RPi 3-b, Aeotec USB. OpenHAB 2.5.
I’m having a devil of a time getting my First Alert CO/Smoke detector to be recognized. My thermostat and Deadbolt work fine.
Apparently the device does not stay awake long enough. I have been thrashing around for hours, attempting everything I can find to get past this stage.
All I see in PaperUI Things is Node13 “Online Unknown Device”.
I know I am working with the correct device because each time I exclude it and include it, the Node number goes up by one count.
Apparently the device can be awakened by sliding out the battery, holding the Test button and sliding the battery back in. I have done that so many times the slider is jamming. Nothing helps.
As a test, I did the steps above and captured the log. I don’t know what to do with this. Can anyone give me a hint about how to analyze this log?
Blockquote2020-02-09 15:12:35.937 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage input 0<>128 : Message: class=ApplicationUpdate[73], type=Request[0], dest=13, callback=132, payload=84 0D 0A 04 A1 00 20 80 70 85 71 72 86
2020-02-09 15:12:35.942 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg (0): Message: class=ApplicationUpdate[73], type=Request[0], dest=13, callback=132, payload=84 0D 0A 04 A1 00 20 80 70 85 71 72 86
2020-02-09 15:12:35.943 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2020-02-09 15:12:35.945 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 0
2020-02-09 15:12:35.947 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: null
2020-02-09 15:12:35.950 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=ApplicationUpdate[73], type=Request[0], dest=13, callback=132, payload=84 0D 0A 04 A1 00 20 80 70 85 71 72 86
2020-02-09 15:12:35.953 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 13: Application update request. Node information received. Transaction null
2020-02-09 15:12:35.955 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Creating new instance of command class COMMAND_CLASS_BATTERY
2020-02-09 15:12:35.959 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Command class COMMAND_CLASS_BATTERY, endpoint 0 created
2020-02-09 15:12:35.960 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 13: Application update is adding command class COMMAND_CLASS_BATTERY.
2020-02-09 15:12:35.962 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Adding command class COMMAND_CLASS_BATTERY to the list of supported command classes.
2020-02-09 15:12:35.964 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Creating new instance of command class COMMAND_CLASS_CONFIGURATION
2020-02-09 15:12:35.966 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Command class COMMAND_CLASS_CONFIGURATION, endpoint 0 created
2020-02-09 15:12:35.967 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 13: Application update is adding command class COMMAND_CLASS_CONFIGURATION.
2020-02-09 15:12:35.969 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Adding command class COMMAND_CLASS_CONFIGURATION to the list of supported command classes.
2020-02-09 15:12:35.970 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Creating new instance of command class COMMAND_CLASS_ASSOCIATION
2020-02-09 15:12:35.974 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Command class COMMAND_CLASS_ASSOCIATION, endpoint 0 created
2020-02-09 15:12:35.975 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 13: Application update is adding command class COMMAND_CLASS_ASSOCIATION.
2020-02-09 15:12:35.977 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Adding command class COMMAND_CLASS_ASSOCIATION to the list of supported command classes.
2020-02-09 15:12:35.978 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Creating new instance of command class COMMAND_CLASS_ALARM
2020-02-09 15:12:35.980 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Command class COMMAND_CLASS_ALARM, endpoint 0 created
2020-02-09 15:12:35.982 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 13: Application update is adding command class COMMAND_CLASS_ALARM.
2020-02-09 15:12:35.983 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Adding command class COMMAND_CLASS_ALARM to the list of supported command classes.
2020-02-09 15:12:35.985 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Creating new instance of command class COMMAND_CLASS_MANUFACTURER_SPECIFIC
2020-02-09 15:12:35.987 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Command class COMMAND_CLASS_MANUFACTURER_SPECIFIC, endpoint 0 created
2020-02-09 15:12:35.989 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 13: Application update is adding command class COMMAND_CLASS_MANUFACTURER_SPECIFIC.
2020-02-09 15:12:35.990 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Adding command class COMMAND_CLASS_MANUFACTURER_SPECIFIC to the list of supported command classes.
2020-02-09 15:12:35.992 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Creating new instance of command class COMMAND_CLASS_VERSION
2020-02-09 15:12:35.993 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 13: Command class COMMAND_CLASS_VERSION, endpoint 0 created
2020-02-09 15:12:35.995 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 13: Application update is adding command class COMMAND_CLASS_VERSION.
2020-02-09 15:12:35.996 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Adding command class COMMAND_CLASS_VERSION to the list of supported command classes.
2020-02-09 15:12:35.998 [DEBUG] [essage.ApplicationUpdateMessageClass] - NODE 13: Application update - no transaction.
2020-02-09 15:12:36.000 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2020-02-09 15:12:36.012 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-02-09 15:12:36.250 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start. Holdoff false.
2020-02-09 15:12:36.254 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Is awake with 1 messages in the queue
2020-02-09 15:12:36.257 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: COMMAND_CLASS_WAKE_UP not found - setting AWAKE
2020-02-09 15:12:36.258 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: Start sleep timer at 5000ms
2020-02-09 15:12:36.260 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 13: Got an event from Z-Wave network: ZWaveNodeStatusEvent
2020-02-09 15:12:36.271 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 13: Node Status event - Node is AWAKE
2020-02-09 15:12:36.271 [me.event.ThingUpdatedEvent] - Thing ‘zwave:device:fe40ab17:node13’ has been updated.
2020-02-09 15:12:38.760 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: WakeupTimerTask 1 Messages waiting, state REQUEST_NIF
2020-02-09 15:12:41.260 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: WakeupTimerTask 1 Messages waiting, state REQUEST_NIF
2020-02-09 15:12:41.262 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 13: No more messages, go back to sleep
2020-02-09 15:16:00.896 [vent.ItemStateChangedEvent] - BackRightWindow changed from NULL to StillClosed
Blockquote
