I have a strange issue with my fibaro single switch. There is sometimes a large latency in receiving commands.
I acivated the Debug-Log, but I’m not sure if there is something unnormal.
2019-02-13 20:54:07.020 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Polling...
2019-02-13 20:54:07.024 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Polling zwave:device:5668fa7e:node36:meter_watts
2019-02-13 20:54:07.027 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 36: Generating poll message for COMMAND_CLASS_METER, endpoint 0
2019-02-13 20:54:07.029 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 36: Generating poll message for COMMAND_CLASS_METER, endpoint 0
2019-02-13 20:54:07.032 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 36: Creating new message for application command METER_GET
2019-02-13 20:54:07.035 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: SECURITY NOT required on COMMAND_CLASS_METER
2019-02-13 20:54:07.037 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: Command Class COMMAND_CLASS_METER is NOT required to be secured
2019-02-13 20:54:07.040 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Polling zwave:device:5668fa7e:node36:meter_kwh
2019-02-13 20:54:07.042 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 36: Generating poll message for COMMAND_CLASS_METER, endpoint 0
2019-02-13 20:54:07.044 [DEBUG] [ternal.converter.ZWaveMeterConverter] - NODE 36: Generating poll message for COMMAND_CLASS_METER, endpoint 0
2019-02-13 20:54:07.047 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 36: Creating new message for application command METER_GET
2019-02-13 20:54:07.049 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: SECURITY NOT required on COMMAND_CLASS_METER
2019-02-13 20:54:07.052 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: Command Class COMMAND_CLASS_METER is NOT required to be secured
2019-02-13 20:54:07.054 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Polling zwave:device:5668fa7e:node36:switch_binary1
2019-02-13 20:54:07.056 [DEBUG] [converter.ZWaveBinarySwitchConverter] - NODE 36: Generating poll message for COMMAND_CLASS_SWITCH_BINARY, endpoint 1
2019-02-13 20:54:07.059 [DEBUG] [dclass.ZWaveBinarySwitchCommandClass] - NODE 36: Creating new message for application command SWITCH_BINARY_GET
2019-02-13 20:54:07.061 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: Encapsulating message, instance / endpoint 1
2019-02-13 20:54:07.063 [DEBUG] [class.ZWaveMultiInstanceCommandClass] - NODE 36: Creating new message for command MULTI_CHANNEL_ENCAP endpoint 1
2019-02-13 20:54:07.066 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: SECURITY NOT required on COMMAND_CLASS_MULTI_CHANNEL
2019-02-13 20:54:07.068 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: Command Class COMMAND_CLASS_MULTI_CHANNEL is NOT required to be secured
2019-02-13 20:54:07.070 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Polling skipped for zwave:device:5668fa7e:node36:switch_binary1 on COMMAND_CLASS_BASIC
2019-02-13 20:54:07.073 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Adding to device queue
2019-02-13 20:54:07.075 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Added 450 to queue - size 36
2019-02-13 20:54:07.078 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-13 20:54:07.082 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 24 03 32 01 10 25 45 82
2019-02-13 20:54:07.085 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 36: Sending REQUEST Message = 01 0A 00 13 24 03 32 01 10 25 45 82
2019-02-13 20:54:07.090 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-02-13 20:54:07.093 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-02-13 20:54:07.096 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-02-13 20:54:07.098 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-02-13 20:54:07.099 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2019-02-13 20:54:07.100 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-02-13 20:54:07.102 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-13 20:54:07.111 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-02-13 20:54:07.113 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 450: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 69
2019-02-13 20:54:07.115 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-13 20:54:07.117 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Adding to device queue
2019-02-13 20:54:07.118 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Added 451 to queue - size 36
2019-02-13 20:54:07.119 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-13 20:54:07.121 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Adding to device queue
2019-02-13 20:54:07.123 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Added 452 to queue - size 37
2019-02-13 20:54:07.124 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-13 20:54:07.142 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-13 20:54:07.143 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-13 20:54:07.144 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 45 00 00 02 AC
2019-02-13 20:54:07.145 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 450: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 69
2019-02-13 20:54:07.147 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-02-13 20:54:07.149 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 450: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 69
2019-02-13 20:54:07.151 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-13 20:54:07.153 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 36: sentData successfully placed on stack.
