- Platform information:
- OS: Debian 9.4 64-bit
- Java Runtime Environment: openjdk version “1.8.0_181” OpenJDK Runtime Environment (build 1.8.0_181-8u181-b13-1~deb9u1-b13)
- openHAB version: 2.3.0
- z-wave version: 2.4.0.201809081506
- z-wave controller: aeotec gen5
Hi all!
I have a pretty small z-wave network with only 4 nodes and its great compared to the 433 Mhz. But the latest addition to the network (Node 6, MCO Home MH9-CO2 Sensor) started to mess things up (i think the sensor is the cause but I cant be certain). The network was working great but after some time the CO2-sensor gets stuck and doesn’t report any more values. But the sensor is not reported as dead.
This has happened a couple of times and the first time I had some missconfigs I thought was the cause for this problem (yes, I’m a z-wave/openhab noob ). But here we are some weeks later and the problem has occurred once again.
The first log is the last report from the sensor (no cuts):
12-Dec-2018 00:00:46.885 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 6: Application Command Request (ALIVE:DONE)
12-Dec-2018 00:00:46.885 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 6: resetResendCount initComplete=true isDead=false
12-Dec-2018 00:00:46.885 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 6: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
12-Dec-2018 00:00:46.885 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 6: SECURITY not supported
12-Dec-2018 00:00:46.885 [DEBUG] [e.internal.protocol.commandclass.ZWaveCommandClass] - NODE 6: Received COMMAND_CLASS_SENSOR_MULTILEVEL V5 SENSOR_MULTILEVEL_REPORT
12-Dec-2018 00:00:46.885 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 6: Sensor Type = CO2(17), Scale = 0
12-Dec-2018 00:00:46.886 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 6: Sensor Value = 804
12-Dec-2018 00:00:46.886 [TRACE] [ab.binding.zwave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
12-Dec-2018 00:00:46.886 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
12-Dec-2018 00:00:46.886 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_SENSOR_MULTILEVEL, value = 804
12-Dec-2018 00:00:46.886 [DEBUG] [.internal.converter.ZWaveMultiLevelSensorConverter] - NODE 6: Sensor conversion not performed for CO2.
12-Dec-2018 00:00:46.886 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Updating channel state zwave:device:dd005807:node6:sensor_co2 to 804 [DecimalType]
12-Dec-2018 00:00:46.886 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 6: Commands processed 1.
12-Dec-2018 00:00:46.888 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 6: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@6e4d1bbf.
12-Dec-2018 00:00:46.888 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
12-Dec-2018 00:00:46.889 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
12-Dec-2018 00:00:46.889 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
12-Dec-2018 00:00:46.889 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
12-Dec-2018 00:00:46.889 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
12-Dec-2018 00:11:26.771 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling...
12-Dec-2018 00:11:26.772 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling zwave:device:dd005807:node6:sensor_temperature
12-Dec-2018 00:11:26.772 [DEBUG] [.internal.converter.ZWaveMultiLevelSensorConverter] - NODE 6: Generating poll message for COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
12-Dec-2018 00:11:26.772 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 6: Creating new message for command SENSOR_MULTILEVEL_GET
12-Dec-2018 00:11:26.772 [TRACE] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 6: Encapsulating message, endpoint 0
12-Dec-2018 00:11:26.772 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 6: SECURITY not supported
12-Dec-2018 00:11:26.772 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 6: Command Class COMMAND_CLASS_SENSOR_MULTILEVEL is NOT required to be secured
12-Dec-2018 00:11:26.772 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling zwave:device:dd005807:node6:sensor_relhumidity
12-Dec-2018 00:11:26.773 [TRACE] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 6: Encapsulating message, endpoint 0
12-Dec-2018 00:11:26.773 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 6: SECURITY not supported
12-Dec-2018 00:11:26.773 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 6: Command Class COMMAND_CLASS_SENSOR_MULTILEVEL is NOT required to be secured
12-Dec-2018 00:11:26.773 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling zwave:device:dd005807:node6:sensor_co2
12-Dec-2018 00:11:26.773 [DEBUG] [.internal.converter.ZWaveMultiLevelSensorConverter] - NODE 6: Generating poll message for COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 0
12-Dec-2018 00:11:26.773 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 6: Creating new message for command SENSOR_MULTILEVEL_GET
12-Dec-2018 00:11:26.774 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 6: Adding to device queue
12-Dec-2018 00:11:26.774 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 6: Added to queue - size 1
12-Dec-2018 00:11:26.774 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
12-Dec-2018 00:11:26.774 [TRACE] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 6: listening == true, frequentlyListening == false, awake == false
12-Dec-2018 00:11:26.774 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction from sendQueue
12-Dec-2018 00:11:26.774 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - getTransactionToSend 6
