Update,
After an interesting night configuring zwave devices, this morning all seems to be working well.
Last night odd things were happening. Took forever to add a new MS6 (to replace the one that will not work on batteries anymore). Had to keep waking it up to try to get configuration to complete. The new zwave binding seems to take a long time to get the device configuration - kept failing with “Static configurations not complete” - then it would start all over again on the next wake up.
Fibaro LED controller responded very slowly (i think it was downloading configurations again) - then suddenly started working normally! One of the devices that always previously worked started acting oddly. It’s a MIMO I/O module (mains powered) which switches my extractor fan light on and off. When switched the light switched on and off rapidly 10 times or so, then stopped in a random state. Looking at the log, I can see that the node was “DEAD” (it’s not), and so the switch command was sent several times with no “ACK”. Feedback always worked though, and quickly. Today - back to working normally.
As to the lock, last night, responding very slowly, or sometimes fast. feedback (alarms coming in mostly) working sporadically. Today - working well. usually takes 4 seconds to lock/unlock, feedback instant. The occasional ALARM does not show up (so the state is captured by polling, set to 120 seconds). about 85% on receiving alarms, even when they come quickly (ie unlock - exit relock in the space of 2-5 seconds works).
Here is the “Alarm” log since last night for example:
2015-11-13 23:04:30.133 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:82 ]- NODE 27: Received Alarm Request
2015-11-13 23:04:30.133 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:94 ]- NODE 27: Alarm report - Value = 0
2015-11-13 23:04:30.133 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:112 ]- NODE 27: Alarm Type = General (0)
2015-11-13 23:04:30.133 [DEBUG] [b.z.i.protocol.ZWaveController:616 ]- NODE 27: Notifying event listeners: ZWaveAlarmValueEvent: org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass$ZWaveAlarmValueEvent@2d86fde3
2015-11-13 23:06:31.409 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 27: Polling list: item Door_Status_Alarm is not completed initialisation
2015-11-13 23:06:33.634 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 27: Polling list: item Door_Status_Alarm is not completed initialisation
2015-11-13 23:08:23.851 [DEBUG] [.z.internal.ZWaveActiveBinding:193 ]- NODE 27: Polling list: item Door_Status_Alarm is not completed initialisation
2015-11-13 23:19:00.998 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:82 ]- NODE 27: Received Alarm Request
2015-11-13 23:19:00.998 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:94 ]- NODE 27: Alarm report - Value = 1
2015-11-13 23:19:00.999 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:112 ]- NODE 27: Alarm Type = RF UnLock (25)
2015-11-13 23:19:00.999 [DEBUG] [b.z.i.protocol.ZWaveController:616 ]- NODE 27: Notifying event listeners: ZWaveAlarmValueEvent: org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass$ZWaveAlarmValueEvent@4abad873
2015-11-13 23:35:41.575 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:82 ]- NODE 27: Received Alarm Request
2015-11-13 23:35:41.575 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:94 ]- NODE 27: Alarm report - Value = 1
2015-11-13 23:35:41.576 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:112 ]- NODE 27: Alarm Type = RF Lock (24)
2015-11-13 23:35:41.576 [DEBUG] [b.z.i.protocol.ZWaveController:616 ]- NODE 27: Notifying event listeners: ZWaveAlarmValueEvent: org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass$ZWaveAlarmValueEvent@6447138f
2015-11-13 23:36:21.577 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:82 ]- NODE 27: Received Alarm Request
2015-11-13 23:36:21.577 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:94 ]- NODE 27: Alarm report - Value = 1