2019-02-13 20:54:07.154 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 450: Advanced to WAIT_REQUEST
2019-02-13 20:54:07.156 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: TID 450: Transaction not completed
2019-02-13 20:54:07.158 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-13 20:54:07.159 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-13 20:54:07.172 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=69, payload=45 00 00 02
2019-02-13 20:54:07.173 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=69, payload=45 00 00 02
2019-02-13 20:54:07.174 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0E 00 04 00 24 08 32 02 21 32 00 00 00 00 FA
2019-02-13 20:54:07.176 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 450: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 69
2019-02-13 20:54:07.178 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-02-13 20:54:07.180 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 450: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 69
2019-02-13 20:54:07.182 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 450: (Callback 69)
2019-02-13 20:54:07.183 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2019-02-13 20:54:07.185 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 450: callback 69
2019-02-13 20:54:07.187 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=69, payload=45 00 00 02
2019-02-13 20:54:07.189 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 36: SendData Request. CallBack ID = 69, Status = Transmission complete and ACK received(0)
2019-02-13 20:54:07.190 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: resetResendCount initComplete=true isDead=false
2019-02-13 20:54:07.192 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 450: Advanced to WAIT_DATA
2019-02-13 20:54:07.194 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: TID 450: Transaction not completed
2019-02-13 20:54:07.195 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-13 20:54:07.197 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-13 20:54:07.202 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=36, callback=0, payload=00 24 08 32 02 21 32 00 00 00 00
2019-02-13 20:54:07.204 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=36, callback=0, payload=00 24 08 32 02 21 32 00 00 00 00
2019-02-13 20:54:07.206 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-02-13 20:54:07.208 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Application Command Request (ALIVE:DONE)
2019-02-13 20:54:07.210 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: resetResendCount initComplete=true isDead=false
2019-02-13 20:54:07.212 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: Incoming command class COMMAND_CLASS_METER, endpoint 0
2019-02-13 20:54:07.214 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: SECURITY NOT required on COMMAND_CLASS_METER
2019-02-13 20:54:07.216 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 36: Received COMMAND_CLASS_METER V3 METER_REPORT
2019-02-13 20:54:07.218 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 36: Meter: Type=Electric(1), Scale=W(2), Value=0E+1
2019-02-13 20:54:07.219 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Got an event from Z-Wave network: ZWaveMeterValueEvent
2019-02-13 20:54:07.221 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_METER, value = 0E+1
2019-02-13 20:54:07.223 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Updating channel state zwave:device:5668fa7e:node36:meter_watts to 0 [DecimalType]
2019-02-13 20:54:07.226 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Commands processed 1.
2019-02-13 20:54:07.228 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1129881.
2019-02-13 20:54:07.230 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@1129881.
2019-02-13 20:54:07.233 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: notifyTransactionResponse TID:450 DONE
2019-02-13 20:54:07.235 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2019-02-13 20:54:07.237 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2019-02-13 20:54:07.239 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-02-13 20:54:07.241 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-13 20:54:07.242 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-13 20:54:07.245 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 24 03 32 01 00 25 46 91
2019-02-13 20:54:07.247 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 36: Sending REQUEST Message = 01 0A 00 13 24 03 32 01 00 25 46 91
2019-02-13 20:54:07.251 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2019-02-13 20:54:07.253 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-02-13 20:54:07.256 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2019-02-13 20:54:07.271 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-02-13 20:54:07.273 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 451: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 70
2019-02-13 20:54:07.275 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=null[0], type=ACK[2], dest=255, callback=0, payload=
2019-02-13 20:54:07.277 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 451: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 70
2019-02-13 20:54:07.279 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2019-02-13 20:54:07.281 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-13 20:54:07.282 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-13 20:54:07.302 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-13 20:54:07.304 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-13 20:54:07.304 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 46 00 00 02 AF
2019-02-13 20:54:07.306 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 451: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 70
2019-02-13 20:54:07.307 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-02-13 20:54:07.309 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 451: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 70
2019-02-13 20:54:07.311 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Response[1], dest=255, callback=0, payload=01
2019-02-13 20:54:07.313 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 36: sentData successfully placed on stack.
