markymark
(Mark Baumann)
February 6, 2020, 8:21pm
1
Hello I have following problem:
2020-02-06 20:19:07.031 [me.event.ThingUpdatedEvent] - Thing 'zigbee:coordinator_cc2531:6d1beb44' has been updated.
2020-02-06 20:19:07.034 [hingStatusInfoChangedEvent] - 'zigbee:coordinator_cc2531:6d1beb44' changed from INITIALIZING to UNKNOWN
2020-02-06 20:19:13.072 [WARN ] [.cc2531.network.ZigBeeNetworkManager] - Dongle reset failed. Assuming bootloader is running and sending magic byte 0xef.
2020-02-06 20:19:18.079 [WARN ] [.cc2531.network.ZigBeeNetworkManager] - Attempt to get out from bootloader failed.
Can someone help me please? Thx!
markymark
(Mark Baumann)
February 6, 2020, 8:47pm
2
you can set the bottloader number to another number but a random one does not solve my problem.
chris
(Chris Jackson)
February 6, 2020, 8:50pm
3
No - it won’t. This must be set to the default unless you know that the firmware was changed. If it’s not correct, then the binding won’t be able to communicate with the bootloader.
markymark
(Mark Baumann)
February 6, 2020, 9:47pm
4
Ok cool but the default does not work too and says the same problem with the bootloader
chris
(Chris Jackson)
February 6, 2020, 9:48pm
5
That likely means that there is a communication problem, or the stick doesn’t work, or the stick doesn’t have the correct firmware, or maybe it’s not programmed.
markymark
(Mark Baumann)
April 18, 2020, 11:48am
8
finally the device is online
So what did you, to make it work?
D1rk
(Dirk)
October 23, 2021, 4:13pm
10
Hi @markymark . How did you resolve the issue? I am getting exactly the same Warnings. Thanks, Dirk
+1
Did anyone find the cure… and how?
To answer my own question:
In my case i got the port wrong. It was /dev/ttyACM0 NOT /dev/ttyAMA0
all good now
markymark
(Mark Baumann)
May 16, 2022, 7:25am
13
Thanks @NOOBintown for helping at this post here. I think there are multiple possibilities why it does not work.
