I migrated to Openhab 3.0 and I’m finding a lot of issues with Zigbee binding.
The same configuration that was working with the latest openhab 2.5 version doesn’t work on a fresh Openhab 3 installation.
My hardware is Raspberry PI3 and Bitron Video ZigBee USB Funkstick
At least once per day the binding starts a strange behavior until reboot, then everything restart to work fine for some hours
Everything seems to start with a
2020-12-31 18:01:35.154 [WARN ] [e.ember.internal.ash.AshFrameHandler] - ASH: ERROR received (code 81). Disconnecting.
2020-12-31 18:01:35.195 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:01380F03' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
2020-12-31 18:01:35.203 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:device:01380F03:00158d0004516178' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-12-31 18:01:35.207 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:device:01380F03:00124b001efe4fee' changed from OFFLINE to OFFLINE (BRIDGE_OFFLINE)
2020-12-31 18:01:35.212 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:device:01380F03:00158d00040221f8' changed from OFFLINE to OFFLINE (BRIDGE_OFFLINE)
2020-12-31 18:01:35.216 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:device:01380F03:00158d0004514c4b' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-12-31 18:01:35.220 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:device:01380F03:7cb03eaa00aba09b' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-12-31 18:01:35.225 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:device:01380F03:7cb03eaa00aec851' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2020-12-31 18:01:36.221 [INFO ] [bee.handler.ZigBeeCoordinatorHandler] - ZigBee dongle inactivity timer. Reinitializing ZigBee
2020-12-31 18:01:37.382 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:device:01380F03:7cb03eaa00aba09b' changed from OFFLINE (BRIDGE_OFFLINE) to OFFLINE
2020-12-31 18:01:37.391 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:01380F03' changed from OFFLINE (COMMUNICATION_ERROR) to UNKNOWN
2020-12-31 18:01:44.037 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 7CB03EAA00ABA09B: Starting ZigBee device discovery
2020-12-31 18:01:44.087 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 7CB03EAA00AEC851: Starting ZigBee device discovery
2020-12-31 18:01:44.089 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 00158D0004514C4B: Starting ZigBee device discovery
2020-12-31 18:01:44.097 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 00124B001EFE4FEE: Starting ZigBee device discovery
2020-12-31 18:01:44.104 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 00158D0004516178: Starting ZigBee device discovery
2020-12-31 18:01:44.130 [WARN ] [zsmartsystems.zigbee.ZigBeeExecutors] - Uncaught exception in thread NotificationService-thread-4
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler.nodeUpdated(ZigBeeThingHandler.java:872) ~[?:?]
at org.openhab.binding.zigbee.handler.ZigBeeThingHandler.nodeAdded(ZigBeeThingHandler.java:815) ~[?:?]
at com.zsmartsystems.zigbee.ZigBeeNetworkManager$7.run(ZigBeeNetworkManager.java:1333) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128) ~[?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628) ~[?:?]
2020-12-31 18:01:44.353 [WARN ] [zsmartsystems.zigbee.ZigBeeExecutors] - Uncaught exception in thread NotificationService-thread-19
at com.zsmartsystems.zigbee.ZigBeeNetworkManager$14.run(ZigBeeNetworkManager.java:1733) ~[?:?]
2020-12-31 18:01:44.369 [WARN ] [zsmartsystems.zigbee.ZigBeeExecutors] - Uncaught exception in thread NotificationService-thread-3
2020-12-31 18:01:44.654 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 00158D0004232414: Starting ZigBee device discovery
2020-12-31 18:01:44.661 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 00158D00040221F8: Starting ZigBee device discovery
2020-12-31 18:01:44.103 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:coordinator_ember:01380F03' changed from UNKNOWN to ONLINE
2020-12-31 18:01:44.106 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:device:01380F03:00158d0004516178' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2020-12-31 18:01:44.113 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:device:01380F03:00158d00040221f8' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2020-12-31 18:01:44.118 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:device:01380F03:00158d0004232414' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2020-12-31 18:01:45.994 [INFO ] [bee.discovery.ZigBeeDiscoveryService] - 00158D00040221F8: Starting ZigBee device discovery
2020-12-31 18:01:53.833 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'zigbee:device:01380F03:7cb03eaa00aec851' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
After a lot of
2020-12-31 18:07:32.796 [WARN ] [nding.zigbee.serial.ZigBeeSerialPort] - Processing DATA_AVAILABLE event: Serial buffer overrun
Again
2020-12-31 18:07:32.881 [WARN ] [e.ember.internal.ash.AshFrameHandler] - ASH: ERROR received (code 81). Disconnecting.
Someone could help?