2015-11-13 23:36:21.577 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:112 ]- NODE 27: Alarm Type = Manual UnLock (22)
2015-11-13 23:36:21.577 [DEBUG] [b.z.i.protocol.ZWaveController:616 ]- NODE 27: Notifying event listeners: ZWaveAlarmValueEvent: org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass$ZWaveAlarmValueEvent@5a40c712
2015-11-13 23:41:27.002 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:82 ]- NODE 27: Received Alarm Request
2015-11-13 23:41:27.002 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:94 ]- NODE 27: Alarm report - Value = 1
2015-11-13 23:41:27.002 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:112 ]- NODE 27: Alarm Type = RF Lock (24)
2015-11-13 23:41:27.002 [DEBUG] [b.z.i.protocol.ZWaveController:616 ]- NODE 27: Notifying event listeners: ZWaveAlarmValueEvent: org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass$ZWaveAlarmValueEvent@415552de
2015-11-14 00:54:57.906 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:82 ]- NODE 27: Received Alarm Request
2015-11-14 00:54:57.906 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:94 ]- NODE 27: Alarm report - Value = 1
2015-11-14 00:54:57.906 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:112 ]- NODE 27: Alarm Type = RF UnLock (25)
2015-11-14 00:54:57.906 [DEBUG] [b.z.i.protocol.ZWaveController:616 ]- NODE 27: Notifying event listeners: ZWaveAlarmValueEvent: org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass$ZWaveAlarmValueEvent@1d966f95
2015-11-14 01:00:04.397 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:82 ]- NODE 27: Received Alarm Request
2015-11-14 01:00:04.397 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:94 ]- NODE 27: Alarm report - Value = 1
2015-11-14 01:00:04.397 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:112 ]- NODE 27: Alarm Type = RF Lock (24)
2015-11-14 01:00:04.397 [DEBUG] [b.z.i.protocol.ZWaveController:616 ]- NODE 27: Notifying event listeners: ZWaveAlarmValueEvent: org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass$ZWaveAlarmValueEvent@5161dd28
2015-11-14 01:03:59.054 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:82 ]- NODE 27: Received Alarm Request
2015-11-14 01:03:59.054 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:94 ]- NODE 27: Alarm report - Value = 1
2015-11-14 01:03:59.054 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:112 ]- NODE 27: Alarm Type = RF UnLock (25)
2015-11-14 01:03:59.054 [DEBUG] [b.z.i.protocol.ZWaveController:616 ]- NODE 27: Notifying event listeners: ZWaveAlarmValueEvent: org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass$ZWaveAlarmValueEvent@6a93edf
2015-11-14 01:04:53.857 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:82 ]- NODE 27: Received Alarm Request
2015-11-14 01:04:53.857 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:94 ]- NODE 27: Alarm report - Value = 1
2015-11-14 01:04:53.857 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:112 ]- NODE 27: Alarm Type = RF Lock (24)
2015-11-14 01:04:53.857 [DEBUG] [b.z.i.protocol.ZWaveController:616 ]- NODE 27: Notifying event listeners: ZWaveAlarmValueEvent: org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass$ZWaveAlarmValueEvent@6c1f4adc
2015-11-14 07:41:46.780 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:82 ]- NODE 27: Received Alarm Request
2015-11-14 07:41:46.780 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:94 ]- NODE 27: Alarm report - Value = 1
2015-11-14 07:41:46.780 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:112 ]- NODE 27: Alarm Type = Manual UnLock (22)
2015-11-14 07:41:46.780 [DEBUG] [b.z.i.protocol.ZWaveController:616 ]- NODE 27: Notifying event listeners: ZWaveAlarmValueEvent: org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass$ZWaveAlarmValueEvent@1ba24a2f
2015-11-14 07:46:55.992 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:82 ]- NODE 27: Received Alarm Request
2015-11-14 07:46:55.992 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:94 ]- NODE 27: Alarm report - Value = 1
