@chris
I looked at the script quickly and at least some pieces seem to come from your server.
http://www.cd-jackson.com/downloads/openhab2/org.openhab.binding.zwave-${OH_VERSION}-SNAPSHOT.jar
@chris
I don’t really know why - I suspect that this is only if you choose a specific option to use a custom development version supplied by me? It shouldn’t be something that people are using at all these days.
I will look at this the first chance I get, but I’m a bit busy ATM.
That is what you get with the “Development” version of the zwave binding. In the past, this is where the version with security was located before it was merged. I left it in the script since Chris has thrown some bindings out there for people to test.
Seems to work so far with Openhab 2.5.0.M3 and org.openhab.binding.zwave-2.5.0-SNAPSHOT.jar and installed per the README manual install instructions (including adding stream and installing the serial transport feature, thanks
I’m also getting the error message in the JAR files
[21:12:29] openhabian@openHABianPi:/usr/share/openhab2/addons/archive/zwave$ ls -l
total 12
-rw-rw-r-- 1 openhab openhab 854 Sep 28 14:07 org.openhab.binding.zwave-2.5.0-SNAPSHOT.20190928141422.old
-rw-rw-r-- 1 openhab openhab 854 Sep 30 20:47 org.openhab.binding.zwave-2.5.0-SNAPSHOT.20190930205104.old
-rw-rw-r-- 1 openhab openhab 854 Sep 30 20:51 org.openhab.binding.zwave-2.5.0-SNAPSHOT.20190930210809.old
[21:12:32] openhabian@openHABianPi:/usr/share/openhab2/addons/archive/zwave$ cat org.openhab.binding.zwave-2.5.0-SNAPSHOT.2019093021*
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=utf-8"/>
<title>Error 403 Trying to access a file outside of the directory, target: org.openhab.addons.bundles/org.openhab.binding.zwave/2.5.0-SNAPSHOT/org.openhab.binding.zwave-2.5.0-SNAPSHOT.jar</title>
</head>
<body><h2>HTTP ERROR 403</h2>
<p>Problem accessing /job/openHAB2-Bundles/lastSuccessfulBuild/org.openhab.addons.bundles%24org.openhab.binding.zwave/artifact/org.openhab.addons.bundles/org.openhab.binding.zwave/2.5.0-SNAPSHOT/org.openhab.binding.zwave-2.5.0-SNAPSHOT.jar. Reason:
<pre> Trying to access a file outside of the directory, target: org.openhab.addons.bundles/org.openhab.binding.zwave/2.5.0-SNAPSHOT/org.openhab.binding.zwave-2.5.0-SNAPSHOT.jar</pre></p><hr><a href="http://eclipse.org/jetty">Powered by Jetty:// 9.4.z-SNAPSHOT</a><hr/>
</body>
</html>
This may be contributing to my timeout error. I am on openhab 2.4 stable, on openhabian on a Raspberry Pi 3B.
After running into challenges correctly getting the zwave binding updated, I deleted the binding with the script successfully, confirmed the serial binding was installed (the binding and the logs told me it was), and then tried to re-update the binding with the script.
sudo -u openhab ./zzManualInstall.sh
[... selecting update zwave ]
***** SUMMARY *****
Addons path: /usr/share/openhab2/addons
OpenHAB account: openhab
Requested action: Install or upgrade Z-Wave binding
Current OpenHAB snapshot version: 2.5.0
Requested Z-Wave version: OpenHAB snapshot
Is this correct?
1) Yes, start now 3) Exit
2) No, take me back to the first menu
#? 1
Uninstalling any managed binding(s) and installing serial transport...
Logging in as openhab
... a 'No matching bundles' error mesage is normal, if a binding had not been previously installed.
Backing up and uninstalling any unmanaged installs of Z-Wave...
!!!!! It has taken more than two minutes to uninstall the Z-Wave binding, so exi ting !!!!!
And looking at the logs:
2019-09-30 21:07:57.782 [INFO ] [ing.zwave.handler.ZWaveSerialHandler] - Stopped ZWave serial handler
2019-09-30 21:07:57.821 [hingStatusInfoChangedEvent] - 'zwave:serial_zstick:713fde47' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2019-09-30 21:07:59.322 [INFO ] [internal.service.FeaturesServiceImpl] - The specified feature: 'openhab-transport-serial' version '2.4.0' is already installed
2019-09-30 21:07:59.325 [INFO ] [internal.service.FeaturesServiceImpl] - Adding features: openhab-transport-serial/[2.4.0,2.4.0]
2019-09-30 21:08:08.497 [INFO ] [internal.service.FeaturesServiceImpl] - Changes to perform:
2019-09-30 21:08:08.504 [INFO ] [internal.service.FeaturesServiceImpl] - Region: root
2019-09-30 21:08:08.506 [INFO ] [internal.service.FeaturesServiceImpl] - Bundles to install:
2019-09-30 21:08:08.507 [INFO ] [internal.service.FeaturesServiceImpl] - mvn:org.openhab.binding/org.openhab.binding.zwave/2.4.0
2019-09-30 21:08:08.518 [INFO ] [internal.service.FeaturesServiceImpl] - Installing bundles:
2019-09-30 21:08:08.519 [INFO ] [internal.service.FeaturesServiceImpl] - mvn:org.openhab.binding/org.openhab.binding.zwave/2.4.0
2019-09-30 21:08:09.160 [INFO ] [internal.service.FeaturesServiceImpl] - Done.
