thanks @chris ! I know that this is strange because when you look at node83 on habmin switch doesn’t go ON or OFF when you push wall button. Lifeline is set to Controller.
Node83 on habmin:
This morning I made new log when I just pushed wall switch (node83) ON / OFF.
I also checked on https://www.cd-jackson.com/index.php/openhab/zwave-log-viewer that there is dimmer state level logged. But state doesn’t report on HABMIN or Habpanel.
Here is the log:
2018-10-27 09:35:27.219 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-10-27 09:35:27.219 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Application Command Request (ALIVE:DONE)
2018-10-27 09:35:27.220 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: resetResendCount initComplete=true isDead=false
2018-10-27 09:35:27.220 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2018-10-27 09:35:27.220 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
2018-10-27 09:35:27.220 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
2018-10-27 09:35:27.221 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 83: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
2018-10-27 09:35:27.221 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 83: Switch Multi Level report, value = 1
2018-10-27 09:35:27.221 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 83: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-10-27 09:35:27.222 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 83: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 1
2018-10-27 09:35:27.222 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 83: Updating channel state zwave:device:12345678-9012-3456-7890-123456789012:node83:switch_dimmer1 to 1 [PercentType]
2018-10-27 09:35:27.222 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Commands processed 1.
2018-10-27 09:35:27.223 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@6f7be5e6.
2018-10-27 09:35:27.223 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-10-27 09:35:27.224 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-10-27 09:35:27.224 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2018-10-27 09:35:30.902 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 1F 0E 60 0D 01 01 32 02 21 44 00 00 0E ED 00 00 25
2018-10-27 09:35:30.903 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=31, callback=0, payload=00 1F 0E 60 0D 01 01 32 02 21 44 00 00 0E ED 00 00
2018-10-27 09:35:30.903 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=31, callback=0, payload=00 1F 0E 60 0D 01 01 32 02 21 44 00 00 0E ED 00 00
2018-10-27 09:35:30.903 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-10-27 09:35:30.903 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 31: Application Command Request (ALIVE:DONE)
2018-10-27 09:35:30.903 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 31: resetResendCount initComplete=true isDead=false
2018-10-27 09:35:30.903 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 31: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2018-10-27 09:35:30.903 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 31: Incoming command class COMMAND_CLASS_METER, endpoint 1
2018-10-27 09:35:30.904 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 31: SECURITY NOT required on COMMAND_CLASS_METER
2018-10-27 09:35:30.904 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 31: Received COMMAND_CLASS_METER V3 METER_REPORT
2018-10-27 09:35:30.904 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 31: Meter: Type=Electric(1), Scale=kWh(0), Value=38.21
2018-10-27 09:35:30.904 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 31: Commands processed 1.
2018-10-27 09:35:30.904 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 31: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@73114b0e.
2018-10-27 09:35:30.904 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-10-27 09:35:30.904 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-10-27 09:35:30.904 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2018-10-27 09:35:31.406 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 3D 03 40 03 0B 84
2018-10-27 09:35:31.407 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=61, callback=0, payload=00 3D 03 40 03 0B
2018-10-27 09:35:31.409 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=61, callback=0, payload=00 3D 03 40 03 0B
2018-10-27 09:35:31.409 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-10-27 09:35:31.409 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 61: Application Command Request (ALIVE:DONE)
2018-10-27 09:35:31.410 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 61: resetResendCount initComplete=true isDead=false
2018-10-27 09:35:31.410 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 61: Incoming command class COMMAND_CLASS_THERMOSTAT_MODE, endpoint 0
2018-10-27 09:35:31.410 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 61: SECURITY not supported
2018-10-27 09:35:31.410 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 61: Received COMMAND_CLASS_THERMOSTAT_MODE V1 THERMOSTAT_MODE_REPORT
2018-10-27 09:35:31.410 [DEBUG] [lass.ZWaveThermostatModeCommandClass] - NODE 61: Thermostat Mode report, value = 11
2018-10-27 09:35:31.411 [DEBUG] [lass.ZWaveThermostatModeCommandClass] - NODE 61: Thermostat Mode Report, value = Heat Econ
2018-10-27 09:35:31.411 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 61: Commands processed 1.
2018-10-27 09:35:31.411 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 61: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@18f0b083.
