Where and how will I add controls? I just added the lock in the things menu and it shows lock status channel.
What does the control menu show you?
Have you linked any channels to some items - I guess not?
no how will i do that
You should read the openhab documentation if you are not familiar with the basic operation of the system.
Chris,
I add door lock state and battery channels to control. The door lock state channel is defaulted to off when I toggle it on it doesnāt stay on and in the openhab log file it states that :ādoorlockstate failed to initialiseā
please see the control screenshot.
2018-09-21 22:44:23.479 [INFO ] [basic.internal.servlet.WebAppServlet] - Stopped Basic UI
2018-09-21 22:44:31.654 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Stopped Paper UI
2018-09-21 22:44:31.680 [INFO ] [panel.internal.HABPanelDashboardTile] - Stopped HABPanel
2018-09-21 22:44:31.693 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Stopped Home Builder
2018-09-21 22:44:31.717 [INFO ] [.dashboard.internal.DashboardService] - Stopped Dashboard
2018-09-21 22:45:14.513 [INFO ] [ebuilder.internal.HomeBuilderServlet] - Started Home Builder at /homebuilder
2018-09-21 22:45:14.815 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2018-09-21 22:45:15.052 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at http://192.168.1.15:8080
2018-09-21 22:45:15.065 [INFO ] [.dashboard.internal.DashboardService] - Started Dashboard at https://192.168.1.15:8443
2018-09-21 22:45:29.434 [INFO ] [thome.model.lsp.internal.ModelServer] - Started Language Server Protocol (LSP) service on port 5007
2018-09-21 22:45:33.372 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2018-09-21 22:45:33.490 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2018-09-21 22:45:38.489 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 000D6F000F747372: Starting ZigBee device discovery
2018-09-21 22:45:38.537 [INFO ] [g.discovery.internal.PersistentInbox] - Added new thing āzigbee:device:9abac4d2:000d6f000f747372ā to inbox.
2018-09-21 22:46:58.054 [ERROR] [al.converter.ZigBeeConverterDoorLock] - 000D6F000F747372: Error opening device door lock controls
2018-09-21 22:46:58.063 [INFO ] [ng.zigbee.handler.ZigBeeThingHandler] - 000D6F000F747372: Channel zigbee:device:9abac4d2:000d6f000f747372:000D6F000F747372_1_doorlockstate failed to initialise
Please provide a full debug log of the initialisation and I will take a look.
chris,
I created default.items and default.sitemap file and the lock shows up on both controls and basic ui. In both cases it only show on and off. What am I missing to see the lock and unlock functionality
Again when I set the switch to on I get the following message and changes back to off.
I hope this is the log your were expecting:
2018-09-22 19:34:47.684 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 000D6F000F747372: Command for channel zigbee:device:9abac4d2:000d6f000f747372:000D6F000F747372_1_doorlockstate --> OFF
2018-09-22 19:34:47.694 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 000D6F000F747372: No handler found for zigbee:device:9abac4d2:000d6f000f747372:000D6F000F747372_1_doorlockstate
2018-09-22 19:35:01.469 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 000D6F000F747372: Command for channel zigbee:device:9abac4d2:000d6f000f747372:000D6F000F747372_1_doorlockstate --> ON
2018-09-22 19:35:01.477 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 000D6F000F747372: No handler found for zigbee:device:9abac4d2:000d6f000f747372:000D6F000F747372_1_doorlockstate
2018-09-22 19:35:46.525 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 000D6F000F747372: Node updated - ZigBeeNode [IEEE=000D6F000F747372, NWK=D545, Type=END_DEVICE]
2018-09-22 19:35:46.536 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Start.
2018-09-22 19:35:46.681 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Done.
2018-09-22 19:35:49.856 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Start.
2018-09-22 19:35:50.001 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Done.
2018-09-22 19:36:57.618 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 000D6F000F747372: Node updated - ZigBeeNode [IEEE=000D6F000F747372, NWK=D545, Type=END_DEVICE]
2018-09-22 19:36:57.626 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Start.
2018-09-22 19:36:57.719 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Done.
2018-09-22 19:36:59.560 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Start.
2018-09-22 19:36:59.697 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Done.
2018-09-22 19:41:59.656 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Start.
2018-09-22 19:41:59.791 [DEBUG] [nal.ZigBeeNetworkStateSerializerImpl] - Saving ZigBee network state: Done.
2018-09-22 19:43:01.271 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 000D6F000F747372: Command for channel zigbee:device:9abac4d2:000d6f000f747372:000D6F000F747372_1_doorlockstate --> ON
2018-09-22 19:43:01.279 [DEBUG] [ng.zigbee.handler.ZigBeeThingHandler] - 000D6F000F747372: No handler found for zigbee:device:9abac4d2:000d6f000f747372:000D6F000F747372_1_doorlockstate
Chris,
I reset the lock and now the lock status could be changed from on to off and vice/versa
I also created the following rule and seams to be working. how can I change this rule to perform lock and unlock
rule āLock_itā
Item My_iPhone changed from OFF to ON
Door_Lock_State.sendCommand(ON)
rule āUnLock_itā
Item My_iPhone changed from ON to OFF
Door_Lock_State.sendCommand(OFF)
Great - Iām glad you finally got it working.
Chris,
What command can I send from the rule script to lock and unlock the device?
This is a switch, so you can set it to ON and OFF.
Chris,
So your new code does not give me the locking and unlocking ability?
Sorry, Iām confused - I thought you said above it was working?
If this is not the case, then please can you clearly describe what your issue is.
I have a lock(YRD216) that is connected to openhab I want to be able to lock and unlock it from openhab.
currently I see the battery percentage and (on and off) status. I have not been able to unlock it or lock it
You should be able to send a command to the channel to unlock and lock it. If itās not working, then please provide a full debug log of the initialisation of the binding. Please also ensure you use code fences when posting logs so they are readable.
What is the locking and unlocking command ?
You need to set the item to ON or OFF. ON will lock it, and OFF will unlock it.
