Hey @chris,
This regards both openhab 1.7 and 2 actually.
It seems my aeon z stick S2 is not in “listening” mode according to habmin.
So it’s not creating a good mesh network as all nodes go via another node instead of directly to the controller.
I can’t see anywhere in habmin, both 1 and 2 where I can let it be in listening mode.
It is set as “mastercontroller = true” as well as “SUC = true”.
HEAL does not seem to work as well.
So I removed one of the nodes that rest of nodes were routing through and then my controller started marking all nodes red/dead.
edit: I removed one of the nodes that were marked as dead and re added it. It gave it a new node ID per usual, but it instantly was marked dead. They both are in the same room and can see each other.
I really believe this is something with “listening = false” in habmin.
Edit 2.
Saw in association groups and switch state that some of my nodes were member of node 1.
I edited this, now the nodes gained some more routes. But not directly to my controller.
A heal and reinitialise of a node does this:
2016-10-16 21:32:52.507 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 16: Unsu
pported command class ZWAVE_PLUS_INFO
pported command class DEVICE_RESET_LOCALLY
pported command class ASSOCIATION_GROUP_INFO
pported command class POWERLEVEL
pported command class FIRMWARE_UPDATE_MD
2016-10-16 21:32:52.648 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 16: Unsu
2016-10-16 21:32:52.663 [WARN ] [.o.b.z.i.p.c.ZWaveCommandClass] - NODE 16: Unsu
2016-10-16 21:32:53.880 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 16: No i
tem bound for event, endpoint = 0, command class = SWITCH_ALL, value = 255, igno
ring.
2016-10-16 21:32:54.426 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 16: No i
tem bound for event, endpoint = 0, command class = CONFIGURATION, value = org.op
enhab.binding.zwave.internal.protocol.ConfigurationParameter@6b65aa0e, ignoring.
2016-10-16 21:32:54.582 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 16: No i
enhab.binding.zwave.internal.protocol.ConfigurationParameter@3ad0552e, ignoring.
2016-10-16 21:32:54.722 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 16: No i
enhab.binding.zwave.internal.protocol.ConfigurationParameter@463a903d, ignoring.
2016-10-16 21:32:54.878 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 16: No i
enhab.binding.zwave.internal.protocol.ConfigurationParameter@15c9861, ignoring.
2016-10-16 21:32:55.019 [WARN ] [.z.internal.ZWaveActiveBinding] - NODE 16: No i
enhab.binding.zwave.internal.protocol.ConfigurationParameter@58081bd4, ignoring.
