The zWave database is missing some parameters for the ZEN22 switch that I recently received. I would like to update the database but I do not know what version number I should be using.
PaperUI shows zwave_version 3.5 and HABmin shows Firmware Version 3.5… However the XML file for the node in userdata/zwave/ shows version 4 for the node. Which version should I use in the database?
This will be my first time updating the zWave database and I’m hoping not to muck it up
I’m running version 2.5.0.00 but the parameters are not in the CD Jackson database so I believe the OpenHAB version is irrelevant, correct?
I know (based on zooz’s current manual) that I am missing configuration parameters 13 - enable/disable scene control, 14 - enable/disable double tap and 15 - enable/disable paddle control. There could be more, I am interested in scene control and figured I would look more closely while updating the database.
Yes, the manual shows parameters 13 - 15 but the CD Jackson database only goes to parameter 12, parameters 13 - 15 are not there. I tried to attach the manual from TheSmartestHouse.com but it is too large. A screen shot of the relevant section is below (see the right hand column).
I think I saw a newer firmware version in our database too. Let me look at that later. If I see things missing I will verify with their support whether your firmware version has those features.
I have found problems I’m their manuals on a couple of occasions.
I will reach out to their support to verify the firmware versions for those features. They have been very helpful in supporting their devices in openHAB.
EDIT: I just sent the email to support asking about those features & firmware versions. they likely need to check with their engineers.
EDIT2: That functionality was added in version 3.01 (shown as 3.1 in OH). I will need a copy of your xml file to make a new database entry for this. 3.0 did not have scene control, as seen in the manual attached to the database entry.
