemoryGetId
22:18:01.865
RX RES MemoryGetId: HomeID EBD99462 ControllerID NODE 1MemoryGetId
22:18:01.869
TX REQ SerialApiGetCapabilitiesSerialApiGetCapabilities
22:18:01.876
RX RES Controller Info 0086:0101:005ASerialApiGetCapabilities
22:18:01.888
TX REQ SerialApiSetTimeoutsSerialApiSetTimeouts
22:18:01.891
RX RES SerialApiSetTimeoutsSerialApiSetTimeouts
22:18:01.895
TX REQ GetSucNodeIdGetSucNodeId
22:18:01.897
RX RES SUC ID: NOT SETGetSucNodeId
22:18:01.900
TX REQ SerialApiGetInitDataSerialApiGetInitData
22:18:01.999
RX RES SerialApiGetInitData: Found 1 nodesSerialApiGetInitData
22:18:02.004
TX REQ GetControllerCapabilitiesGetControllerCapabilities
22:18:02.018
RX RES GetControllerCapabilitiesGetControllerCapabilities
22:18:02.071 1
Stage advanced to PROTOINFO
22:18:02.073 1
TX REQ IdentifyNodeIdentifyNode
22:18:02.077 1
RX RES IdentifyNode: STATIC_CONTROLLER PC_CONTROLLER LISTENING FLIRS250 FLIRS1000 ROUTING BEAMINGIdentifyNode
22:18:02.082 1
22:18:02.083 1
Stage advanced to INIT_NEIGHBORS
22:18:02.084 1
22:18:02.089 1
22:18:02.093 1
TX REQ GetRoutingInfoGetRoutingInfo
22:18:02.098 1
RX RES RoutingInfo: Found 0 neighboursGetRoutingInfo
22:18:02.121 1
Stage advanced to FAILED_CHECK
22:18:25.342
TX REQ Remove Node REMOVE_NODE_STOPRemoveNodeFromNetwork
22:18:30.342
22:18:30.343
22:18:35.343
22:18:35.344
22:18:40.345
22:18:40.346
22:20:12.434
Binding started. Version 2.0.0.201608280109
22:20:17.292
22:20:17.304
22:20:17.336
22:20:17.340
22:20:17.362
22:20:17.368
22:20:17.400
22:20:17.403
22:20:17.434
22:20:17.437
22:20:17.453
22:20:17.553
22:20:17.569
22:20:17.579
22:20:17.803 1
22:20:17.808 1
22:20:17.812 1
22:20:17.832 1
22:20:17.832 1
22:20:17.833 1
22:20:17.835 1
22:20:17.841 1
22:20:17.857 1
22:20:17.884 1
22:20:17.892 1
22:20:33.232
TX REQ Add Node ADD_NODE_ANY HIGH POWER NWIAddNodeToNetwork
22:20:33.236
RX REQ Add Node ADD_NODE_STATUS_LEARN_READYAddNodeToNetwork
22:20:34.354
RX REQ Add Node ADD_NODE_STATUS_NODE_FOUNDAddNodeToNetwork
22:20:34.501 6
RX REQ Add Node ADD_NODE_STATUS_ADDING_SLAVE NODE 6AddNodeToNetwork
22:20:34.509
TX REQ Add Node ADD_NODE_STOPAddNodeToNetwork
22:20:34.564 6
RX REQ Add Node ADD_NODE_STATUS_DONE NODE 6AddNodeToNetwork
22:20:34.747 6
Stage advanced to IDENTIFY_NODE
22:20:34.768 6
22:20:34.771 6
RX RES IdentifyNode: ROUTING_SLAVE SECURE_KEYPAD_DOOR_LOCK LISTENING FLIRS250 FLIRS1000 ROUTING BEAMINGIdentifyNode
22:20:34.811 6
Stage advanced to MANUFACTURER
22:20:34.902 6
TX REQ SendData 2 Sent MANUFACTURER_SPECIFIC_GETSendData
22:20:34.911 6
RX RES SendData 2 ACCEPTED BY CONTROLLERSendData
22:20:34.969 6
RX REQ SendData 2 ACK RECEIVED from device in 67msSendData
22:20:35.054 6
RX REQ MANUFACTURER_SPECIFIC_REPORT 003B:6341:5044 Schlage, Touchscreen DeadboltApplicationCommandHandler
22:20:39.909 6
