I have now added these 2 scribts on the syno, in the docker container i have now the same rights (crw-rw---- 1 root dialout 166, 0 Feb 26 09:40 /dev/ttyACM0) but i have not the openhab user on the synology, the openhab user is only in the container, in the docker container i have added the user to the groups, but the problem is the same, i will try today to give the stick on the synology full acces ( chmod 777 /dev/ttyAM0)
chmod 777 /dev/ttyAM0 on the synology solved my problem
Now the z-wave stick works in Docker
Does this work for you even after a restart of the Synology host or do you have to execute the chmod command after every DSM reboot?
That’s what I’m experiencing . Any solution to make it persistent?
This was working, but when i has stopped the container and startet it, the zwave stick was not working anymore, then you need to restart the synology, than i had to run the commando always after a DSM reboot.
It was a great experience with docker, but there were always such small issues.
It was never so easy to expand the system with new sticks etc., so i have installed openhab on a raspberry pi.
Thx for your reply @mpuff
Just stopping and starting the container works for me.
But after each DSM restart I have to execute the chmod command again.
So I think I have to start looking for some config to make this persistent. Maybe udev rules are a way to go…
So just for reference, this is what works for my setup now for several hours with some restarts
Hi all,
I am also struggling with the Aeotec Gen5 USB stick.
chmod 777 /dev/ttyACM0 helps for me; but doing that after each restart is not a solution.
The udev rule is great - but somehow it is not working for me. After each restart the stick is still dev/ttyACM0 and not “USBzwave”
I did not create the homeautomation group and therefore removed the “GROUP=homeautomation” part in the rules-file.
Is this necessary? If yes; how do I add user root the group? Any other hints what I might do wrong?
Thanks in advance
I probably have the same problem that was solved here a year and a half ago.
Unfortunately my technical understanding is at the level that is assumed here.
Perhaps I may go back and check again (ah, I forgot to say that I am trying out Openhab3/Mileston 2 in the container):
Basically I don’t know how I can enter the CMOD command in the Docker App in the DSM? It looks like this for me:
on my Raspberry (= openhab2 productive system) I go in via Putty … but here on the Synology I can’t find the right port … if it is one of these … it wouldn’t work:
I am stuck as “stuck”
are you passing it through to the container? you need to have the permissions set via ssh on the Syno not the docker.
then SSH to your syno and be sure the /dev/ttyACM is owned by the user that the docker openhab runs as:
ll /dev/ttyACM0
crwxrwxrwx 1 docker-rw openhab 166, 0 Nov 20 19:58 /dev/ttyACM0
my docker containers run as docker-rw (probably the same for you)
Mmmh, still have problems … I have now logged in with the user who also has docker permission
But CMOD still won’t work:
its “chmod”
oh, silly me … but no difference:
are you root?
do a reboot with the stick attached and try again
its ttyACM0 not AM0
Okay, now it works … i’ve walked this path:
1a) give “high priority” zu Container:
1b) be sure that the Openhab-Admin-User have has the correct permissions on the Synology:
1c) restart synology NAS
2) SSH to NAS with a AdminUser with appropriate access rights to the “Docker” folder:
2a) the user should look like this
2b) SSH to NAS with a AdminUser like this:
- a) Try to find the Thing and create:
b) entry for “serial port” added and saved
Thing created and here we go:
is the stick online if you restart the container or do you need to restart to synology?
this was also a problem the time i used it, when i have done some changes and need to reboot openhab (container), than zwave was not working anymore
quite honestly - I can’t put my finger on it … I have tried -zig times around … and at some point it worked. In EVERY case, however, the step “2b)” must be carried out - otherwise nothing works.
Hi @mpuff, quick question on this one: I’m currently having a similar issue (my Aeotec Z-Wave Gen5+ Stick sometimes stays offline after I reboot my Raspi, and only re-deploying the container solves the problem, see here). Is this similar to what you experienced / have you found a solution to that?
hello, sounds like a similar problem yes, i have installed zwave2mqtt on another raspberry in docker, this was working really good.
Just fyi: In the meantime there’s been some discussion around this problem, and the following fix solved it for me at least symptom-based. The root cause seems to be an unsolved bug.