2019-02-13 20:54:07.315 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 451: Advanced to WAIT_REQUEST
2019-02-13 20:54:07.316 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: TID 451: Transaction not completed
2019-02-13 20:54:07.318 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-13 20:54:07.320 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-13 20:54:07.332 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=SendData[19], type=Request[0], dest=0, callback=70, payload=46 00 00 02
2019-02-13 20:54:07.334 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=SendData[19], type=Request[0], dest=0, callback=70, payload=46 00 00 02
2019-02-13 20:54:07.335 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 24 0A 32 02 21 44 00 00 02 DA 00 00 48
2019-02-13 20:54:07.335 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 451: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 70
2019-02-13 20:54:07.338 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2019-02-13 20:54:07.339 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 451: [WAIT_REQUEST] priority=Get, requiresResponse=true, callback: 70
2019-02-13 20:54:07.341 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 451: (Callback 70)
2019-02-13 20:54:07.343 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2019-02-13 20:54:07.345 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 451: callback 70
2019-02-13 20:54:07.347 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=SendData[19], type=Request[0], dest=0, callback=70, payload=46 00 00 02
2019-02-13 20:54:07.348 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 36: SendData Request. CallBack ID = 70, Status = Transmission complete and ACK received(0)
2019-02-13 20:54:07.350 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: resetResendCount initComplete=true isDead=false
2019-02-13 20:54:07.352 [DEBUG] [nal.protocol.ZWaveTransactionManager] - TID 451: Advanced to WAIT_DATA
2019-02-13 20:54:07.354 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: TID 451: Transaction not completed
2019-02-13 20:54:07.356 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-13 20:54:07.359 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 1 out at start. Holdoff false.
2019-02-13 20:54:07.362 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=36, callback=0, payload=00 24 0A 32 02 21 44 00 00 02 DA 00 00
2019-02-13 20:54:07.365 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=36, callback=0, payload=00 24 0A 32 02 21 44 00 00 02 DA 00 00
2019-02-13 20:54:07.367 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2019-02-13 20:54:07.369 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Application Command Request (ALIVE:DONE)
2019-02-13 20:54:07.370 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: resetResendCount initComplete=true isDead=false
2019-02-13 20:54:07.372 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: Incoming command class COMMAND_CLASS_METER, endpoint 0
2019-02-13 20:54:07.377 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 36: SECURITY NOT required on COMMAND_CLASS_METER
2019-02-13 20:54:07.378 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 36: Received COMMAND_CLASS_METER V3 METER_REPORT
2019-02-13 20:54:07.380 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 36: Meter: Type=Electric(1), Scale=kWh(0), Value=7.3
2019-02-13 20:54:07.382 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Got an event from Z-Wave network: ZWaveMeterValueEvent
2019-02-13 20:54:07.384 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Got a value event from Z-Wave network, endpoint = 0, command class = COMMAND_CLASS_METER, value = 7.3
2019-02-13 20:54:07.386 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Updating channel state zwave:device:5668fa7e:node36:meter_kwh to 7.3 [DecimalType]
2019-02-13 20:54:07.388 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Commands processed 1.
2019-02-13 20:54:07.390 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@113a2aa.
2019-02-13 20:54:07.393 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: Command verified org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@113a2aa.
2019-02-13 20:54:07.395 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 36: notifyTransactionResponse TID:451 DONE
2019-02-13 20:54:07.397 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 36: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
2019-02-13 20:54:07.399 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 1
2019-02-13 20:54:07.401 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2019-02-13 20:54:07.403 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2019-02-13 20:54:07.405 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2019-02-13 20:54:07.408 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0D 00 13 24 06 60 0D 01 01 25 02 25 47 EB
2019-02-13 20:54:07.410 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 36: Sending REQUEST Message = 01 0D 00 13 24 06 60 0D 01 01 25 02 25 47 EB
2019-02-13 20:54:07.415 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 10 0A 60 0D 01 01 31 05 04 22 00 00 8E
2019-02-13 20:54:07.441 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2019-02-13 20:54:07.443 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 452: [WAIT_RESPONSE] priority=Get, requiresResponse=true, callback: 71
