Is there any way to skip the graphical setup for z-wave? I am having issues because of a mix of graphical and text configs. Can I leave zwave.items like this:
Group Tstat10 (Thermostats)
Group Tstat10_Chart (Tstat10)
Number Basement_Tstat_HeatSetPoint "Basement Heat Setpoint [%.1f °F]" <temperature> (Tstat10) {zwave="4:command=thermostat_setpoint,setpoint_type=1,setpoint_scale=1,refresh_interval=600"}
Number Basement_Tstat_CoolSetPoint "Basement Cool Setpoint [%.1f °F]" <temperature> (Tstat10) {zwave="4:command=thermostat_setpoint,setpoint_type=2,setpoint_scale=1,refresh_interval=600"}
Number Basement_Tstat_Temperature "Basement Temperature [%.1f °F]" <temperature> (Tstat10_Chart, Room_Temperature) {zwave="4:1:command=sensor_multilevel,sensor_type=1,refresh_interval=600"}
Number Basement_Tstat_Humidity "Basement Humidity [%.1f %%]" <humidity> (Tstat10_Chart, Humidity) {zwave="4:2:command=sensor_multilevel,sensor_type=5,refresh_interval=600"}
Number Basement_Tstat_OpMode "Basement Mode" <settings> (Tstat10) {zwave="4:command=thermostat_mode,refresh_interval=600"}
Number Basement_Tstat_ModeState "Basement State [MAP(ct100.map):%s]" <settings> (Tstat10) {zwave="4:command=thermostat_operating_state,refresh_interval=60"}
Number Basement_Tstat_Battery "Basement Thermostat Battery [%d %%]" <battery> (Tstat10, Battery) {zwave="4:command=BATTERY,refresh_interval=1200"}
DateTime Basement_Tstat_Clock (Tstat10, Clock) {zwave="4:command=CLOCK"}
Number Basement_Chart_Period "Chart Period"
Or do they need to be like:
Group Tstat11 (Thermostats)
Group Tstat11_Chart (Tstat11)
Number Office_Tstat_HeatSetPoint "Office Heat Setpoint [%.1f °F]" <temperature> (Tstat11) {channel="zwave:device:36154fb5:node2:thermostat_setpoint_heating"}
Number Office_Tstat_CoolSetPoint "Office Cool Setpoint [%.1f °F]" <temperature> (Tstat11) {channel="zwave:device:36154fb5:node2:thermostat_setpoint_cooling"}
Number Office_Tstat_Temperature "Office Temperature [%.1f °F]" <temperature> (Tstat11_Chart, Room_Temperature) {channel="zwave:device:36154fb5:node2:sensor_temperature"}
Number Office_Tstat_Humidity "Office Humidity [%.1f %%]" <humidity> (Tstat11_Chart, Humidity) {channel="zwave:device:36154fb5:node2:sensor_relhumidity2"}
Number Office_Tstat_OpMode "Office Mode" <settings> (Tstat11) {channel="zwave:device:36154fb5:node2:thermostat_mode"}
Number Office_Tstat_ModeState "Office State [MAP(ct100.map):%s]" <settings> (Tstat11) {channel="zwave:device:36154fb5:node2:thermostat_state"}
Number Office_Tstat_Battery "Office Thermostat Battery [%d %%]" <battery> (Tstat11, Battery) {channel="zwave:device:36154fb5:node2:battery-level"}
DateTime Office_Tstat_Clock (Tstat11, Clock) {channel="zwave:device:36154fb5:node2:time_offset"}
Number Office_Chart_Period "Chart Period"
