Hi
I’ve built a background lighting using a 12 V LED stripe. The stripe has an external 12 V power supply and can be switched on/off via ZigBee (using a Philips Hue Smart Plug and an IKEA Tradfri remote control). For dimming, I’ve integrated a 12 V dimmer (link to Amazon).
That works fine so far and looks good. However, the perfect solution would be if I could dim the LED stripe via ZigBee. The remote control already supports dimming.
Now I’m looking for a ZigBee controller/power supply that has a power input of 230 V, a power output of 12 V and can be dimmed via ZigBee. There are plenty of controllers that are…
- 12 V only (link to Amazon) and need an external power supply or
- 230 V only (link to Amazon).
I’m not a fan of option 1 as the external power supply would be always on (small but steady power consumption) and for option 2, another 12 V transformer would be necessary.
Is anyone aware of a ZigBee dimmer having a power input of 230 V and a power output of 12 V?
Thank you and have a great weekend