2018-10-27 09:35:31.411 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-10-27 09:35:31.412 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-10-27 09:35:31.412 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-10-27 09:35:31.412 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2018-10-27 09:35:33.036 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 53 0A 60 0D 01 01 31 05 04 22 00 79 B4
2018-10-27 09:35:33.036 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=83, callback=0, payload=00 53 0A 60 0D 01 01 31 05 04 22 00 79
2018-10-27 09:35:33.036 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=83, callback=0, payload=00 53 0A 60 0D 01 01 31 05 04 22 00 79
2018-10-27 09:35:33.036 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-10-27 09:35:33.037 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Application Command Request (ALIVE:DONE)
2018-10-27 09:35:33.037 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: resetResendCount initComplete=true isDead=false
2018-10-27 09:35:33.037 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2018-10-27 09:35:33.037 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 1
2018-10-27 09:35:33.037 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: SECURITY NOT required on COMMAND_CLASS_SENSOR_MULTILEVEL
2018-10-27 09:35:33.037 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 83: Received COMMAND_CLASS_SENSOR_MULTILEVEL V4 SENSOR_MULTILEVEL_REPORT
2018-10-27 09:35:33.037 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 83: Sensor Type = Power(4), Scale = 0
2018-10-27 09:35:33.037 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 83: Sensor Value = 12.1
2018-10-27 09:35:33.037 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 83: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2018-10-27 09:35:33.037 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 83: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SENSOR_MULTILEVEL, value = 12.1
2018-10-27 09:35:33.037 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 83: Sensor conversion not performed for POWER.
2018-10-27 09:35:33.037 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 83: Updating channel state zwave:device:12345678-9012-3456-7890-123456789012:node83:sensor_power1 to 12.1 [DecimalType]
2018-10-27 09:35:33.038 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Commands processed 1.
2018-10-27 09:35:33.038 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@607da4ff.
2018-10-27 09:35:33.038 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-10-27 09:35:33.038 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-10-27 09:35:33.038 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2018-10-27 09:35:33.727 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 00 53 07 60 0D 01 01 26 03 00 EA
2018-10-27 09:35:33.727 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=83, callback=0, payload=00 53 07 60 0D 01 01 26 03 00
2018-10-27 09:35:33.728 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=83, callback=0, payload=00 53 07 60 0D 01 01 26 03 00
2018-10-27 09:35:33.728 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-10-27 09:35:33.728 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Application Command Request (ALIVE:DONE)
2018-10-27 09:35:33.728 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: resetResendCount initComplete=true isDead=false
2018-10-27 09:35:33.729 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2018-10-27 09:35:33.729 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
2018-10-27 09:35:33.729 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
2018-10-27 09:35:33.729 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 83: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
2018-10-27 09:35:33.729 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 83: Switch Multi Level report, value = 0
2018-10-27 09:35:33.730 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 83: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-10-27 09:35:33.730 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 83: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 0
2018-10-27 09:35:33.730 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 83: Updating channel state zwave:device:12345678-9012-3456-7890-123456789012:node83:switch_dimmer1 to 0 [PercentType]
2018-10-27 09:35:33.730 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Commands processed 1.
2018-10-27 09:35:33.731 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@501929c3.
2018-10-27 09:35:33.731 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-10-27 09:35:33.731 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-10-27 09:35:33.731 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2018-10-27 09:35:36.128 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 1B 0E 32 02 21 74 00 08 AC 63 00 00 00 00 00 00 58
2018-10-27 09:35:36.128 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 0E 32 02 21 74 00 08 AC 63 00 00 00 00 00 00
2018-10-27 09:35:36.129 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 0E 32 02 21 74 00 08 AC 63 00 00 00 00 00 00
2018-10-27 09:35:36.129 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-10-27 09:35:36.130 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Application Command Request (ALIVE:DONE)
2018-10-27 09:35:36.130 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: resetResendCount initComplete=true isDead=false
2018-10-27 09:35:36.130 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: Incoming command class COMMAND_CLASS_METER, endpoint 0
2018-10-27 09:35:36.131 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: SECURITY not supported
2018-10-27 09:35:36.131 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 27: Received COMMAND_CLASS_METER V3 METER_REPORT
2018-10-27 09:35:36.131 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 27: Meter: Type=Electric(1), Scale=W(2), Value=568.419
2018-10-27 09:35:36.131 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Commands processed 1.
2018-10-27 09:35:36.132 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@29a951f5.
