I shutdown OpenHAB, installed the updated jar and restarted OpenHAB. Node 29 looks to still be in a partially recognized state (device type is recognized but no channels created).
What do you recommend as the next step?
My first inclination was to exclude and re-include the device but wanted to check first in case there was something else I should try first.
You will need to delete the thing, and add it back. At the moment, you will still be using the thing definition from the previous binding as there is nothing in ESH to update the definitions.
Just delete the thing, go to the inbox and rescan, then add it again (no need to exclude etc).
For the remainder of my devices I’m assuming it would be most efficient to batch them up and fix them all at once (if needed) instead doing them one at a time. Let me know if it’s better to incremental changes instead.