The relevant directory structure and permissions:
[21:11:56] openhabian@openHABianPi:/usr/share/openhab2/addons$ ls -l
total 580
drwxrwxr-x+ 4 openhab openhab 4096 Sep 28 14:07 archive
-rw-rw-r-- 1 openhab openhab 548391 Sep 30 20:51 org.apache.servicemix.bundles.xstream-1.4.7_1.jar
-rw-rw-r-- 1 openhab openhab 70 Dec 17 2018 README
-rwxrw-r-- 1 openhab openhab 35992 Sep 28 14:03 zzManualInstall.sh
total 12
My inferences from this, please correct me if I’m wrong:
If this helps,
The path in the error jar file was:
The currently correct and working path was:
https://openhab.jfrog.io/openhab/online-repo-snapshot/2.5/org/openhab/addons/bundles/org.openhab.binding.zwave/2.5.0-SNAPSHOT/org.openhab.binding.zwave-2.5.0-SNAPSHOT.jar
My solution, following the readme instructions here https://github.com/openhab-5iver/openHAB-utils/ :
[given that these commands are so often obliquely referred to, I include the full command for others’ references]
I went into karaf
openhab-cli console
removed the current zwave binding
bundle:uninstall org.openhab.binding.zwave
downloaded the correct file to the addons directory with wget
wget https://openhab.jfrog.io/openhab/online-repo-snapshot/2.5/org/openhab/addons/bundles/org.openhab.binding.zwave/2.5.0-SNAPSHOT/org.openhab.binding.zwave-2.5.0-SNAPSHOT.jar
exited karaf
logout
and restarted the whole system (sudo reboot now). I assume this could have been done in karaf, but this works and old habits & all.
Going back into karaf console and running (bundle:list | grep ZWave) gave me:
267 x Active x 80 x 2.5.0.201909300431 x openHAB Add-ons :: Bundles :: ZWave Binding
I assume this means I’m up and running with the most recent zwave snapshot.
Frustratingly, my new LZW30 switch is still not recognized. This is a concern for another thread.
While I initially started this post to troubleshoot the script and getting the latest zwave snapshot updated, when successful, I decided to leave it as a more complete how-to for others trying to do the same thing when 5iver’s update script is giving the download errors/incorrect jar files.
[also, perhaps it will help 5iver update his script for this not uncommon error, should it be applicable]
It can’t because it is not yet merged from the database to the zwave binding:
I finally made some time to test and push a new release that corrects the download URLs. The script had been downloading an ~800KB file that was not a jar. Unfortunately, the links in the README downloaded the same file. Some error checking should be put into the script for this sort of thing… should be easy to check if the files are jars.
Future updates…
bundle:update
(which lets Karaf resolves the dependencies) instead of copying jars to /addons/I just pushed another update that uses bintray for all downloads. This should help with some of the intermittent download errors experienced with the CI server.
You need me to test this later this week?
No, thank you… I’ve tested it for zwave and I’m sure I’ll hear about it if there is a problem!
I can confirm that the zwave binding is working, unfortunately the zigbee is not. I’ve tried 1.2.3, 1.2.5 and 1.2.6, all of them causing the logfile to fill up with errors…
Some of the logs:
2019-10-19 16:42:19.483 [WARN ] [org.eclipse.jetty.server.HttpChannel] - /rest/inbox/zigbee:coordinator_telegesis:0000000C/approve
javax.servlet.ServletException: javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: org.eclipse.smarthome.core.types.Command cannot be found by org.openhab.binding.zigbee.telegesis_2.5.0.201910190422
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:88) ~[?:?]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.Server.handle(Server.java:531) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260) [84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118) [75:org.eclipse.jetty.io:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762) [87:org.eclipse.jetty.util:9.4.11.v20180605]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680) [87:org.eclipse.jetty.util:9.4.11.v20180605]
Caused by: javax.servlet.ServletException: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: org.eclipse.smarthome.core.types.Command cannot be found by org.openhab.binding.zigbee.telegesis_2.5.0.201910190422
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:489) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) ~[?:?]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865) ~[85:org.eclipse.jetty.servlet:9.4.11.v20180605]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535) ~[85:org.eclipse.jetty.servlet:9.4.11.v20180605]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) ~[82:org.eclipse.jetty.security:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293) ~[?:?]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473) ~[85:org.eclipse.jetty.servlet:9.4.11.v20180605]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144) ~[84:org.eclipse.jetty.server:9.4.11.v20180605]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) ~[?:?]