2018-10-27 09:35:36.132 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-10-27 09:35:36.132 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-10-27 09:35:36.132 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2018-10-27 09:35:37.386 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 00 53 07 60 0D 01 01 26 03 01 EB
2018-10-27 09:35:37.387 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=83, callback=0, payload=00 53 07 60 0D 01 01 26 03 01
2018-10-27 09:35:37.387 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=83, callback=0, payload=00 53 07 60 0D 01 01 26 03 01
2018-10-27 09:35:37.388 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-10-27 09:35:37.388 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Application Command Request (ALIVE:DONE)
2018-10-27 09:35:37.388 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: resetResendCount initComplete=true isDead=false
2018-10-27 09:35:37.389 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2018-10-27 09:35:37.389 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
2018-10-27 09:35:37.389 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
2018-10-27 09:35:37.390 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 83: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
2018-10-27 09:35:37.390 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 83: Switch Multi Level report, value = 1
2018-10-27 09:35:37.390 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 83: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-10-27 09:35:37.391 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 83: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 1
2018-10-27 09:35:37.391 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 83: Updating channel state zwave:device:12345678-9012-3456-7890-123456789012:node83:switch_dimmer1 to 1 [PercentType]
2018-10-27 09:35:37.392 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Commands processed 1.
2018-10-27 09:35:37.392 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@344098eb.
2018-10-27 09:35:37.392 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-10-27 09:35:37.393 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-10-27 09:35:37.393 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-10-27 09:35:37.393 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2018-10-27 09:35:43.065 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 53 0A 60 0D 01 01 31 05 04 22 00 79 B4
2018-10-27 09:35:43.065 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=83, callback=0, payload=00 53 0A 60 0D 01 01 31 05 04 22 00 79
2018-10-27 09:35:43.065 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=83, callback=0, payload=00 53 0A 60 0D 01 01 31 05 04 22 00 79
2018-10-27 09:35:43.066 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-10-27 09:35:43.066 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Application Command Request (ALIVE:DONE)
2018-10-27 09:35:43.066 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: resetResendCount initComplete=true isDead=false
2018-10-27 09:35:43.066 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2018-10-27 09:35:43.066 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: Incoming command class COMMAND_CLASS_SENSOR_MULTILEVEL, endpoint 1
2018-10-27 09:35:43.066 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: SECURITY NOT required on COMMAND_CLASS_SENSOR_MULTILEVEL
2018-10-27 09:35:43.066 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 83: Received COMMAND_CLASS_SENSOR_MULTILEVEL V4 SENSOR_MULTILEVEL_REPORT
2018-10-27 09:35:43.067 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 83: Sensor Type = Power(4), Scale = 0
2018-10-27 09:35:43.067 [DEBUG] [ss.ZWaveMultiLevelSensorCommandClass] - NODE 83: Sensor Value = 12.1
2018-10-27 09:35:43.067 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 83: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
2018-10-27 09:35:43.067 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 83: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SENSOR_MULTILEVEL, value = 12.1
2018-10-27 09:35:43.067 [DEBUG] [erter.ZWaveMultiLevelSensorConverter] - NODE 83: Sensor conversion not performed for POWER.
2018-10-27 09:35:43.067 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 83: Updating channel state zwave:device:12345678-9012-3456-7890-123456789012:node83:sensor_power1 to 12.1 [DecimalType]
2018-10-27 09:35:43.068 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Commands processed 1.
2018-10-27 09:35:43.068 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@399798c0.
2018-10-27 09:35:43.068 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-10-27 09:35:43.068 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-10-27 09:35:43.068 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2018-10-27 09:35:43.288 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 25 0E 60 0D 01 01 32 02 21 44 00 00 0D 1F 00 00 EE
2018-10-27 09:35:43.288 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=37, callback=0, payload=00 25 0E 60 0D 01 01 32 02 21 44 00 00 0D 1F 00 00
2018-10-27 09:35:43.289 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=37, callback=0, payload=00 25 0E 60 0D 01 01 32 02 21 44 00 00 0D 1F 00 00
2018-10-27 09:35:43.289 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-10-27 09:35:43.289 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Application Command Request (ALIVE:DONE)
2018-10-27 09:35:43.289 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: resetResendCount initComplete=true isDead=false
2018-10-27 09:35:43.289 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2018-10-27 09:35:43.290 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: Incoming command class COMMAND_CLASS_METER, endpoint 1
2018-10-27 09:35:43.290 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 37: SECURITY NOT required on COMMAND_CLASS_METER
2018-10-27 09:35:43.290 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 37: Received COMMAND_CLASS_METER V3 METER_REPORT
2018-10-27 09:35:43.290 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 37: Meter: Type=Electric(1), Scale=kWh(0), Value=33.59
2018-10-27 09:35:43.291 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Commands processed 1.
