Update looks fine - thanks.
Awesome, thanks. Iām still working to get my IDE set up. Any chance you are planning to post a new binding JAR with the latest DB anytime soon?
Yes - I will do one tonight.
Hi Chris, really sorry to pester you, I was just wondering if you were still planning to do this some time soon. If not, Iām happy to get my IDE set up and figure out how to compile with the latest DB myself.
Thanks, Danny
Probably not now until next weekend. What are you after? It was updated last, on the night I said I would (ie 4 days ago now).
You can always find the latest version in following thread -:
Oh, I didnāt realize. I guess I was expecting a post in this thread. I was just after the update that I made to YRD210 to expose the alarm_raw value.
Iāll download the latest JAR and try it out.
Hello everyone,
Another newbie here. So Iāve read and Iāve read all these posts regarding secure inclusion and I cannot get my smart lock to work with OH2. I have a Nortek/GoControl HUSBZB-1 stick and a Schlage Connect BE469WK.
So far Iāve tried a fresh new install and all the snapshots mentioned in this post. I also installed the serial transport in karaf console. Right now Iām using:
230 ā Active ā 80 ā 2.3.0.201802082157 ā ZWave Binding
I tried using low power, high power and network wide inclusion. No matter how many times I exclude the darn lock, it refuses to pair securely.
I also tried using the zensys tool. Factory reset the smart lock, hardware reset the stick, stand on one leg and crossed my fingers and nothing has worked.
The error that I get in the logs is:
2018-02-12 23:33:25.746 [INFO ] [alization.ZWaveNodeInitStageAdvancer] - NODE 4: SECURITY_INC State=FAILED, Reason=GET_SCHEME
Any help would be appreciated.
Thanks.
I had this get_scheme error thing at some point.
Finally I tried with my receiver under a meter away, high power, secure inclusion mode set to all devices, firmware reset on the lock, exclude and include in habmin.
The first time it didnāt work with this either, but I tried changing network security key and did it again and then it worked.
Also I thought I would set the secure inclusion mode back to entry control devices, but then it stopped working so I guess Iāll leave it alone.
Blahbla,
We shouldnāt have to jump thru so many hoops to get the lock to pair with the stick, so there must be a bug somewhere in the code. The lock pairs fine with other zwave hubs (ST Hub), so we should aim for OH to have the same quality.
If the developers want, Iām willing to help to root cause the issue, by testing and providing whatever information they need. Just tell me what to try and what info logs to provide.
I thought you said earlier that you also tried using the Zensys software and that didnt work?
If what you have written here is really the case, then I think the issue is not with openHAB?
Of course, help is always greatly received. Itās not a simple issue to resolve as by nature security issues devices may simply not reply. However you can use the log viewer to help debug the problem
Hi Chris,
I tried the zensys tool and it pairs fine with the lock, at least it looks like it. I even tried pairing it with zensys first, then moving the stick to OH and did the inclusion in OH and it still did not pair. But like I said, Iām new to this so maybe I did the zensys thing wrong.
So I guess there are three things to rule out here:
- The stick
- The lock
- OH
Hopefully we can use Zensys to rule out the stick and/or the lock, but i really dont know how to use Zensys all that well. Is there a set of instructions that I should follow or a tutorial somewhere that explains how I should pair with Zensys first? and maybe then move the stick to OH to see if it works that way?
What do you mean by this? It sounds like you are doing the inclusion twice? If you do the key exchange with the Zensys tool, then you do not need to include it again on OH. You must only try and include it once.
I have never used the Zensys tool so I canāt comment on this - sorry.
To be honest, Iām still not really sure what you are doing. The secure inclusion is VERY particular about what you have to do, and how quickly it needs to be done. If itās not performed correctly, then it will fail (welcome to the world of security ).
Please can you clearly state step by step what you have done when including the lock. Sorry to sound like Iām being difficult, but secure inclusion can be difficult.
Also, please check the logs, or if not, please provide the logs so they can be checked to see what is going on.
How can I go about adding tonnes of debugging to the zwave module for inclusion/exclusion?
When I use Habmin, it doesnt seem to do anything except say this in the logs:
2018-02-17 14:58:28.503 [arthome.event.BindingEvent] - org.openhab.binding.zwave.event.BindingEvent@43326675
My yale lock YRD240 didnt have any impact when I tried to add or remove the device.
I guess youād need to compile the binding yourself if you want to add debug. There is information on setting up the IDE in the documentation.
If you just want to see the existing debug, then just enable debug level logging with the set:log debug org.openhab.binding.zwave
command (as in the documentation ).
It looks like this may be from the event.log file, with a default setup. Set the zwave binding to debug log:set DEBUG org.openhab.binding.zwave) and tail the openhab.log file. There are lots of posts about this (sorryā¦ on phone).
Also, when you used Zensys, did you set a security key or use the one provided. If the latter, make sure to be using the same key in OH.
Hi Chris,
Sorry for the delay, but I finally got some time to try again but this time I got the lock to work with OH, however, the only way i can get it to work is by pairing it with Zensys tool or Axial server first, then moving the zwave stick to my OH raspberry PI. So far Iāve tried with two Schlage Connect locks and I got the same results. I always have to pair with another zwave hub first. So this rules out everything except for OH2.
Suggestions?
Maybe, but youāve not really said what youāre doing, and maybe checked the logs to see what is happening.
Make sure the device is reset before include, then check the logs to see what is happening.
Hi Chris, So this is what I did:
- shutdown OH2
- factory reset the Schlage Connect
- took my HUSBZB-1 USB Stick and plugged into my windows PC
- launched Axial Server (30-day trial version) and copied the security key from OH2 to Axial. Saved Settings.
- Reset the USB stick using Axial
- set the stick to exclusion mode and excluded the door lock by doing the programming instructions on the keypad and I got a green check mark (door lock confirmation that it succeeded excluding from the stick)
- factory reset the Schlage Connect again
- Set Axial to inclusion mode and the door lock showed up in Axial. I was able to manage it with Axial.
- I closed Axial and moved the USB stick back to OH2
- In Habmin, the lock showed up in Inbox, I didnāt have to search for it.
- I added it from inbox and it worked fine.
If i repeat the above procedure with OH2 and the latest zwave binding, it never succeeds doing the secure binding. And Like I said, I tried with two door locks (identical Schlage Connect Bronze).
As I said, I canāt really comment without seeing the logs - sorry - but really this doesnāt provide a lot to go on.
Please also provide the version - just so we are sure about what this is to avoid confusion.
