Z-Wave YRD446
I am trying to add a new z-wave device, but have some questions. On @chris site, I see:
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/624
Endpoint 0 has no command class linked to the basic class.
Device supports configuration, but no parameters are defined.
I am just not sure how to fix that. I also see that everything is checked UnSec, but I would think it should be Secured.
I’ve fixed this - I just ticked BASIC in the DOOR_LOCK command class (this is probably correct - if not we can fix it later).
This probably requires more work… The following table in the manual needs to effectively be input into the database -:
To start this, click on the green + button in the configuration section.
You’ll get the following -:
Hopefully most information will be self explanatory - the main things are just the parameter number, size, and description.
You’re probably right - don’t worry about this though - the binding doesn’t use the information from the database here so it will be secured :wink: .
Thanks for the help! I added the information.
