Thanks for quick reply. After turning off the other z-wave controller and repeadeatly doing the inclusion procedure, clicking the Aeon z-wave stick button and “find new items” in Paper UI it finally did show up as a Z-Wave Node 4: ZD2102 Door Window Sensor with 3 channels:
Tamper Alarm
zwave:device:0d062c9b:node4:alarm_burglar
Indicates if the burglar alarm is triggered
radio_button_checked
Door Sensor
zwave:device:0d062c9b:node4:sensor_door
Indicates if the door/window is open or closed
Battery Level
zwave:device:0d062c9b:node4:battery-level
However, I only receive burglar/tamper on (not off), and the door/window sensor never goes off at all…
When I mount it back the burglar/tamper alarm does not go off. When I close the door the z-wave log shows this:
3:58:43.256 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 04 03 20 01 00 D4
13:58:43.259 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
13:58:43.259 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 04 03 20 01 00 D4
13:58:43.259 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 04 03 20 01 00 D4
13:58:43.259 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 03 20 01 00
13:58:43.259 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Application Command Request (ALIVE:DONE)
13:58:43.259 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 4: Starting initialisation from DONE
13:58:43.259 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@3da41d16 already registered
13:58:43.259 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Incoming command class BASIC
13:58:43.259 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 4: Received Basic Request
13:58:43.259 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 4: Basic Set sent to the controller will be processed as Basic Report
13:58:43.259 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 4: Basic report, value = 0x00
13:58:43.259 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
13:58:43.259 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
13:58:43.259 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 0
13:58:43.259 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=4, callback=142, payload=04 02 84 08
13:58:43.259 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 03 20 01 00
13:58:43.259 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=142, expected=SendData, cancelled=false MISMATCH
When I open the door it shows this:
13:59:51.710 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 04 03 20 01 FF 2B
13:59:51.712 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
13:59:51.712 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 04 03 20 01 FF 2B
13:59:51.712 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 04 03 20 01 FF 2B
13:59:51.712 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 03 20 01 FF
13:59:51.712 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Application Command Request (ALIVE:DONE)
13:59:51.712 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 4: Starting initialisation from DONE
13:59:51.712 [DEBUG] [ve.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@3da41d16 already registered
13:59:51.712 [DEBUG] [ssage.ApplicationCommandMessageClass] - NODE 4: Incoming command class BASIC
13:59:51.712 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 4: Received Basic Request
13:59:51.712 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 4: Basic Set sent to the controller will be processed as Basic Report
13:59:51.712 [DEBUG] [.commandclass.ZWaveBasicCommandClass] - NODE 4: Basic report, value = 0xFF
13:59:51.712 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
13:59:51.712 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
13:59:51.712 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
13:59:51.712 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=4, callback=142, payload=04 02 84 08
13:59:51.712 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 03 20 01 FF
13:59:51.712 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=142, expected=SendData, cancelled=false MISMATCH
