Z-wave - transaction mismatch
Hi!
I’ve set up openHABian on a Pi 3 with a UZB stick as a controller. I’ve tried to get StellaZ thermostats under control, but with no success. The thermostat is recognized and included fine, as far a I can tell. All channels are available and can be bound to items, but I get no data from the device. Readings just say “0” on “NaN”, and the log starts repeating:
[ding.zwave.handler.ZWaveThingHandler] - NODE 2: Pol    ling...
[ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling deferred until initialisation complete
The thermostat has a function “confirm inclusion/exclusion” that can be triggered with a physical button. With that I can get the following in the log:
2018-02-16 13:12:31.128 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 3: Response processed after 950ms/950ms.
2018-02-16 13:12:31.129 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
2018-02-16 13:12:31.131 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0A 00 13 03 03 86 13 26 25 48 38
2018-02-16 13:12:31.133 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 3: Sending REQUEST Message = 01 0A 00 13 03 03 86 13 26 25 48 38
2018-02-16 13:12:31.144 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
2018-02-16 13:12:31.146 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-02-16 13:12:31.148 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
2018-02-16 13:12:31.149 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
2018-02-16 13:12:31.151 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
2018-02-16 13:12:31.152 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 3: Sent Data successfully placed on stack.
2018-02-16 13:12:31.164 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 05 00 13 48 00 A1
2018-02-16 13:12:31.166 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-02-16 13:12:31.168 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 13 48 00 00 00 A3
2018-02-16 13:12:31.170 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 07 00 13 48 00 00 00 A3
2018-02-16 13:12:31.171 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=48 00
2018-02-16 13:12:31.172 [DEBUG] [l.serialmessage.SendDataMessageClass] - NODE 3: SendData Request. CallBack ID = 72, Status = Transmission complete and ACK received(0)
2018-02-16 13:12:31.174 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Config, dest=3, callback=72, payload=03 03 86 13 26
2018-02-16 13:12:31.176 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=48 00
2018-02-16 13:12:31.177 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=72, expected=ApplicationCommandHandler, cancelled=false      MISMATCH
2018-02-16 13:12:31.180 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 0C 00 04 00 03 04 86 14 26 03 B9 00 FE
2018-02-16 13:12:31.184 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2018-02-16 13:12:31.186 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 0C 00 04 00 03 04 86 14 26 03 B9 00 FE
2018-02-16 13:12:31.188 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 0C 00 04 00 03 04 86 14 26 03 B9 00 FE
2018-02-16 13:12:31.190 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 03 04 86 14 26 03 B9 00
2018-02-16 13:12:31.192 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 3: Application Command Request (ALIVE:VERSION)
2018-02-16 13:12:31.193 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 3: Incoming command class VERSION
2018-02-16 13:12:31.194 [DEBUG] [ommandclass.ZWaveVersionCommandClass] - NODE 3: Received COMMAND_CLASS_VERSION command V0
2018-02-16 13:12:31.195 [DEBUG] [ommandclass.ZWaveVersionCommandClass] - NODE 3: Process Version Command Class Report
2018-02-16 13:12:31.196 [DEBUG] [ommandclass.ZWaveVersionCommandClass] - NODE 3: Requested Command Class = SWITCH_MULTILEVEL, Version = 3
2018-02-16 13:12:31.198 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 3: Version = 3, version set. Enabling extra functionality.
2018-02-16 13:12:31.199 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Config, dest=3, callback=72, payload=03 03 86 13 26
2018-02-16 13:12:31.201 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 03 04 86 14 26 03 B9 00
2018-02-16 13:12:31.202 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=72, expected=ApplicationCommandHandler, cancelled=false        transaction complete!
2018-02-16 13:12:31.204 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
The only thing I can spot that looks like a potential issue (besides the “polling deferred until initialisation complete”) is the transaction mismatch at 2018-02-16 13:12:31.177. Can anyone give me pointers on how to get this solved?
Thanks!
There is nothing to solve. This is just a debug message - it’s not an error or anything. It’s perfectly normal.
Hi @chris, thanks for the response.
That’s good to hear. My underlying issue remains, though, so I can’t get any data from the device. What can be deduced from log messages of the device state? What does the “Polling deferred until initialisation complete” mean - what’s the missing initialization, since the device is correctly identified?
I also noticed that when trying to update config parameters for the thing (wakeup interval or polling period), I get this exception:
2018-02-16 15:54:48.019 [ERROR] [st.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at 'things/zwave:device:fed6e7a8:node3/config'
        at org.eclipse.smarthome.config.xml.AbstractXmlBasedProvider.get(AbstractXmlBasedProvider.java:151) [108:org.eclipse.smarthome.config.xml:0.10.0.b1]
        at org.eclipse.smarthome.config.xml.AbstractXmlConfigDescriptionProvider.getConfigDescription(AbstractXmlConfigDescriptionProvider.java:50) [108:org.eclipse.smarthome.config.xml:0.10.0.b1]
        at org.eclipse.smarthome.config.core.ConfigDescriptionRegistry.getConfigDescription(ConfigDescriptionRegistry.java:152) [103:org.eclipse.smarthome.config.core:0.10.0.b1]
        at org.eclipse.smarthome.config.core.ConfigDescriptionRegistry.getConfigDescription(ConfigDescriptionRegistry.java:188) [103:org.eclipse.smarthome.config.core:0.10.0.b1]
        at org.eclipse.smarthome.io.rest.core.internal.thing.ThingResource.normalizeConfiguration(ThingResource.java:735) [126:org.eclipse.smarthome.io.rest.core:0.10.0.b1]
        at org.eclipse.smarthome.io.rest.core.internal.thing.ThingResource.updateConfiguration(ThingResource.java:415) [126:org.eclipse.smarthome.io.rest.core:0.10.0.b1]
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:?]