12-Dec-2018 00:11:26.774 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 6: Creating empty message of class = SendData (0x13), type = Request
12-Dec-2018 00:11:26.774 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Calculated checksum = 47
12-Dec-2018 00:11:26.774 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0B 00 13 06 04 31 04 01 00 25 DB 2F
12-Dec-2018 00:11:26.775 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 6: Sending REQUEST Message = 01 0B 00 13 06 04 31 04 01 00 25 DB 2F
12-Dec-2018 00:11:26.935 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - Message SENT
12-Dec-2018 00:11:26.935 [TRACE] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 8481: Transaction Start type SendData
12-Dec-2018 00:11:26.935 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 8481: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 219
12-Dec-2018 00:11:26.935 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd class: COMMAND_CLASS_SENSOR_MULTILEVEL
12-Dec-2018 00:11:26.936 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd: 5
12-Dec-2018 00:11:26.936 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage Transactions outstanding: 1
12-Dec-2018 00:11:26.936 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
12-Dec-2018 00:11:26.937 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 06
12-Dec-2018 00:11:26.937 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
12-Dec-2018 00:11:26.937 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
12-Dec-2018 00:11:26.937 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
12-Dec-2018 00:11:26.937 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction null
12-Dec-2018 00:11:26.937 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg: ACK
12-Dec-2018 00:11:26.937 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
12-Dec-2018 00:11:26.938 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Dec 12 00:11:28 CET 2018 - 2000ms
12-Dec-2018 00:11:26.938 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage lastTransaction: TID 8481: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 219
12-Dec-2018 00:11:26.938 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
12-Dec-2018 00:11:26.938 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
12-Dec-2018 00:11:26.938 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - STOP transaction timer
12-Dec-2018 00:11:26.939 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Dec 12 00:11:28 CET 2018 - 1999ms
12-Dec-2018 00:11:26.939 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - STOP transaction timer
12-Dec-2018 00:11:26.939 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 6: Adding to device queue
12-Dec-2018 00:11:26.939 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 6: Added to queue - size 1
12-Dec-2018 00:11:26.940 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
12-Dec-2018 00:11:26.940 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
12-Dec-2018 00:11:26.940 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - STOP transaction timer
12-Dec-2018 00:11:26.940 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Dec 12 00:11:28 CET 2018 - 1998ms
12-Dec-2018 00:11:26.941 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 6: Adding to device queue
12-Dec-2018 00:11:26.941 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 6: Added to queue - size 2
12-Dec-2018 00:11:26.941 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
12-Dec-2018 00:11:26.941 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Received SOF
12-Dec-2018 00:11:26.942 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
12-Dec-2018 00:11:26.942 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - STOP transaction timer
12-Dec-2018 00:11:26.942 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Dec 12 00:11:28 CET 2018 - 1996ms
12-Dec-2018 00:11:26.951 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
12-Dec-2018 00:11:26.951 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 04 01 13 01 E8
12-Dec-2018 00:11:26.952 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Calculated checksum = -24
12-Dec-2018 00:11:26.952 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
12-Dec-2018 00:11:26.952 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Message payload = 01
12-Dec-2018 00:11:26.952 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
12-Dec-2018 00:11:26.953 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
12-Dec-2018 00:11:26.953 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
12-Dec-2018 00:11:26.953 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
12-Dec-2018 00:11:26.953 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
12-Dec-2018 00:11:26.953 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction TID 8481: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 219
12-Dec-2018 00:11:26.954 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
12-Dec-2018 00:11:26.954 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Last transaction: TID 8481: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 219
12-Dec-2018 00:11:26.954 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
12-Dec-2018 00:11:26.954 [TRACE] [ab.binding.zwave.internal.protocol.ZWaveController] - Incoming Message type = RESPONSE
12-Dec-2018 00:11:26.954 [TRACE] [ternal.protocol.serialmessage.SendDataMessageClass] - Handle Message Send Data Response
12-Dec-2018 00:11:26.954 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 6: sentData successfully placed on stack.