... 15 more
Caused by: org.glassfish.jersey.server.ContainerException: java.lang.NoClassDefFoundError: org.eclipse.smarthome.core.types.Command cannot be found by org.openhab.binding.zigbee.telegesis_2.5.0.201910190422
at org.glassfish.jersey.servlet.internal.ResponseWriter.rethrow(ResponseWriter.java:278) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.internal.ResponseWriter.failure(ResponseWriter.java:260) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:509) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:334) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) ~[171:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) ~[169:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
... 15 more
Caused by: java.lang.NoClassDefFoundError: org.eclipse.smarthome.core.types.Command cannot be found by org.openhab.binding.zigbee.telegesis_2.5.0.201910190422
at com.sun.proxy.$Proxy148.<clinit>(Unknown Source) ~[?:?]
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method) ~[?:?]
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62) ~[?:?]
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45) ~[?:?]
at java.lang.reflect.Constructor.newInstance(Constructor.java:423) ~[?:?]
at java.lang.reflect.Proxy.newProxyInstance(Proxy.java:739) ~[?:?]
at org.eclipse.smarthome.core.internal.common.SafeCallerBuilderImpl.lambda$0(SafeCallerBuilderImpl.java:68) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
at java.security.AccessController.doPrivileged(Native Method) ~[?:?]
at org.eclipse.smarthome.core.internal.common.SafeCallerBuilderImpl.build(SafeCallerBuilderImpl.java:59) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.doInitializeHandler(ThingManagerImpl.java:770) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.initializeHandler(ThingManagerImpl.java:672) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.registerAndInitializeHandler(ThingManagerImpl.java:1074) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingManagerImpl.thingAdded(ThingManagerImpl.java:457) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyTrackers(ThingRegistryImpl.java:209) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:129) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ThingRegistryImpl.notifyListenersAboutAddedElement(ThingRegistryImpl.java:1) ~[?:?]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.added(AbstractRegistry.java:154) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.added(AbstractRegistry.java:1) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:56) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListeners(AbstractProvider.java:74) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.common.registry.AbstractProvider.notifyListenersAboutAddedElement(AbstractProvider.java:78) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.common.registry.AbstractManagedProvider.add(AbstractManagedProvider.java:61) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.common.registry.AbstractRegistry.add(AbstractRegistry.java:322) ~[102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.config.discovery.internal.PersistentInbox.addThingSafely(PersistentInbox.java:599) ~[?:?]
at org.eclipse.smarthome.config.discovery.internal.PersistentInbox.approve(PersistentInbox.java:172) ~[?:?]
at org.eclipse.smarthome.io.rest.core.internal.discovery.InboxResource.approve(InboxResource.java:104) ~[?:?]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$ResponseOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:160) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) ~[172:org.glassfish.jersey.core.jersey-server:2.22.2]
... 15 more
Which version of OH? Using S1725, I just successfully installed Zigbee (w/ 1.2.5 libs), which I haven’t been able to do since the ESH reintegration.
OH 2.4, it installs ok according to the script, but doesn’t work and gives loads of errors. I wonder if the correct versions of all the dependencies are fetched? I use a Telegesis controller.
What errors? Please post some logs.
The binding is not controller dependent, by the way.
I’ll test on 2.4, but I don’t have a telegesis controller. Could you upgrade to 2.5M4… just do a backup first and it should be easy to rollback.
See my post four days ago…
Do I just change the version number proposed by the script to 2.5M4?
Sorry, no… I was meaning to update the OH version.
BTW, I have not had a chance to test the snapshot version of the zigbee binding on OH 2.4 yet.
Oh, right! I’m rather new to OH and unfortunately I’m not running on a raspberry like everyone else but on a Synology NAS inside a preconfigured docker, so I will first have to figure out how to upgrade OH…
@5iver I was wondering if you could add an option to add the console extensions? There are again the two sets of files required - the ones from the OH repo, and the ZSS repo.
The main one everyone may want is the org.openhab.binding.zigbee.console bundle, and the corresponding ZSS bundle. There are also extensions for Ember and Telegesis, but these are less useful for most people.
The console provides some manual features to read and write data in devices, and also has the ability to provide a backup of the network data stored in the coordinator (this only works for Ember).
