ok I put in a 3sec. “Interval” whit habadmin ind one of the newer power plugs
så now it`s working ok 3 sec. i can wait for my extra screen and some lights
to come on agin after computer standby.
It does fill a lot in the log but what to do ?
so now i can move on to do some realy nice things whit this knowledge ,this was realy
just a little test to make it work on some think closeby.
Like any other Thing you set up in PaperUI, you look to see the available options in PaperUI. If there’s an “advanced options” button or suchlike, you might click that.
That’s the one. When the binding sends a command to your device, it follows it a short time later with a poll. If your device has updated its power readings in response to the command, you might get a new reading then.
What do you mean? It’s working now?
If not, make it longer - say 3000mS.
No. If it is getting polled too quickly for the device power meter to have changed in response to the last command it had, then reducing the time won’t help.
Well, if you can get that working, then you can set your binding polling back to a very long time, and your device reporting back to a long time, and reduce the traffic on your zwave network
