Hi all,
I’ve updated my openhabian with “openhabian-config”. Since then is the z-stick no longer online. After several hours trying I reinstalled everything. Still no luck. Any ideas
What I did so far:
- used the openhabian image 1.0 (openhabian-ua-netinst-20161216-git52cc420.img)
- installed the Z-Wave binding in the Paper UI
- checked which port with “ls /dev/tty*” appears, when the Aeo Gen5 stick is pluged in. It is “/dev/ttyACM0”
- set the serial parameter in the Paper UI “/dev/ACM0”.
as far as I can recall this steps did the trick the last time (with build 671). There was especially no permission setting necessary. I set the serial parameter in the Paper UI exactly like this “/dev/ACM0” (without quotation marks). Is this correct? I’ve btw also tried “device=serial:/dev/ACM0”, “serial:/dev/ACM0”, …
just fyi: after a bit of reading I checked the permissions. But since my linux knowledge is still limited I’m not yet able to interpret it properly.
[14:15:31] pi@openHABianPi:~$ ls -l /dev/ttyACM0
crw-rw---- 1 root dialout 166, 0 Dec 26 13:49 /dev/ttyACM0
Which user is actually used to run openhab in openhabian?
Thanks for your help!
BR Simon