2018-10-27 09:35:43.291 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 37: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@2059e900.
2018-10-27 09:35:43.291 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-10-27 09:35:43.291 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-10-27 09:35:43.292 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2018-10-27 09:35:43.835 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 00 53 07 60 0D 01 01 26 03 00 EA
2018-10-27 09:35:43.836 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=83, callback=0, payload=00 53 07 60 0D 01 01 26 03 00
2018-10-27 09:35:43.836 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=83, callback=0, payload=00 53 07 60 0D 01 01 26 03 00
2018-10-27 09:35:43.836 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-10-27 09:35:43.836 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Application Command Request (ALIVE:DONE)
2018-10-27 09:35:43.836 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: resetResendCount initComplete=true isDead=false
2018-10-27 09:35:43.836 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: Decapsulating COMMAND_CLASS_MULTI_CHANNEL
2018-10-27 09:35:43.837 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: Incoming command class COMMAND_CLASS_SWITCH_MULTILEVEL, endpoint 1
2018-10-27 09:35:43.837 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: SECURITY NOT required on COMMAND_CLASS_SWITCH_MULTILEVEL
2018-10-27 09:35:43.837 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 83: Received COMMAND_CLASS_SWITCH_MULTILEVEL V3 SWITCH_MULTILEVEL_REPORT
2018-10-27 09:35:43.837 [DEBUG] [ss.ZWaveMultiLevelSwitchCommandClass] - NODE 83: Switch Multi Level report, value = 0
2018-10-27 09:35:43.837 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 83: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
2018-10-27 09:35:43.837 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 83: Got a value event from Z-Wave network, endpoint = 1, command class = COMMAND_CLASS_SWITCH_MULTILEVEL, value = 0
2018-10-27 09:35:43.837 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 83: Updating channel state zwave:device:12345678-9012-3456-7890-123456789012:node83:switch_dimmer1 to 0 [PercentType]
2018-10-27 09:35:43.838 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Commands processed 1.
2018-10-27 09:35:43.838 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@439c3207.
2018-10-27 09:35:43.838 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-10-27 09:35:43.838 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-10-27 09:35:43.839 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2018-10-27 09:35:46.130 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 14 00 04 00 1B 0E 32 02 21 74 00 08 85 D3 00 00 00 00 00 00 C1
2018-10-27 09:35:46.130 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 0E 32 02 21 74 00 08 85 D3 00 00 00 00 00 00
2018-10-27 09:35:46.131 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=27, callback=0, payload=00 1B 0E 32 02 21 74 00 08 85 D3 00 00 00 00 00 00
2018-10-27 09:35:46.132 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-10-27 09:35:46.132 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Application Command Request (ALIVE:DONE)
2018-10-27 09:35:46.132 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: resetResendCount initComplete=true isDead=false
2018-10-27 09:35:46.133 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: Incoming command class COMMAND_CLASS_METER, endpoint 0
2018-10-27 09:35:46.133 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: SECURITY not supported
2018-10-27 09:35:46.133 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 27: Received COMMAND_CLASS_METER V3 METER_REPORT
2018-10-27 09:35:46.133 [DEBUG] [.commandclass.ZWaveMeterCommandClass] - NODE 27: Meter: Type=Electric(1), Scale=W(2), Value=558.547
2018-10-27 09:35:46.134 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Commands processed 1.
2018-10-27 09:35:46.134 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Checking command org.openhab.binding.zwave.internal.protocol.ZWaveCommandClassPayload@732b6d5f.
2018-10-27 09:35:46.134 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction completed - outstandingTransactions 0
2018-10-27 09:35:46.134 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2018-10-27 09:35:46.135 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2018-10-27 09:35:48.337 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0D 00 04 00 53 07 60 0D 01 01 26 03 01 EB
2018-10-27 09:35:48.338 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationCommandHandler[4], type=Request[0], dest=83, callback=0, payload=00 53 07 60 0D 01 01 26 03 01
2018-10-27 09:35:48.339 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationCommandHandler[4], type=Request[0], dest=83, callback=0, payload=00 53 07 60 0D 01 01 26 03 01
2018-10-27 09:35:48.340 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2018-10-27 09:35:48.340 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 83: Application Command Request (ALIVE:DONE)
2018-10-27 09:35:48.340 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 83: resetResendCount initComplete=true isDead=false
I don’t know at this point where I should troubleshoot this more. If you have any tip where to look this trouble, I will check it. Thank you!
Br, Jussi