Sending data abort
22:20:39.909
TX REQ SendDataAbortSendDataAbort
22:20:39.910 6
22:20:39.911 6
TX REQ SendData 4 Sent MANUFACTURER_SPECIFIC_GETSendData
22:20:39.920 6
RX RES SendData 4 ACCEPTED BY CONTROLLERSendData
22:20:39.937 6
RX REQ SendData 4 ACK RECEIVED from device in 26msSendData
22:20:39.950 6
22:20:39.954 6
Stage advanced to SECURITY_REPORT
22:20:39.955 6
SECURE INCLUSION INCLUSION IN PROGRESS PAIRED LAST RX ----ms LAST TX 1ms
22:20:39.957 6
TX REQ SendData 5 Sent SECURITY_SCHEME_GETSendData
22:20:39.968 6
RX RES SendData 5 ACCEPTED BY CONTROLLERSendData
22:20:39.983 6
RX REQ SendData 5 ACK RECEIVED from device in 26msSendData
22:20:40.052 6
RX REQ SECURITY_SCHEME_REPORT SCHEME_0ApplicationCommandHandler
22:20:40.074 6
SECURE INCLUSION INCLUSION IN PROGRESS PAIRED LAST RX 10ms LAST TX 2ms
22:20:40.076 6
TX REQ SendData 6 Sent SECURITY_NONCE_GETSendData
22:20:40.084 6
RX RES SendData 6 ACCEPTED BY CONTROLLERSendData
22:20:40.113 6
RX REQ SendData 6 ACK RECEIVED from device in 37msSendData
22:20:40.129 6
RX REQ SECURITY_NONCE_REPORT NONCE ID 102ApplicationCommandHandler
22:20:40.156 6
SECURE INCLUSION INCLUSION IN PROGRESS PAIRED LAST RX 21ms LAST TX 1ms
22:20:40.167 6
TX REQ SendData 7 Sent SECURITY_ENCAP NONCE ID 102SendData
22:20:40.179 6
RX RES SendData 7 ACCEPTED BY CONTROLLERSendData
22:20:40.204 6
RX REQ SendData 7 ACK RECEIVED from device in 37msSendData
22:20:40.320 6
RX REQ SECURITY_NONCE_GETApplicationCommandHandler
22:20:40.323 6
SECURE ERROR Device message contained nonce that is unknown to us, id=-4.
22:20:40.325 6
TX REQ SendData 8 Sent SECURITY_NONCE_REPORT NONCE ID 252SendData
22:20:40.334 6
RX RES SendData 8 ACCEPTED BY CONTROLLERSendData
22:20:40.354 6
RX REQ SendData 8 ACK RECEIVED from device in 29msSendData
22:20:40.408 6
RX REQ SECURITY_ENCAP NONCE ID 252ApplicationCommandHandler
22:20:40.415 6
SECURE RXD SECURITY_KEY_VERIFY
22:20:40.563 6
SECURE INCLUSION INCLUSION IN PROGRESS PAIRED LAST RX 241ms LAST TX 239ms
22:20:41.365 6
SECURE INCLUSION INCLUSION IN PROGRESS PAIRED LAST RX 1043ms LAST TX 1041ms
22:20:42.167 6
SECURE INCLUSION INCLUSION IN PROGRESS PAIRED LAST RX 1845ms LAST TX 1843ms
22:20:42.972 6
SECURE INCLUSION INCLUSION IN PROGRESS PAIRED LAST RX 2650ms LAST TX 2648ms
22:20:43.774 6
SECURE INCLUSION INCLUSION IN PROGRESS PAIRED LAST RX 3452ms LAST TX 3450ms
22:20:45.331 6
22:20:45.333 6
TX REQ SendData 9 Sent SECURITY_NONCE_REPORT NONCE ID 252SendData
22:20:45.341 6
RX RES SendData 9 ACCEPTED BY CONTROLLERSendData
22:20:45.361 6
RX REQ SendData 9 ACK RECEIVED from device in 28msSendData
22:20:45.383 6
SECURE INCLUSION INCLUSION IN PROGRESS PAIRED LAST RX 5061ms LAST TX 5059ms
22:20:45.413 6
22:20:45.418 6
SECURE ERROR Device message contained nonce that was previously used, id=-4.