2015-11-14 07:46:55.992 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:112 ]- NODE 27: Alarm Type = RF Lock (24)
2015-11-14 07:46:55.992 [DEBUG] [b.z.i.protocol.ZWaveController:616 ]- NODE 27: Notifying event listeners: ZWaveAlarmValueEvent: org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass$ZWaveAlarmValueEvent@f8fe4ef
2015-11-14 09:21:12.008 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:82 ]- NODE 27: Received Alarm Request
2015-11-14 09:21:12.008 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:94 ]- NODE 27: Alarm report - Value = 1
2015-11-14 09:21:12.008 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:112 ]- NODE 27: Alarm Type = Manual UnLock (22)
2015-11-14 09:21:12.008 [DEBUG] [b.z.i.protocol.ZWaveController:616 ]- NODE 27: Notifying event listeners: ZWaveAlarmValueEvent: org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass$ZWaveAlarmValueEvent@14b91f9d
2015-11-14 09:22:34.038 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:82 ]- NODE 27: Received Alarm Request
2015-11-14 09:22:34.038 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:94 ]- NODE 27: Alarm report - Value = 1
2015-11-14 09:22:34.038 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:112 ]- NODE 27: Alarm Type = Keypad Unlock (19)
2015-11-14 09:22:34.038 [DEBUG] [b.z.i.protocol.ZWaveController:616 ]- NODE 27: Notifying event listeners: ZWaveAlarmValueEvent: org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass$ZWaveAlarmValueEvent@17e59e18
2015-11-14 09:26:45.744 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:82 ]- NODE 27: Received Alarm Request
2015-11-14 09:26:45.744 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:94 ]- NODE 27: Alarm report - Value = 2
2015-11-14 09:26:45.744 [DEBUG] [z.i.p.c.ZWaveAlarmCommandClass:112 ]- NODE 27: Alarm Type = Manual Lock (21)
2015-11-14 09:26:45.744 [DEBUG] [b.z.i.protocol.ZWaveController:616 ]- NODE 27: Notifying event listeners: ZWaveAlarmValueEvent: org.openhab.binding.zwave.internal.protocol.commandclass.ZWaveAlarmCommandClass$ZWaveAlarmValueEvent@6a529d2e
If you see, at 2015-11-14 09:21:12.008, the wife left for her morning run. Locked the door, then came back in (for something), then left again.
Detail:
There are 3 Alarms, captured, but there were actually 4 events. Between the “Manual unlock” and the “Keypad unlock” there should have been a “Touch Lock” Alarm. This is captured at other times, so the lock sends it, and I capture it. I’m assuming the binding missed it somehow (timing? not long between the unlock and the lock). Maybe the lock didn’t send it (but then we’re in La La land) - have to assume it did and we missed it.
Here is my openhab.log output (filtered to capture “Front Door” events - this captures the output of my rules (hopefully I’ve got all the bugs out of the rules).
09:21:12.010 [INFO ] [penhab.model.script.Front Door:53 ] - Door Lock Alarm Received: 1
09:21:12.011 [INFO ] [penhab.model.script.Front Door:53 ] - Door Lock Alarm 22 (Manual Unlock) Received: 1
09:21:12.013 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule 'Front Door Lock Notifications'
09:21:12.014 [INFO ] [o.model.script.Front Door Lock:53 ] - Front Door Lock trigger Value is: true
09:21:12.215 [INFO ] [o.model.script.Front Door Lock:53 ] - Front Door Lock Status updated to CONFIRMED Unlocked by: Manual Unlock
09:21:12.216 [INFO ] [penhab.model.script.Front Door:53 ] - Front Door Auto Unlock Cancelled (Door is already unlocked)
09:21:17.209 [INFO ] [penhab.model.script.Front Door:53 ] - Front Door Opened - sending Hallway Motion trigger
09:21:38.120 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule 'Autolock Front Door'
09:21:38.135 [INFO ] [penhab.model.script.Front Door:53 ] - Front Door Closed: Setting autolock timer
09:22:34.224 [INFO ] [penhab.model.script.Front Door:53 ] - Door Lock Alarm Received: 1
09:22:34.276 [INFO ] [penhab.model.script.Front Door:53 ] - Door Lock Alarm 19 (Keypad Unlock) User: 1
09:22:34.383 [INFO ] [penhab.model.script.Front Door:53 ] - Door Lock Alarm User: 1 is Nick/Jill
