@mganapa
Hi Mahesh,
I’m thinking this is actually a bug in the Schlage lock. When the lock was listed in the habmin zwave device list, I did exactly as you suggested and the lock excluded/unpaired fine (gave me the checkmark). This worked every time the lock was shown in habmin (as shown below). When I try to enrol the lock, it shows up in habmin but the lock shows an X after 30 seconds or so but shows up in the device list… every time. When I power up the lock, the LED should flash indicating it is paired to a zwave network, which it did on Wednesday when I paired the first time, but it won’t any more tonight even when habmin swears it’s paired (and it’s clearly talking to the lock).
I then went through the exclude/include process using Aeotec’s IMA Tool and I saw the exact same behaviour… and I can see that the IMA Tool is communicating just fine with the lock… but the lock doesn’t think it’s paired.
Now, I have no idea if this behaviour means the lock won’t communicate at all (or will be wonky) or if it’ll work just fine and its just all the indicators are saying it’s not paired, but it actually is and will run fine. For the purposes of debugging openhab, however, I’d rather not introduce another unknown variable, so I will likely go and exchange the lock for a new one tomorrow. I have a feeling that when I did the factory reset on the lock with openhab running (and the Z-Stick still paired) it borked it somehow so the lock is still retaining the Z-Stick address and won’t re-include properly.
As it is, when I hit the lock button on the web UI, nothing happens (still) and I still get the following errors in the zwave.log:
2015-10-23 23:29:28.895 [WARN ] [.b.z.i.c.ZWaveConverterHandler:206 ]- No command class found for item = Door_Lock, command class name = door_lock, ignoring execute refresh.
2015-10-23 23:29:28.895 [WARN ] [.b.z.i.c.ZWaveConverterHandler:295 ]- No command class found for item = Door_Lock, command class name = door_lock, using 0 refresh interval.
2015-10-23 23:29:28.895 [WARN ] [.b.z.i.c.ZWaveConverterHandler:206 ]- No command class found for item = Door_Basic, command class name = door_lock, ignoring execute refresh.
2015-10-23 23:29:28.895 [WARN ] [.b.z.i.c.ZWaveConverterHandler:295 ]- No command class found for item = Door_Basic, command class name = door_lock, using 0 refresh interval.
2015-10-23 23:29:28.895 [WARN ] [.b.z.i.c.ZWaveConverterHandler:206 ]- No command class found for item = Door_Corridor_Battery, command class name = battery, ignoring execute refresh.
2015-10-23 23:29:28.895 [WARN ] [.b.z.i.c.ZWaveConverterHandler:295 ]- No command class found for item = Door_Corridor_Battery, command class name = battery, using 0 refresh interval.
2015-10-23 23:29:28.896 [WARN ] [.b.z.i.c.ZWaveConverterHandler:295 ]- No command class found for item = Door_Corridor_Battery, command class name = battery, using 0 refresh interval.
2015-10-23 23:29:28.896 [WARN ] [.b.z.i.c.ZWaveConverterHandler:295 ]- No command class found for item = Door_Lock, command class name = door_lock, using 0 refresh interval.
2015-10-23 23:29:28.896 [WARN ] [.b.z.i.c.ZWaveConverterHandler:295 ]- No command class found for item = Door_Basic, command class name = door_lock, using 0 refresh interval.
2015-10-23 23:29:33.814 [WARN ] [.b.z.i.c.ZWaveConverterHandler:394 ]- NODE 8: No command class found for item = Door_Lock. Class = door_lock(DOOR_LOCK), endpoint = 0. Ignoring command.
Could you or Dave check my items and sitemap files back in my second post to ensure I’ve set them up properly? I’m still not 100% certain they are.
Here’s my zwave device list showing my lock which doesn’t think it’s paired…