22:20:45.419 6
SECURE INCLUSION INCLUSION IN PROGRESS PAIRED LAST RX 5097ms LAST TX 0ms
22:20:45.422 6
22:20:45.430 6
22:20:45.452 6
RX REQ SendData 4 ACK RECEIVED from device in 30msSendData
22:20:45.482 6
22:20:45.501 6
SECURE INCLUSION INCLUSION IN PROGRESS PAIRED LAST RX 5179ms LAST TX 2ms
22:20:45.906 6
SECURE INCLUSION INCLUSION IN PROGRESS PAIRED LAST RX 5584ms LAST TX 407ms
22:20:46.708 6
SECURE INCLUSION INCLUSION IN PROGRESS PAIRED LAST RX 6386ms LAST TX 1209ms
22:20:48.319 6
SECURE INCLUSION INCLUSION IN PROGRESS PAIRED LAST RX 7997ms LAST TX 2820ms
22:20:49.924 6
SECURE INCLUSION INCLUSION IN PROGRESS PAIRED LAST RX 9602ms LAST TX 4425ms
22:20:50.732 6
SECURE INCLUSION INCLUSION IN PROGRESS PAIRED LAST RX 10410ms LAST TX 5233ms
22:20:50.732 6
I see in the HABmin instructions that you need to download the zwave jar as well. does the needed code not exist in the one i hand built from the above repo?
I’m not completely sure I understand your question but HABmin is independant of ZWave. If you want to run the lock code, then just use the repo I referenced above.
yes. sorry not really clear. when I download the jar file from your site habmin doesnt work and gives the errors above. when I git clone the directory into webapps/habmin it works. so for now im working and can test zwave again.
the reference and my confusion to the zwave jar comes from the install page saying to download all the jar files on the site… zwave*.jar and org.habmin*.jar to the addons folder.
either way its working now and OH2 is on the horizion
time to test secure zwave
Thanks Chris for your help and great code.
To be clear, you mean downloading the HABmin JAR file - right? You are compiling the ZWave JAR yourself?
It probably should say that any zwave JAR can be used - maybe you ended up with 2 of them or something… Anyhow, if it’s working, then all good
All good
now just wish I could switch to OH2. still a bit buggy to get rolling enough for the wife
Does the lock really need to be touching the zwave gen5 stick to secure include? or can it be downstairs? its been included now a few times from about 30ft and it says it cant finish secure include. i think i read somewhere that the gen5 stick must be plugged into OH to secure include is that right? ive also read that i need to unplug the gen5 and move it to touching the lock and use the gen5 button to include/exclude???
It doesn’t have to be touching. 30ft should be ok (just), but it will depend on your house construction (concrete/wood) and probably a bunch of other stuff.
Normally I would recommend a few meters…
Absolutely.
No - not for secure inclusion. The stick MUST be plugged in to OH. If it doesn’t include first time, you must exclude and re-include. There are tight timing constraints on secure inclusion.
ok… trying again. all wood in the way… details and logs in a bit
I’m about to head off to bed here, and then am travelling for the next 2 days, so not sure I’ll get the chance to look until tomorrow night at least…
Good luck.
rebuilding and figured out again that I needed to add the below to the products.xml file again and rebuild also needed to copy the kwikset_914.xml to 914trl.xml to match your xml from your device database. any way this 914 can be included in your next build as a default?
still need to ex/include again to see if I can see the lock status
Dave
0090
Kwikset
Sure. If you can create a PR into the main OH1 binding I’ll merge it there and then merge this into the master branch.