09:22:36.084 [INFO ] [penhab.model.script.Front Door:53 ] - Front Door Opened - sending Hallway Motion trigger
09:22:39.450 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule 'Autolock Front Door'
09:22:39.450 [INFO ] [penhab.model.script.Front Door:53 ] - Front Door Closed: Setting autolock timer
09:26:45.750 [INFO ] [penhab.model.script.Front Door:53 ] - Door Lock Alarm Received: 2
09:26:45.791 [INFO ] [penhab.model.script.Front Door:53 ] - Door Lock Alarm 21 (Manual Lock) Received: 2
09:26:45.816 [INFO ] [penhab.model.script.Front Door:53 ] - Door Lock Alarm 21 Touch Lock
09:26:45.950 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule 'Front Door Lock Notifications'
09:26:45.955 [INFO ] [o.model.script.Front Door Lock:53 ] - Front Door Lock trigger Value is: true
09:26:46.250 [INFO ] [o.model.script.Front Door Lock:53 ] - Front Door Lock Status updated to CONFIRMED Locked by: Touch Lock
09:26:46.252 [INFO ] [penhab.model.script.Front Door:53 ] - Front Door Auto Relock Cancelled (Door is already locked)
09:29:02.302 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule 'Presence Detection Unlock Front Door Jill'
10:49:33.441 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule 'Presence Detection Unlock Front Door Jill'
10:50:32.930 [INFO ] [penhab.model.script.Front Door:53 ] - Front Door Opened - sending Hallway Motion trigger
10:50:33.103 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule 'Front Door Lock Notifications'
10:50:33.180 [INFO ] [o.model.script.Front Door Lock:53 ] - Front Door Lock trigger Value is: false
10:50:34.239 [INFO ] [o.model.script.Front Door Lock:53 ] - Front Door Lock Status updated to CONFIRMED Unlocked
10:50:34.655 [INFO ] [penhab.model.script.Front Door:53 ] - Front Door Auto Unlock Cancelled (Door is already unlocked)
10:50:37.002 [DEBUG] [m.r.internal.engine.RuleEngine:305 ] - Executing rule 'Autolock Front Door'
10:50:37.030 [INFO ] [penhab.model.script.Front Door:53 ] - Front Door Closed: Setting autolock timer
10:55:37.520 [INFO ] [penhab.model.script.Front Door:53 ] - Front Door Locked by: Auto
You can see the missed “Touch Lock” here (ie there should be two, but there is only one). Other triggers work well though. There is only one missed trigger in the list today (she got back at 10:50). There should have been an unlock at 10:50:32.930, but I had just updated my rules, so that is captured in a “lock initialize” rule, but I did get the notification (just in case you’re wondering how she opened a locked door).
Right now, after leaving it overnight, everything is working normally, and lock is working well. The lock is sometimes fast (4 seconds) sometimes slow (up to 30 seconds or more) - seems to be waiting for the “nonce” security hash I guess.
Once I’m happy that it’s stable (no more fiddling/restarts), I’ll capture some logs of normal operation, then (fingers crossed) I’ll restart openhab, and capture the startup logs - this seems to be the most problematical part of the whole thing. Once everything is going, all is well, getting everything going…
If we can get the ALARM capture to 100% I can reduce polling to a minimum, and that should reduce traffic to/from the lock. The big delay seems to be the “nonce” handshake, and as a the lock mostly sits there and does nothing, but does need to wake up, handshake, and respond quickly, this may be the main problem.
Battery is reporting (not sure how often, I’m not polling), and it’s up to 71% now (from 70%) - maybe just minor fluctuations (these are not new batteries, from the old lock, which initially reported at 75% 2 days ago - but I have been testing a lot).
Aeon sensors are still at 100% - so that may not have been related. The one that was dropping (was 85% is now up to 91% climbed slowly yesterday 1% at a time). Weird.
I now have an Aeon ZSD37-ZW Range Extender a couple of feet from the lock. Not sure if it’s doing anything, but it can’t hurt.
I’ll post some logs later this afternoon.