12-Dec-2018 00:11:26.954 [TRACE] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 8481: TransactionAdvance ST: WAIT_RESPONSE
12-Dec-2018 00:11:26.954 [TRACE] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 8481: TransactionAdvance WT: ApplicationCommandHandler {}
12-Dec-2018 00:11:26.954 [TRACE] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 8481: TransactionAdvance RX: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
12-Dec-2018 00:11:26.954 [TRACE] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 8481: TransactionAdvance TO: WAIT_REQUEST
12-Dec-2018 00:11:26.955 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - TID 8481: Advanced to WAIT_REQUEST
12-Dec-2018 00:11:26.955 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 6: TID 8481: Transaction not completed
12-Dec-2018 00:11:26.955 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
12-Dec-2018 00:11:26.955 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
12-Dec-2018 00:11:26.955 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
12-Dec-2018 00:11:26.955 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - STOP transaction timer
12-Dec-2018 00:11:26.955 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Start transaction timer to Wed Dec 12 00:11:31 CET 2018 - 5000ms
12-Dec-2018 00:11:26.959 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Received SOF
12-Dec-2018 00:11:26.971 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 DB 00 00 02 32
12-Dec-2018 00:11:26.971 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 07 00 13 DB 00 00 02 32
12-Dec-2018 00:11:26.971 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Calculated checksum = 50
12-Dec-2018 00:11:26.972 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
12-Dec-2018 00:11:26.972 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 0: Message payload = DB 00 00 02
12-Dec-2018 00:11:26.972 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
12-Dec-2018 00:11:26.974 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
12-Dec-2018 00:11:26.974 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=219, payload=DB 00 00 02
12-Dec-2018 00:11:26.975 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - processReceiveMessage past lock Message: class=SendData[19], type=Request[0], dest=0, callback=219, payload=DB 00 00 02
12-Dec-2018 00:11:26.975 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=219, payload=DB 00 00 02
12-Dec-2018 00:11:26.975 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - lastTransaction TID 8481: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 219
12-Dec-2018 00:11:26.976 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
12-Dec-2018 00:11:26.976 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Last transaction: TID 8481: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 219
12-Dec-2018 00:11:26.976 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Checking TID 8481: (Callback 219)
12-Dec-2018 00:11:26.976 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Callback match!
12-Dec-2018 00:11:26.977 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Correlated to TID 8481: callback 219
12-Dec-2018 00:11:26.977 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=219, payload=DB 00 00 02
12-Dec-2018 00:11:26.977 [TRACE] [ab.binding.zwave.internal.protocol.ZWaveController] - Incoming Message type = REQUEST
12-Dec-2018 00:11:26.977 [TRACE] [ternal.protocol.serialmessage.SendDataMessageClass] - Handle Message Send Data Request
12-Dec-2018 00:11:26.978 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 6: SendData Request. CallBack ID = 219, Status = Transmission complete and ACK received(0)
12-Dec-2018 00:11:26.978 [DEBUG] [.openhab.binding.zwave.internal.protocol.ZWaveNode] - NODE 6: resetResendCount initComplete=true isDead=false
12-Dec-2018 00:11:26.978 [TRACE] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 8481: TransactionAdvance ST: WAIT_REQUEST
12-Dec-2018 00:11:26.978 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Received SOF
12-Dec-2018 00:11:26.978 [TRACE] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 8481: TransactionAdvance WT: ApplicationCommandHandler {}
12-Dec-2018 00:11:26.979 [TRACE] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 8481: TransactionAdvance RX: Message: class=SendData[19], type=Request[0], dest=0, callback=219, payload=DB 00 00 02
12-Dec-2018 00:11:26.979 [TRACE] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 8481: TransactionAdvance RQ: RREQ=true, RCLS=ApplicationCommandHandler
12-Dec-2018 00:11:26.979 [TRACE] [b.binding.zwave.internal.protocol.ZWaveTransaction] - TID 8481: TransactionAdvance TO: WAIT_DATA
12-Dec-2018 00:11:26.980 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - TID 8481: Advanced to WAIT_DATA
12-Dec-2018 00:11:26.980 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 6: TID 8481: Transaction not completed
12-Dec-2018 00:11:26.980 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
12-Dec-2018 00:11:26.980 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
12-Dec-2018 00:11:26.981 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
12-Dec-2018 00:11:26.981 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - STOP transaction timer
This is a couple of hours later and this is whats happens from now on. The unit and another node (Node 5, a Fibaro dimmer2 that seems to be working as it should) reports “Polling deferred until initialisation complete”
12-Dec-2018 07:07:54.411 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 1: Node Init response (0) org.openhab.binding.zwave.internal.protocol.ZWaveTransactionResponse@2da94f10
12-Dec-2018 07:11:26.771 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling...
12-Dec-2018 07:11:26.771 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 6: Polling deferred until initialisation complete
12-Dec-2018 07:13:21.846 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling...
12-Dec-2018 07:13:21.846 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 5: Polling deferred until initialisation complete
12-Dec-2018 07:19:08.221 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: sendTransaction org.openhab.binding.zwave.internal.protocol.ZWaveSerialPayload@19896ca0
12-Dec-2018 07:19:08.221 [DEBUG] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Adding to device queue
12-Dec-2018 07:19:08.222 [TRACE] [ng.zwave.internal.protocol.ZWaveTransactionManager] - NODE 4: Added to queue - size 1
Help is much appreciated!