        at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [177:org.glassfish.jersey.core.jersey-common:2.22.2]
        at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [178:org.glassfish.jersey.core.jersey-server:2.22.2]
        at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [175:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
        at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
        at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
        at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
        at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [85:org.eclipse.jetty.security:9.3.22.v20171030]
        at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
        at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [88:org.eclipse.jetty.servlet:9.3.22.v20171030]
        at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [191:org.ops4j.pax.web.pax-web-jetty:6.0.7]
        at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.eclipse.jetty.server.Server.handle(Server.java:534) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [87:org.eclipse.jetty.server:9.3.22.v20171030]
        at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [79:org.eclipse.jetty.io:9.3.22.v20171030]
        at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [79:org.eclipse.jetty.io:9.3.22.v20171030]
        at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [79:org.eclipse.jetty.io:9.3.22.v20171030]
        at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [90:org.eclipse.jetty.util:9.3.22.v20171030]
        at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [90:org.eclipse.jetty.util:9.3.22.v20171030]
        at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [90:org.eclipse.jetty.util:9.3.22.v20171030]
        at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [90:org.eclipse.jetty.util:9.3.22.v20171030]
        at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [90:org.eclipse.jetty.util:9.3.22.v20171030]
Is this related to the initialisation issue?
Thanks again.
Have you configured associations so that the device will send data to the binding? This is the usual reason for this sort of issue.
I’ve linked the thing’s channels to items that I can see in the UI (using PaperUI). Is this an “association” in OpenHAB parlance, or is something else required? I can’t find “association” in OpenHAB docs. The binding documentation discusses them, but not how to actually create them.
No - it’s not.
Associations are a ZWave feature - not openhab itself.
https://docs.openhab.org/addons/bindings/zwave/readme.html#associations
Ok, thanks. Any pointers on the “how” part? Plenty of sites explain what an association is, none so far how to create one. Neither my controller’s (UZB stick) or the device’s (StellaZ thermostat) documentation have the word “association” in them. Is there an external tool that can achieve this?
An incredibly well-hidden feature, if you ask me :roll_eyes:
Maybe the device doesn’t support associations and it therefore doesn’t report data. Looking at the database, none are defined, so either there aren’t any, or the database is incomplete (both are just as possible).
Can you explain exactly what you are trying to do.
Sure. I have a bunch of StellaZ thermostats that I’d like to get automatically controlled based on a set of rules. As a first step I’m trying to get some manual control over them through openHAB. I get to the point where I have “items” on the paper UI “control” page, with “channels” from “things” representing the thermostats connected to them. At this point I’d be happy to see for instance the actual temperature from the thermostat. I get a view like this:
“0” is the best I can get for a value. Depending on the item’s value type it’s usually “NaN” or “-”, never anything meaningful. OpenHAB log repeats this:
2018-02-17 13:15:59.771 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling...
2018-02-17 13:15:59.774 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 2: Polling deferred until initialisation complete
Adjusting the dimmer control sets a new message to queue, but the same loop keeps repeating in the log. So it seems to me the controller doesn’t get anything back from the thermostat, and the thermostat doesn’t receive command. And updating device configuration parameters results in an exception, as I mentioned above.
So, the simple bottom line: any ideas on what to do to see a real temperature reading? :slightly_smiling_face:
Normally, the temperature would be reported in an association. If the device doesn’t support associations (bad news in general) then you need to adjust the polling rate to (say) 15 minutes so it updates more regularly.
You should also check the wakeup interval to see what this is set to since polling will only work when the device is awake (battery devices sleep most of the time to conserve battery).
If you have all this configured, and it’s still not working, then next is to check the debug logs.
I note that battery % is 0 - that’s probably not a particularly good sign if it’s correct (I guess so) :wink:
Ok, thanks. The wakeup period is insane, if it’s correct (600k+) but I can’t update it due to the exception above. Do you have an idea whether that exception is related to the binding, or something more generic in openHAB?
@chris, can you think of any options on how to find the cause for the exception?
This was the case, whenever trying to update configuration parameters for the device:
2018-02-19 21:18:16.539 [ERROR] [st.core.internal.thing.ThingResource] - Exception during HTTP PUT request for update config at 'things/zwave:device:fed6e7a8:node3/config'
The same exception is mentioned at least here and here, but if either of them contains a solution, I can’t find it. I installed latest snapshot of the Z-wave binding last night, to no effect. openHAB is at version 2.2.0.
Any ideas would be appreciated.
